path: root/arch/arm/mach-omap2/clocks-common.c
2018-12-10ti: remove usage of DM_I2C_COMPAT and don't disable DM_I2C in SPLJean-Jacques Hiblot
DM_I2C_COMPAT is a compatibility layer that allows using the non-DM I2C API when DM_I2C is used. The goal is to eventually remove DM_I2C_COMPAT when all I2C "clients" have been migrated to use the DM API. This a step in that direction for the TI based platforms. Build tested with buildman: buildman -dle am33xx ti omap3 omap4 omap5 davinci keystone boot tested with: am335x_evm, am335x_boneblack, am335x_boneblack_vboot (DM version), am57xx_evm, dra7xx_evm, k2g_evm, am437x_evm Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-04-08ti: clocks: Fix do_enable_clocks() to accept NULL pointers as input parametersLukasz Majewski
Up till this commit passing NULL as input parameter was allowed, but not handled properly. When one passed NULL to one of this function parameters, the code was executed causing data abort. However, what is more interesting, the abort was not caught because of code execution in HYP mode with masked CPSR A bit ("Imprecise Data Abort mask bit). The TI's AM57xx SoC switch to HYP mode with A bit masked in lowlevel_init.S due to SMC call. Such operation (by default) is performed in SoC ROM code. The problem would pop up when one: - Switch back to SVC mode after disabling LPAE support - Somebody enables A bit (by executing cpsie a asm instruction) and then the previously described exception would be caught. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-04ARM: OMAP4+: Add support for dynamically selecting OPPsLokesh Vutla
It can be expected that different paper spins of a SoC can have different definitions for OPP and can have their own constraints on the boot up OPP for each voltage rail. In order to have this flexibility, add support for dynamically selecting the OPP voltage based on the board to handle any such exceptions. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-11-21arm: Introduce arch/arm/mach-omap2 for OMAP2 derivative platformsTom Rini
This moves what was in arch/arm/cpu/armv7/omap-common in to arch/arm/mach-omap2 and moves arch/arm/cpu/armv7/{am33xx,omap3,omap4,omap5} in to arch/arm/mach-omap2 as subdirectories. All refernces to the former locations are updated to the current locations. For the logic to decide what our outputs are, consolidate the tests into a single config.mk rather than including 4. Signed-off-by: Tom Rini <trini@konsulko.com>
