CONFIG_88F5182
CONFIG_BOARD_IS_OPENRD_BASE
CONFIG_BOARD_IS_OPENRD_CLIENT
CONFIG_BOARD_IS_OPENRD_ULTIMATE
CONFIG_D2NET_V2
CONFIG_FEROCEON
CONFIG_FEROCEON_88FR131
CONFIG_INETSPACE_V2
CONFIG_KW88F6192
CONFIG_KW88F6281
CONFIG_KW88F6702
CONFIG_NET2BIG_V2
CONFIG_NETSPACE_LITE_V2
CONFIG_NETSPACE_MAX_V2
CONFIG_NETSPACE_MINI_V2
CONFIG_NETSPACE_V2
CONFIG_SHEEVA_88SV131
At this point mv-plug-common.h is now only an include of mv-common.h so
remove that indirection.
Have this symbol follow the pattern of all other such symbols.
This patch removes a TODO from the code.
Signed-off-by: Trevor Woerner <twoerner@gmail.com>
As there is only one machine under mach-orion5x, having a Kconfig entry
for SPL_LDSCRIPT is not helpful, move this to the defconfig file.
Suggested-by: Masahiro Yamada <masahiroy@kernel.org>
Reviewed-by: Masahiro Yamada <masahiroy@kernel.org>
With SPL_LDSCRIPT moved to Kconfig (and this being a 'string' config
node), all the lingering definitions in header files will cause
warnings/errors due to the redefinition of the configuration item.
As we don't want to pollute the defconfig files (and values should
usually be identical for entire architectures), the defaults are moved
into Kconfig. Kconfig will always pick the first default that
matches, so please keep these values at the end of each file (to allow
any board-specific Kconfig, which will be included earlier) to
override with an unconditional default setting.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
By making the board selections optional, every defconfig will include
the board selection when running savedefconfig so if a new board is
added to the top of the list of choices the former top's defconfig will
still be correct.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
ED Mini V2 is based on Orion 5x which boots at fixed
address 0xFFFF0000 in NOR Flash. Place SPL there, and
switch U-Boot from .bin to .img format, stored in
NOR Flash at 0xFFF90000.
Note: this patch was tested on HW and works, i.e.
it boots U-Boot properly, but SPL console output
currently does not appear, due to GD being trashed
by arch/arm/lib/spl.c. This trashing is soon to be
removed, and then ED Mini V2 SPL console output will
become visible.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Move
arch/arm/cpu/arm926ejs/orion5x/* -> arch/arm/mach-orion5x/*
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
