path: root/arch/arm/mach-rmobile/board.c
2020-05-18common: Drop init.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-05-02ARM: rmobile: Contain CONFIG_ARCH_RMOBILE_BOARD_STRINGMarek Vasut
Pull the symbol from the boards and zap struct rmobile_sysinfo as they are rather useless. The entire purpose of that whole machinery was to print board name in the CONFIG_ARCH_RMOBILE_BOARD_STRING. Do that in a far simpler and more contained manner. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-11-30ARM: rmobile: Zap checkboard on Gen3Marek Vasut
The checkboard() function showing hard-coded board model for which the U-Boot was built is superseded on Gen3 by show_board_info() displaying the Model from device tree. Add small ifdef to stop compiling the function into U-Boot. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: rmobile: Move SoC sources to mach-rmobileNobuhiro Iwamatsu
Move from arch/arm/cpu/armv7/rmobile/ to arch/arm/mach-rmobile/. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
