path: root/arch/arm/mach-omap2/boot-common.c
2019-02-15usb: Rename SPL_USB_SUPPORT to SPL_USB_STORAGEAbel Vesa
Since there is the SPL_USB_HOST_SUPPORT for enabling USB support in SPL, makes more sense to rename the SPL_USB_SUPPORT as SPL_USB_STORAGE. Everything that is not part of the usb storage support in SPL is now build under SPL_USB_HOST_SUPPORT. Signed-off-by: Abel Vesa <abel.vesa@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2019-01-26spl: Kconfig: Drop the _SUPPORT postfix from SPL_DFUAndrew F. Davis
The symbol CONFIG_SPL_DFU_SUPPORT in SPL build has the same meaning as CONFIG_DFU in regular U-Boot. Drop the _SUPPORT to allow for cleaner use in code. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <lukma@denx.de>
2018-09-11ARM: mach-omap2: Don't initialize I2C if DM_I2C is enabledAdam Ford
boot-common.c checks to see if I2C is enabled in SPL, but it doens't check for DM_I2C before initializing it. This will now only initialize the I2C is the DM_I2C is not enabled to avoid initializing it more than once. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-30ti: fastboot: Move weak overrides to board filesAlex Kiernan
Overriding fastboot_set_reboot_flag() in arch/arm/mach-omap2/boot-common.c leaves it applying all boards that derive from this, not just the ones which have support for Android bootloader flow. Move the weak function override to the relevant board files. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-30fastboot: Rename fb_set_reboot_flag to fastboot_set_reboot_flagAlex Kiernan
Rename fb_set_reboot_flag to fastboot_set_reboot_flag so it matches all other fastboot code in the global name space. Fix the guards around them so that they're dependent on FASTBOOT, not just USB_FUNCTION_FASTBOOT. Move the weak implementation of fastboot_set_reboot_flag to fb_common.c so we can call it from non-USB fastboot code. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-04-28spl: ti: Avoid preloader_console_init if !CONFIG_SPL_SERIAL_SUPPORTAlex Kiernan
If CONFIG_SPL_SERIAL_SUPPORT is disabled then the build fails because serial_init is undefined. Guard preloader_console_init() appropriately to fix this. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-03-05spl: Kconfig: Rename SPL_USBETH_SUPPORT to SPL_USB_ETHER to match with the ↵Faiz Abbas
U-boot CONFIG Rename CONFIG_SPL_USBETH_SUPPORT to CONFIG_SPL_USB_ETHER. This enables users to block text using CONFIG_IS_ENABLED() instead of resorting to #if ladders with SPL and non-SPL cases. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2017-08-15env: Drop saveenv() in favour of env_save()Simon Glass
Use the env_save() function directly now that there is only one implementation of saveenv(). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Wolfgang Denk <wd@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10arm: omap: Detect boot mode very earlyLokesh Vutla
ROM stores the boot params information in a known location and passes it to SPL. This information needs to be copied very early during boot or else there is a chance of getting corrupted by SPL. So move this boot device detection very early during boot. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-23ti816x: Add additional boot device detection logicTom Rini
It has been observed that between PG1.0 and PG2.0/2.1 depending on which device we boot from, we may see a different value here than is documented in the TRM. Update the values for NAND and MMC1 based on real life usage on each revision. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-19ti: boot: Register the MMC controllers in SPL in the same way as in u-bootJean-Jacques Hiblot
To keep a consistent MMC device mapping in SPL and in u-boot, let's register the MMC controllers the same way in u-boot and in the SPL. In terms of boot time, it doesn't hurt to register more controllers than needed because the MMC device is initialized only prior being accessed for the first time. Having the same device mapping in SPL and u-boot allows us to use the environment in SPL whatever the MMC boot device. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-01-04SPL: make struct spl_image 64-bit safeAndre Przywara
Since entry_point and load_addr are addresses, they should be represented as longs to cover the whole address space and to avoid warning when compiling the SPL in 64-bit. Also adjust debug prints to add the 'l' specifier, where needed. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2016-11-21arm: Introduce arch/arm/mach-omap2 for OMAP2 derivative platformsTom Rini
This moves what was in arch/arm/cpu/armv7/omap-common in to arch/arm/mach-omap2 and moves arch/arm/cpu/armv7/{am33xx,omap3,omap4,omap5} in to arch/arm/mach-omap2 as subdirectories. All refernces to the former locations are updated to the current locations. For the logic to decide what our outputs are, consolidate the tests into a single config.mk rather than including 4. Signed-off-by: Tom Rini <trini@konsulko.com>
