path: root/arch/arm/mach-lpc32xx/clk.c
2020-05-15arm: lpc32xx: move SoC to mach-lpc32xxTrevor Woerner
Following the example of most other SoCs in arch/$(ARCH)/cpu/$(CPU)/$(SOC) move the lpc32xx code from arch/arm/cpu/arm926ejs/lpc32xx to arch/arm/mach-lpc32xx. Following the checklist from commit 01f14456306c ("ARM: prepare for moving SoC sources into mach-*"): [1] move files from arch/arm/cpu/arm926ejs/lpc32xx to arch/arm/mach-lpx32xx [2] add machine entry to arch/arm/Makefile [3] remove "obj-y += ..." from arch/arm/cpu/arm926ejs/Makefile [4] fix the Kconfig file path in arch/arm/Kconfig [5] (no MAINTAINERS update) Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Trevor Woerner <twoerner@gmail.com>
