path: root/arch/arm/mach-omap2/Kconfig
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-23ARM: Kconfig: Move TI_SECURE_DEVICE to a common areaAndrew F. Davis
TI_SECURE_DEVICE is used by both OMAP2+ and Keystone2 family devices, and so when ARCH_OMAP2PLUS was used to gate off the OMAP2+ Kconfig Keystone2 family devices lost this config option. Move this option out of mach-omap2 Kconfig to a spot accessible by both families. We picked arch/arm/Kconfig over the TI specific board/ti/ location as this option is not specific to our boards but rather our architecture. Plus at some point this option can be changed to just SECURE_DEVICE, as having secure parts is not exclusive to TI and so other vendors can interpret this option as needed by their device configurations. Fixes: a93fbf4a7892 ("ARM: omap2+: rename config to ARCH_OMAP2PLUS and consolidate Kconfig") Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-10-20Convert CONFIG_NAND_OMAP_GPMC et al and CONFIG_NAND_MXC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_MXC CONFIG_NAND_OMAP_GPMC CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_ELM CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_SIMPLE CONFIG_SYS_NAND_BUSWIDTH_16BIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues, add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-01Convert CONFIG_SPL_OMAP3_ID_NAND to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SPL_OMAP3_ID_NAND Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13spl: add hierarchical defaults for SPL_LDSCRIPTPhilipp Tomsich
With SPL_LDSCRIPT moved to Kconfig (and this being a 'string' config node), all the lingering definitions in header files will cause warnings/errors due to the redefinition of the configuration item. As we don't want to pollute the defconfig files (and values should usually be identical for entire architectures), the defaults are moved into Kconfig. Kconfig will always pick the first default that matches, so please keep these values at the end of each file (to allow any board-specific Kconfig, which will be included earlier) to override with an unconditional default setting. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-10Convert CONFIG_SYS_I2C_OMAP24XX to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_I2C_OMAP24XX Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-07-22arm: mach-omap2: Move omap5/sec-fxns.c into sec-common.cAndrew F. Davis
TEE loading and firewall setup are common to all omap2 devices, move these function out of omap5 and into mach-omap2. This allows us to use these functions from other omap class devices. Signed-off-by: Andrew F. Davis <afd@ti.com>
2017-06-09am33xx: Finish migration of CONFIG_AM33XX/AM43XXTom Rini
Almost all users of CONFIG_AM33XX/AM43XX have been migrated. Finish moving the last few over to Kconfig, and put all of the boards under the appropriate Kconfig chocie now. This board choice is non-optional, so remove that keyword on am33xx. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-05t81xx: Migrate TI81XX/TI816X/TI814X symbols to KconfigTom Rini
The symbol CONFIG_TI81XX is used for the parts that are common to the TI816x and TI814x SoCs and are not part of CONFIG_ARCH_OMAP2PLUS nor CONFIG_AM33XX. It however has so few uses that we can just modify the code to check for both and drop the symbol. The symbols CONFIG_TI816X and CONFIG_TI814X are for the repective SoCs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-12arm: am33xx: Fix MPU opp selectionLokesh Vutla
Update MPU frequencies and voltages as per the latest DM[1] dated: OCT 2011 Revised APRIL 2016, Section 5.4. Below is the consolidated data: MPU values for PG 2.0 and later(Package ZCZ and ZCE): ------------------------------------------------------- | | ZCZ | ZCE | |-------------------------------------------------------| | | VDD[V] | ARM [MHz] | VDD[V] | ARM [MHz] | |-------|----------|------------|----------|------------| | NITRO | 1.325 | 1000 | NA | NA | |-------|----------|------------|----------|------------| | TURBO | 1.26 | 800 | NA | NA | |-------|----------|------------|----------|------------| |OPP120 | 1.20 | 720 | NA | NA | |-------|----------|------------|----------|------------| |OPP100 | 1.10 | 600 | 1.10 | 600 | |-------|----------|------------|----------|------------| | OPP50 | 0.95 | 300 | 0.95 | 300 | ------------------------------------------------------- There is no eFuse blown on PG1.0 Silicons due to which there is no way to detect the maximum frequencies supported. So default to OPP100 for which both frequency and voltages are common on both the packages. [1] http://www.ti.com/lit/ds/symlink/am3356.pdf Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-12configs: convert CONFIG_SYS_MPUCLK to KconfigLokesh Vutla
2017-05-11arm: am335x: Enable tiny printf in SPLLokesh Vutla
am335x_evm SPL is very close to its limit in SRAM space. Switch to use tiny printf to reclaim some size. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-05-09power: twl4030: Move CONFIG_TWL4030_POWER to KconfigAdam Ford
As requested, I added the CONFIG_TWL4030_POWER to Kconfig and made it the implied default when selecting OMAP34XX as a platform. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-27ARM: omap2+: rename config to ARCH_OMAP2PLUS and consolidate KconfigMasahiro Yamada
In Linux, CONFIG_ARCH_OMAP2PLUS is used for OMAP2 or later SoCs. Rename CONFIG_ARCH_OMAP2 to CONFIG_ARCH_OMAP2PLUS to follow this naming. Move the OMAP2+ board/SoC choice down to mach-omap2/Kconfig to slim down the arch/arm/Kconfig level. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-08arm: mach-omap2: Enable Kconfig support for K2 HS devicesVitaly Andrianov
Like the OMAP54xx, AM43xx, & AM33xx family SoCs, the keystone family of SoCs also have high security enabled models. Allow K2E devices to be built with HS Device Type Support. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Madan Srinivas <madans@ti.com> Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-11-21arm: Introduce arch/arm/mach-omap2 for OMAP2 derivative platformsTom Rini
This moves what was in arch/arm/cpu/armv7/omap-common in to arch/arm/mach-omap2 and moves arch/arm/cpu/armv7/{am33xx,omap3,omap4,omap5} in to arch/arm/mach-omap2 as subdirectories. All refernces to the former locations are updated to the current locations. For the logic to decide what our outputs are, consolidate the tests into a single config.mk rather than including 4. Signed-off-by: Tom Rini <trini@konsulko.com>
