path: root/arch/arm/mach-mediatek
2019-07-29board: mediatek: Add pumpkin board supportFabien Parent
The pumpkin board is made by Gossamer Engineering and is using a MediaTek SoC. The board currently comes in two available version: MT8516 SoC and MT8167 SoC. The board provides the following IOs: eMMC, NAND, SD card, USB type-A, Ethernet, Wi-Fi, Bluetooth, Audio (jack out, 2 PDM port, 1 analog in), serial over USB, and an expansion header. Additionally there is a HDMI port, DSI port, and camera port only on the MT8167 version of the board. The board can be powered by battery and/or via a USB Type-C port and is using a PMIC MT6392. The eMMC and NAND are sharing pins and cannot be used together. This commit is adding the basic boot support for the Pumpkin MT8516 board on the eMMC. Signed-off-by: Fabien Parent <fparent@baylibre.com>
2019-07-18arm: mediatek: add missing arch timer configuration for MT7629Weijie Gao
This patch sets CNTVOFF of ARM CP15 timer to zero to make sure the virtual counter is fully usable for linux kernel. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2019-07-07arm: mediatek: remove arch_misc_initWeijie Gao
The watchdog of mediatek chips is enabled by bootrom before u-boot is running. Previously we choose to enable the wdt driver only to disable the watchdog hardware. Now wdt service is enabled by default. The function arch_misc_init which is only used to disable wdt is no longer needed. Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Ryder Lee <ryder.lee@mediatek.com> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2019-05-18ARM: mediatek: mt8516: use PSCI to reset the SoCFabien Parent
Instead of using the watchdog, let's use PSCI to perform the reset of the SoC. Signed-off-by: Fabien Parent <fparent@baylibre.com>
2019-04-23ARM: MediaTek: Add support for MT8516 SoCFabien Parent
Add support for MediaTek MT8516 SoC. This include the file that will initialize the SoC after boot and its device tree. Signed-off-by: Fabien Parent <fparent@baylibre.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-12-26mt7629: use linux kernel compatible SMP initializationWeijie Gao
This patch changes mt7629 to use the compatible platform SMP initialization method of linux kernel. Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2018-11-28arm: MediaTek: add basic support for MT7623 boardsWeijie Gao
This adds a general board file based on MT7623 SoCs from MediaTek. As this u-boot is loaded by MTK proprietary preloader, there is no low level initializtion codes. Signed-off-by: Weijie Gao <weijie.gao@mediatek.com> Signed-off-by: Ryder Lee <ryder.lee@mediatek.com> Tested-by: Matthias Brugger <matthias.bgg@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-28arm: MediaTek: add basic support for MT7629 boardsRyder Lee
This adds a general board file based on MT7629 SoCs from MediaTek. Apart from the generic parts (cpu) we add some low level init codes and initialize the early clocks. Signed-off-by: Ryder Lee <ryder.lee@mediatek.com> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com> Reviewed-by: Simon Glass <sjg@chromium.org>
