CONFIG_SYS_NS16550 is required when DM_SERIAL is enabled for
Kirkwood boards.
Signed-off-by: Tony Dinh <mibodhi@gmail.com>
For Kirkwood boards, it is necessary to have early malloc in DRAM area
when Driver Model for Serial is enabled. Please see Michael's patch here:
https://lore.kernel.org/u-boot/20220817193809.1059688-20-michael@walle.cc/
This patch enables the early malloc in DRAM for all Kirkwood boards.
Note that this will work for boards that have either non-DM serial
and DM_SERIAL. Also, add the CONFIG_KIRKWOOD_COMMON option to enable
DM_SERIAL as a common option for boards that have been tested.
Perform a simple rename of CONFIG_SAR_REG to CFG_SAR_REG
Perform a simple rename of CONFIG_I2C_MVTWSI_BASE0 to CFG_I2C_MVTWSI_BASE0
CONFIG_NAND_ECC_BCH
CONFIG_NAND_KIRKWOOD
CONFIG_NAND_KMETER1
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS namespace do
not easily transition to Kconfig. In many cases they likely should come
from the device tree instead. Move these out of CONFIG namespace and in
to CFG namespace.
CONFIG_SYS_TIMER_COUNTS_DOWN
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS_NAND
namespace do not easily transition to Kconfig. In many cases they likely
should come from the device tree instead. Move these out of CONFIG
namespace and in to CFG namespace.
Signed-off-by: Pali Rohár <pali@kernel.org>
If something is wrong with the environment, we cannot rely on a proper
u-boot operation anymore. In fact, it is possible, that we never reach
misc_init_r() with a broken environment.
Also don't enable the netconsole by environment settings. This way the
user don't have to reconfigure the environment. Instead the network
console is only enabled when the push button is pressed during boot.
Signed-off-by: Michael Walle <michael@walle.cc>
The board code needs this to be set. Otherwise, the recovery mechanism
doesn't work. Therefore, select this option automatically with the
board.
If we switch to CONFIG_TIMER, we don't need the legacy timer macros and
functions anymore. Add the proper guards to exclude them from compiling.
Cc: Pali Rohár <pali@kernel.org>
Reviewed-by: Pali Rohár <pali@kernel.org>
Bit 21 in SAR register specifies if TCLK is running at 166 MHz or 200 MHz.
This information is undocumented in public Marvell Kirkwood Functional
Specifications [2], but is available in Linux v3.15 kirkwood code [1].
Commit 8ac303d49f89 ("arm: kirkwood: Do not overwrite CONFIG_SYS_TCLK")
broke support for Marvell 88F6281 SoCs because it was expected that all
those SoCs have TCLK running at 200 MHz as specified in Marvell 88F6281
Hardware Specifications [3].
Fix broken support for 88F6281 by detecting CONFIG_SYS_TCLK from SAR
register, like it was doing Linux v3.15.
[1] - https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/tree/arch/arm/mach-kirkwood/common.c?h=v3.15#n542
[2] - https://web.archive.org/web/20130730091033/http://www.marvell.com/embedded-processors/kirkwood/assets/FS_88F6180_9x_6281_OpenSource.pdf
[3] - https://web.archive.org/web/20120620073511/http://www.marvell.com/embedded-processors/kirkwood/assets/HW_88F6281_OpenSource.pdf
Update by Stefan 2022-08-23:
- Fix compilation error for ds109
Fixes: 8ac303d49f89 ("arm: kirkwood: Do not overwrite CONFIG_SYS_TCLK")
mbus driver is initialized from arch_cpu_init() callback which is called
before relocation. This driver stores lot of functions and structure
pointers into global variables, so it is data position dependent.
Therefore after relocations all pointers are invalid and driver does not
work anymore as all pointers referes to the old memory, which overlaps with
CONFIG_SYS_LOAD_ADDR and ${loadaddr}.
For example U-Boot fuse command crashes if loadaddr memory is cleared or
rewritten by some image loaded by U-Boot load command.
mw.w ${loadaddr} 0x0 10000
fuse read 0 1 2
Fix this issue by removing of all mbus global variables in which are stored
pointers to structures or functions which changes during relocation. And
replace it by direct function calls (not via pointers). With this change
fuse command finally works.
Reviewed-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
CONFIG_KIRKWOOD_EGIGA_INIT
CONFIG_KIRKWOOD_PCIE_INIT
CONFIG_KIRKWOOD_RGMII_PAD_1V8
CONFIG_KM_DISABLE_PCIE
CONFIG_LBA48
CONFIG_SYS_64BIT_LBA
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
The way board/keymile/Kconfig is written protects the options there from
being parsed on non-keymile platforms. We cannot however safely source
this file from multiple locations. This does not manifest as a problem
currently as there are no choice statements inside of this file (nor the
sub-Kconfig files it sources). However, moving some target selection to
one of these files exposes the underlying problem. Rework things so
that we have this file sourced in arch/Kconfig.
Cc: Holger Brunck <holger.brunck@hitachienergy.com>
Reviewed-by: Holger Brunck <holger.brunck@hitachienergy.com>
CONFIG_SYS_FAULT_ECHO_LINK_DOWN
Cc: Ramon Fried <rfried.dev@gmail.com>
CONFIG_RESET_PHY_R
CONFIG_SYS_IDE_MAXBUS
CONFIG_SYS_IDE_MAXDEVICE
CONFIG_SYS_ATA_BASE_ADDR
CONFIG_SYS_ATA_STRIDE
CONFIG_SYS_ATA_DATA_OFFSET
CONFIG_SYS_ATA_REG_OFFSET
CONFIG_SYS_ATA_ALT_OFFSET
CONFIG_SYS_ATA_IDE0_OFFSET
CONFIG_SYS_ATA_IDE1_OFFSET
CONFIG_ATAPI
CONFIG_IDE_RESET
Add Kconfig files for Pogoplug V4 board
Kirkwood uses macros KW_DEFADR_PCI_MEM and KW_DEFADR_PCI_IO for base
address of PCIe mappings. Size of PCIe windows is not defined in any macro
yet, so export them in new KW_DEFADR_PCI_MEM_SIZE and KW_DEFADR_PCI_IO_SIZE
macros.
Kirkwood arch code already maps mbus windows for io and mem, so avoid
calling mvebu_mbus_add_window_by_id() function which would try to do
duplicate window mapping.
Kirkwood PCIe controllers already use "marvell,kirkwood-pcie" DT compatible
string, so mark pci_mvebu.c driver as compatible for it.
CONFIG_SYS_KWD_CONFIG
CONFIG_88F5182
CONFIG_BOARD_IS_OPENRD_BASE
CONFIG_BOARD_IS_OPENRD_CLIENT
CONFIG_BOARD_IS_OPENRD_ULTIMATE
CONFIG_D2NET_V2
CONFIG_FEROCEON
CONFIG_FEROCEON_88FR131
CONFIG_INETSPACE_V2
CONFIG_KW88F6192
CONFIG_KW88F6281
CONFIG_KW88F6702
CONFIG_NET2BIG_V2
CONFIG_NETSPACE_LITE_V2
CONFIG_NETSPACE_MAX_V2
CONFIG_NETSPACE_MINI_V2
CONFIG_NETSPACE_V2
CONFIG_SHEEVA_88SV131
At this point mv-plug-common.h is now only an include of mv-common.h so
remove that indirection.
CONFIG_SYS_ATA_PORT_ADDR is not used in the code anymore. Drop it and use
ATA_PORT_ADDR() locally instead.
Drop CONFIG_IDE_RESET_ROUTINE and CONFIG_IDE_SWAP_IO which are also
unused.
On mvebu this is defined if and only if !ARM64.
Otherwise it is defined for boards with ARCH_MX23, ARCH_TEGRA and
ARCH_ZYNQ, and also for SOC_AR934X (tplink_wdr4300).
Signed-off-by: Marek Behún <marek.behun@nic.cz>
In preparation for moving this option to Kconfig, rename it to be
consistent with other USB EHCI Kconfig options.
CONFIG_SYS_I2C_SPEED
CONFIG_SYS_I2C_SLAVE
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
CONFIG_SYS_I2C_MVTWSI
Config option CONFIG_SYS_TCLK is set by kw88f6281.h and kw88f6192.h files
to correct SOC/platform value. So do not overwrite it in board config
include files.
Kirkwood 88F6180 and 88F6192 uses 166 MHz TCLK and Kirkwood 88F6281 uses
200 MHz TCLK.
It is a pain to have to specify the value 10 in each call. Add a new
dectoul() function and update the code to use it.
It is quite confusing that CONFIG_SYS_I2C selects the legacy I2C and
CONFIG_DM_I2C selects the current I2C. The deadline to migrate I2C is less
than a year away.
Also we want to have a CONFIG_I2C for U-Boot proper just like we have
CONFIG_SPL_I2C for SPL, so we can simplify the Makefile rules.
Rename this symbol so it is clear it is going away.
While this platform has not yet been converted, there is active efforts
to do so. Keep the platform for now.
This reverts commit aa697e6904ba1b3144a46ec642d4695e7c0cdc3e.
These boards have not been converted to CONFIG_DM_USB by the deadline
and is also missing conversion to CONFIG_DM. Remove it
Cc: Gerald Kerma <dreagle@doukki.net>
Cc: Tony Dinh <mibodhi@gmail.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
The mvsata_ide driver was due for DM conversion by v2019.07. As that
has long passed, remove the driver and disable it in the boards which
had enabled it.
No board uses this driver any more: remove it.
Signed-off-by: Harm Berntsen <harm.berntsen@nedap.com>
CC: Gerald Kerma <drEagle@doukki.net>
CC: Stefan Roese <sr@denx.de>
CC: Pantelis Antoniou <panto@antoniou-consulting.com>
Historically, the reset_cpu() function had an `addr` parameter which was
meant to pass in an address of the reset vector location, where the CPU
should reset to. This feature is no longer used anywhere in U-Boot as
all reset_cpu() implementations now ignore the passed value. Generic
code has been added which always calls reset_cpu() with `0` which means
this feature can no longer be used easily anyway.
Over time, many implementations seem to have "misunderstood" the
existence of this parameter as a way to customize/parameterize the reset
(e.g. COLD vs WARM resets). As this is not properly supported, the
code will almost always not do what it is intended to (because all
call-sites just call reset_cpu() with 0).
To avoid confusion and to clean up the codebase from unused left-overs
of the past, remove the `addr` parameter entirely. Code which intends
to support different kinds of resets should be rewritten as a sysreset
driver instead.
This transformation was done with the following coccinelle patch:
expression argvalue;
- reset_cpu(argvalue)
+ reset_cpu()
identifier argname;
type argtype;
- reset_cpu(argtype argname)
+ reset_cpu(void)
Signed-off-by: Harald Seiler <hws@denx.de>
Use CONFIG_IS_ENABLED() macro, which provides more convenient
way to check $(SPL)DM_I2C/$(SPL)DM_I2C_GPIO configs
for both SPL and U-Boot proper.
CONFIG_IS_ENABLED(DM_I2C) expands to:
- 1 if CONFIG_SPL_BUILD is undefined and CONFIG_DM_I2C is set to 'y',
- 1 if CONFIG_SPL_BUILD is defined and CONFIG_SPL_DM_I2C is set to 'y',
- 0 otherwise.
All occurences were replaced automatically using these bash cmds:
$ find . -type f -exec sed -i
's/ifndef CONFIG_DM_I2C/if !CONFIG_IS_ENABLED(DM_I2C)/g' {} +
's/ifdef CONFIG_DM_I2C/if CONFIG_IS_ENABLED(DM_I2C)/g' {} +
's/defined(CONFIG_DM_I2C)/CONFIG_IS_ENABLED(DM_I2C)/g' {} +
's/ifndef CONFIG_DM_I2C_GPIO/if !CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} +
's/ifdef CONFIG_DM_I2C_GPIO/if CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} +
's/defined(CONFIG_DM_I2C_GPIO)/CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} +
Signed-off-by: Igor Opaniuk <igor.opaniuk@foundries.io>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
This board has not been converted to CONFIG_DM_MMC by the deadline of
v2019.04, which is almost two years ago. In addition there are other DM
migrations it is also missing. Remove it.
Cc: Chris Packham <judge.packham@gmail.com>
Acked-by: Chris Packham <judge.packham@gmail.com>
CONFIG_NETCONSOLE
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
The Linux coding style guide (Documentation/process/coding-style.rst)
clearly says:
It's a **mistake** to use typedef for structures and pointers.
Besides, using typedef for structures is annoying when you try to make
headers self-contained.
Let's say you have the following function declaration in a header:
void foo(bd_t *bd);
This is not self-contained since bd_t is not defined.
To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h>
#include <asm/u-boot.h>
void foo(bd_t *bd);
Then, the include direcective pulls in more bloat needlessly.
If you use 'struct bd_info' instead, it is enough to put a forward
declaration as follows:
struct bd_info;
void foo(struct bd_info *bd);
Right, typedef'ing bd_t is a mistake.
I used coccinelle to generate this commit.
The semantic patch that makes this change is as follows:
<smpl>
typedef bd_t;
-bd_t
+struct bd_info
</smpl>
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Move this header out of the common header.
Move this uncommon header out of the common header.
Move this header out of the common header. Network support is used in
quite a few places but it still does not warrant blanket inclusion.
Note that this net.h header itself has quite a lot in it. It could be
split into the driver-mode support, functions, structures, checksumming,
etc.
Have this symbol follow the pattern of all other such symbols.
This patch also removes a TODO from the code.
Reviewed-by: Chris Packham <judge.packham@gmail.com>
Signed-off-by: Trevor Woerner <twoerner@gmail.com>
Move this function out of common.h and into a relevant header file.
