path: root/arch/arm/mach-keystone
2015-08-12ARM: keystone2: Use common definition for clk_get_rateLokesh Vutla
Since all the clocks are defined common, and has the same logic to get the frequencies, use a common definition for for clk_get_rate(). Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-08-12ARM: keystone2: Remove unsed external clocksLokesh Vutla
Remove unused external clocks and make a common definition for all keystone platforms. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-08-12ARM: keystone2: Cleanup init_pll definitionLokesh Vutla
This is just a cosmetic change that makes the calling of pll init code looks much cleaner. Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-08-12ARM: keystone2: Use common structure for PLLsLokesh Vutla
Register Base addresses are same for PLLs in all keystone platforms. If a PLL is not available, the corresponding register addresses are marked as reserved. Hence use a common definition. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-08-12ARM: keystone2: Fix dev and arm speed detectionLokesh Vutla
Use common devspeed and armspeed definitions. Also fix reading efuse bootrom register. Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-08-12ARM: keystone2: Cleanup PLL init codeLokesh Vutla
There are two types of PLL for all keystone platforms: Main PLL, Secondary PLL. Instead of duplicating the same definition for each secondary PLL, have a common function which does initialization for both PLLs. And also add proper register definitions. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-08-12ARM: keystone2: Enable CONFIG_DISPLAY_CPUINFOLokesh Vutla
Add print_cpuinfo() function and enable CONFIG_DISPLAY_CPUINFO for keystone platforms, so that cpu info can be displayed during boot. Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-08-12ARM: keystone2: Cleanup SoC detectionLokesh Vutla
Add proper register definition for JTAG ID and cleanup cpu_is_* functions. Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-07-27keystone2: add wfi in to the core_spin loopVitaly Andrianov
When core A turning of core B, via tetris DPSC it places the core B DPSC into transitional state. The core B has to execute wfi instruction to move its DPSC to the OFF state. This patch add such instruction. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-19keystone2: use correct EFUSE_BOOTROM fileds to configure speedVitaly Andrianov
The get_max_arm_speed() and get_max_dev_speed() used wrong register fields to get the maximum speeds. This commit fixes the bug. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-05-12arch: Make board selection choices optionalJoe Hershberger
By making the board selections optional, every defconfig will include the board selection when running savedefconfig so if a new board is added to the top of the list of choices the former top's defconfig will still be correct. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Cc: Tom Rini <trini@konsulko.com>
2015-02-21ARM: keystone: move SoC headers to mach-keystone/include/machMasahiro Yamada
Move arch/arm/include/asm/arch-keystone/* -> arch/arm/mach-keystone/include/mach/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com>
2015-02-21ARM: keystone: move SoC sources to mach-keystoneMasahiro Yamada
Move arch/arm/cpu/armv7/keystone/* -> arch/arm/mach-keystone/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com>
