path: root/arch/arm/mach-at91
2015-08-21arm: at91: add support for mini-box picosam9g45 boardErik van Luijk
Bootlog: U-Boot SPL 2015.10-rc1-00452-g96a7ed1 (Aug 17 2015 - 10:32:21) mci: setting clock 258000 Hz, block size 512 mci: setting clock 258000 Hz, block size 512 mci: setting clock 258000 Hz, block size 512 mci: setting clock 33024000 Hz, block size 512 reading u-boot.img reading u-boot.img U-Boot 2015.10-rc1-00452-g96a7ed1 (Aug 17 2015 - 10:32:21 +0000) CPU: AT91SAM9G45 Crystal frequency: 12 MHz CPU clock : 400 MHz Master clock : 133.333 MHz Watchdog enabled DRAM: 256 MiB WARNING: Caches not enabled MMC: mci: 0 mci: setting clock 260416 Hz, block size 512 mci: setting clock 260416 Hz, block size 512 mci: setting clock 260416 Hz, block size 512 mci: setting clock 33333333 Hz, block size 512 reading uboot.env In: serial Out: serial Err: serial Net: macb0 Error: macb0 address not set. Hit any key to stop autoboot: 0 U-Boot> Signed-off-by: Erik van Luijk <evanluijk@interact.nl> [add 'picosam9g45_defconfig' to MAINTAINERS] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-08-21arm: at91: pmc: replace the constant with a define in at91_pmc.hErik van Luijk
To enable the clocks on the at91 boards a constant (0x4) is used. This is replaced with a define in at91_pmc.h (1 << 2). Signed-off-by: Erik van Luijk <evanluijk@interact.nl> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-08-21arm: at91: mpddr: allow multiple DDR controllersErik van Luijk
The mpddr.c depends on ATMEL_BASE_MPDDRC for the base address to configure the controller. This cannot be used when there is more than one controller (i.e. AT91SAM9G45, AT91SAM9M10). Signed-off-by: Erik van Luijk <evanluijk@interact.nl> [remove 'new blank line at EOF'] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-08-12arm, at91: support for sam9260 based smartweb boardHeiko Schocher
add support for the at91sam9260 based board smartweb from siemens. SPL is used without serial support, as this SoC has only 4k sram for running SPL. Here a U-Boot bootlog: RomBOOT > U-Boot 2015.07-rc2-00109-g4ae828c (Jun 15 2015 - 09:31:16 +0200) CPU: AT91SAM9260 Crystal frequency: 18.432 MHz CPU clock : 198.656 MHz Master clock : 99.328 MHz Watchdog enabled DRAM: 64 MiB WARNING: Caches not enabled NAND: 256 MiB In: serial Out: serial Err: serial Net: macb0 Hit any key to stop autoboot: 0 U-Boot> Signed-off-by: Heiko Schocher <hs@denx.de>
2015-08-12spl, common, serial: build SPL without serial supportHeiko Schocher
This patch enables building SPL without CONFIG_SPL_SERIAL_SUPPORT support. Signed-off-by: Heiko Schocher <hs@denx.de> [trini: Ensure we build arch/arm/imx-common on mx28] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-05-13ARM: at91: remove non-generic boardsMasahiro Yamada
Remove board support for afeb9260, tny_a9260, and sbc35_a9g20. They have not been converted into Generic Board yet. See doc/README.generic-board for details. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2015-05-12arch: Make board selection choices optionalJoe Hershberger
By making the board selections optional, every defconfig will include the board selection when running savedefconfig so if a new board is added to the top of the list of choices the former top's defconfig will still be correct. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Cc: Tom Rini <trini@konsulko.com>
2015-04-18ARM: snapper9260: use "select" instead of default value in defconfigMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-01ARM: atmel: at91sam9n12ek: enable spl supportBo Shen
Enable SPL support for at91sam9n12ek boards, now it supports boot up from NAND flash, serial flash. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-04-01ARM: atmel: at91sam9x5ek: enable spl supportBo Shen
Enable SPL support for at91sam9x5ek board. Now, it supports boot up from NAND flash and SPI flash. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-04-01ARM: atmel: at91sam9m10g45ek: enable spl supportBo Shen
Supports boot up from NAND flash with software ECC eanbled. And supports boot up from SD/MMC card with FAT file system. As the boot from SD/MMC card with FAT file system, the BSS segment is too big to fit into SRAM, so, use the lds to put it into SDRAM. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-04-01ARM: atmel: arm926ejs: fix clock configurationBo Shen
Config MCKR according to the datasheet sequence, or else it will cause the MCKR configuration failed. Remove timeout checking for clock configuration, if configure the clock failed, let the system hang while not run in wrong clock configuration. Signed-off-by: Bo Shen <voice.shen@atmel.com> Tested-by: Heiko Schocher <hs@denx.de>
2015-04-01spl_atmel.c: Switch s_init to board_init_fTom Rini
To facilitate changing lowlevel_init to become s_init, move the current contents of s_init into board_init_f and add the rest of what board_init_f does here. In order to compile clean without CONFIG_SKIP_LOWLEVEL_INIT set, leave an empty stub of s_init(). It can be removed when lowlevel_init becomes s_init. Cc: Bo Shen <voice.shen@atmel.com> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Tested-by: Matt Porter <mporter@konsulko.com> on sama5d3_xplained Signed-off-by: Tom Rini <trini@ti.com> [rebased on current master, leave s_init() as empty stub] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-04-01ARM: atmel: armv7: switch to use common timer functionsBo Shen
The commit 8dfafdd (Introduce common timer functions), add common timer functions, we can use them directly. Signed-off-by: Bo Shen <voice.shen@atmel.com> [rebase on current master] Sigend-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-04-01ARM: atmel: arm9: switch to use common timer functionsBo Shen
Signed-off-by: Bo Shen <voice.shen@atmel.com> [rebase on current master] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-03-18ARM: atmel: sama5d4: set non-secured for peripheralsBo Shen
When access the programmable secure peripherals address space, it needs set them to non-secured. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-03-18ARM: atmel: armv7: move spl lds to armv7 directoryBo Shen
As the u-boot-spl.lds is used only for armv7 SoCs (includes sama5d3 and sama5d4), so move it to armv7 directory. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-03-18ARM: at91: at91sam9rlek: add mci supportWu, Josh
This patch enable the MCI support for at91sam9rlek board. Signed-off-by: Josh Wu <josh.wu@atmel.com> [rebase on ToT] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-02-21ARM: at91: move SoC headers to mach-at91/include/machMasahiro Yamada
Move arch/arm/include/asm/arch-at91/* -> arch/arm/mach-at91/include/mach/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-02-21ARM: at91: collect SoC sources into mach-at91Masahiro Yamada
This commit moves source files as follows: arch/arm/cpu/arm920t/at91/* -> arch/arm/mach-at91/arm920t/* arch/arm/cpu/arm926ejs/at91/* -> arch/arm/mach-at91/arm926ejs/* arch/arm/cpu/armv7/at91/* -> arch/arm/mach-at91/armv7/* arch/arm/cpu/at91-common/* -> arch/arm/mach-at91/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.co>
