path: root/arch/arm/mach-imx/Kconfig
2019-06-11mx7ulp: Add common plugin codes for mx7ulpYe Li
Add common plugin codes to call ROM's hwcnfg_setup and generate IVT2 header. Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-04-13imx: bootaux: add dependency on vf610Marcel Ziswiler
Allow using bootaux also on VF610 aka Vybrid. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-02-15ddr: vybrid: Provide code to perform on-boot calibrationLukasz Majewski
This patch provides the code to calibrate the DDR's DQS to DQ signals (RDLVL). It is based on: VFxxx Controller Reference Manual, Rev. 0, 10/2016, page 1600 10.1.6.16.4.1 "Software Read Leveling in MC Evaluation Mode" and NXP's community thread: "Vybrid: About DDR leveling feature on DDRMC." https://community.nxp.com/thread/395323 Signed-off-by: Lukasz Majewski <lukma@denx.de>
2018-07-23mx7: Remove BMODE supportFabio Estevam
i.MX7 does not support BMODE due to the erratum e10574 ("Watchdog: A watchdog timeout or software trigger will not reset the SOC"), so remove its support. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-01-08imx: introduce CONFIG_GPT_TIMERStefan Agner
Introduce a new config symbol to select the i.MX General Purpose Timer (GPT). Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-01-08imx: move CONFIG_SYSCOUNTER_TIMER to KconfigStefan Agner
2017-12-29imx: Kconfig: Add HAS_CAAM optionBreno Lima
Currently CONFIG_SECURE_BOOT is selecting FSL_CAAM for all i.MX devices, this causes the following error when building mx6sl boards since this SoC doesn't have the CAAM block: In file included from drivers/crypto/fsl/jobdesc.c:12:0: drivers/crypto/fsl/jobdesc.c: In function 'inline_cnstr_jobdesc_blob_dek': include/fsl_sec.h:268:25: error: 'CAAM_ARB_BASE_ADDR' undeclared (first use in this function) #define SEC_MEM_PAGE1 (CAAM_ARB_BASE_ADDR + 0x1000) ^ drivers/crypto/fsl/jobdesc.c:140:21: note: in expansion of macro 'SEC_MEM_PAGE1' memcpy((uint32_t *)SEC_MEM_PAGE1, (uint32_t *)plain_txt, in_sz); ^ include/fsl_sec.h:268:25: note: each undeclared identifier is reported only once for each function it appears in #define SEC_MEM_PAGE1 (CAAM_ARB_BASE_ADDR + 0x1000) ^ drivers/crypto/fsl/jobdesc.c:140:21: note: in expansion of macro 'SEC_MEM_PAGE1' memcpy((uint32_t *)SEC_MEM_PAGE1, (uint32_t *)plain_txt, in_sz); ^ scripts/Makefile.build:280: recipe for target 'drivers/crypto/fsl/jobdesc.o' failed make[3]: *** [drivers/crypto/fsl/jobdesc.o] Error 1 scripts/Makefile.build:425: recipe for target 'drivers/crypto/fsl' failed make[2]: *** [drivers/crypto/fsl] Error 2 scripts/Makefile.build:425: recipe for target 'drivers/crypto' failed make[1]: *** [drivers/crypto] Error 2 Add HAS_CAAM configuration to avoid this error. Signed-off-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-12-29imx: Add a common way for detecting NXP boards revisionFabio Estevam
NXP development boards based on i.MX6/i.MX7 contain the board revision information stored in the fuses. Introduce a common function that can be shared by different boards and convert mx6sabreauto to use this new mechanism. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
