path: root/arch/arm/mach-omap2/vc.c
2017-05-15omap: Drop CONFIG_OMAP_VC_I2C_HS_MCODETom Rini
The symbol CONFIG_OMAP_VC_I2C_HS_MCODE always uses the default value. Restructure the comment and code such that if a need arises later to use another value we can address this then. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-21arm: Introduce arch/arm/mach-omap2 for OMAP2 derivative platformsTom Rini
This moves what was in arch/arm/cpu/armv7/omap-common in to arch/arm/mach-omap2 and moves arch/arm/cpu/armv7/{am33xx,omap3,omap4,omap5} in to arch/arm/mach-omap2 as subdirectories. All refernces to the former locations are updated to the current locations. For the logic to decide what our outputs are, consolidate the tests into a single config.mk rather than including 4. Signed-off-by: Tom Rini <trini@konsulko.com>
