path: root/arch/arm/mach-imx/mx8m/soc.c
2019-01-01imx: rename mx8m,MX8M to imx8m,IMX8MPeng Fan
Rename mx8m,MX8M to imx8m,IMX8M Signed-off-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Jon Nettleton <jon@solid-run.com>
2019-01-01imx: mx8m: add memory mapping for CAAM and TCMGary Bisson
Otherwise can't boot the M4 core as it is impossible to load its firmware into the TCM memory. Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com> Reviewed-by: Peng Fan <peng.fan@nxp.com>
2018-02-04imx: mx8m: add soc related settings and filesPeng Fan
Add SoC level initialization code - arch_cpu_init - mmu table - detect cpu revision - reset cpu and wdog settings - timer init - wdog settings - lowlevel init to save/restore registers - a few dummy header file to avoid build failure - ft_system_setup Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com>
