Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
In the spirit of using the same base name for all of these related macros,
rename this to have the operation at the end. This is not widely used so
the impact is fairly small.
The description for MT8512 has some mistake, so correct it.
Signed-off-by: Mingming Lee <Mingming.Lee@mediatek.com>
Move this uncommon header out of the common header.
Move this header out of the common header.
Move this header out of the common header. Network support is used in
quite a few places but it still does not warrant blanket inclusion.
Note that this net.h header itself has quite a lot in it. It could be
split into the driver-mode support, functions, structures, checksumming,
etc.
The binman-option BINMAN_FDT is introduced by this commit:
commit 3c10dc95bdd0 ("binman: Add a library to access binman entries")
BINMAN_FDT being selected when BINMAN=y that resulting in mt7623
and mt7622 are unable to boot. The root cause of this issue is commit:
commit cbd2fba1eca1 ("arm: MediaTek: add basic support for MT7629 boards")
select BINMAN=y in all mediatek SoCs, and others mediatek SoCs not
expect to use BINMAN_FDT.
This patch remove BINMAN=y option when ARCH_MEDIATEK=y and
move this to the specify SoCs part config.
Signed-off-by: Sam Shih <sam.shih@mediatek.com>
Tested-by: Frank Wunderlich <frank-w@public-files.de>
At present panic() is in the vsprintf.h header file. That does not seem
like an obvious choice for hang(), even though it relates to panic(). So
let's put hang() in its own header.
[trini: Migrate a few more files]
These functions relate to memory init so move them into the init
header.
Move this function out of common.h and into a relevant header file.
Add support for MediaTek MT7622 SoC. This include the file
that will initialize the SoC after boot and its device tree.
Reviewed-by: Ryder Lee <ryder.lee@mediatek.com>
Add support for MediaTek MT8512 SoC. This include the file
Signed-off-by: mingming lee <mingming.lee@mediatek.com>
This adds a general board file based on MT8518 SoCs from MediaTek.
Apart from the generic parts (cpu) we add some low level init codes
and initialize the early clocks.
This commit is adding the basic boot support for the MT8518 eMMC board.
[trini: Migrate env location to defconfig, set ENV_IS_IN_MMC]
Signeed-off-by: Tom Rini <trini@konsulko.com>
Add support for MediaTek MT8518 SoC. This include the file
These functions belong in cpu_func.h. Another option would be cache.h
but that code uses driver model and we have not moved these cache
functions to use driver model. Since they are CPU-related it seems
reasonable to put them here.
Move them over.
The pumpkin board is made by Gossamer Engineering and is using
a MediaTek SoC. The board currently comes in two available version:
MT8516 SoC and MT8167 SoC.
The board provides the following IOs: eMMC, NAND, SD card, USB type-A,
Ethernet, Wi-Fi, Bluetooth, Audio (jack out, 2 PDM port, 1 analog in),
serial over USB, and an expansion header.
Additionally there is a HDMI port, DSI port, and camera port only
on the MT8167 version of the board.
The board can be powered by battery and/or via a USB Type-C port and
is using a PMIC MT6392.
The eMMC and NAND are sharing pins and cannot be used together.
This commit is adding the basic boot support for the Pumpkin MT8516
board on the eMMC.
Signed-off-by: Fabien Parent <fparent@baylibre.com>
This patch sets CNTVOFF of ARM CP15 timer to zero to make sure the virtual
counter is fully usable for linux kernel.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
The watchdog of mediatek chips is enabled by bootrom before u-boot is
running. Previously we choose to enable the wdt driver only to disable the
watchdog hardware.
Now wdt service is enabled by default. The function arch_misc_init which is
only used to disable wdt is no longer needed.
Instead of using the watchdog, let's use PSCI to perform the reset
of the SoC.
Add support for MediaTek MT8516 SoC. This include the file
This patch changes mt7629 to use the compatible platform SMP initialization
method of linux kernel.
This adds a general board file based on MT7623 SoCs from MediaTek.
As this u-boot is loaded by MTK proprietary preloader, there is no
low level initializtion codes.
Signed-off-by: Ryder Lee <ryder.lee@mediatek.com>
Tested-by: Matthias Brugger <matthias.bgg@gmail.com>
This adds a general board file based on MT7629 SoCs from MediaTek.
