path: root/arch/arm/mach-at91/Makefile
2019-10-08ARM: at91: sfr: convert to KconfigEugen Hristev
This converts the at91 sfr to Kconfig Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-05-07arm: v7: Kconfig: Rename CPU_V7 as CPU_V7ALokesh Vutla
Currently CPU_V7 kconfig symbol supports only ARMv7A architectures under armv7 folder. This led to a misconception of creating separate folders for armv7m and armv7r. There is no reason to create separate folder for other armv7 based architectures when it can co-exist with few Kconfig symbols. As a first step towards a common folder, rename CPU_V7 as CPUV7A. Later separate Kconfig symbols can be added for CPU_V7R and CPU_V7M and can co exist in the same folder. Reviewed-by: Tom Rini <trini@konsulko.com> Tested-by: Michal Simek <michal.simek@xilinx.com> Suggested-by: Alexander Graf <agraf@suse.de> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-06-12ARM: at91: sama5: Extend boot device autodetectionMarek Vasut
Extend the boot device autodetection from SAMA5D2 only to the entire SAMA5Dx family of microcontrollers. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas@biessmann.org> [minor compile fix for SAMA5D2] Signed-off-by: Andreas Bießmann <andreas@biessmann.org>
2016-05-24ARM: sama5d2: Implement boot device autodetectionMarek Vasut
Implement support for saving ARM register R4 early during boot using save_boot_params . Implement support for decoding the stored register R4 value in spl_boot_device() to obtain boot device from which the SoC booted. This way, the SPL will always load U-Boot from the same device from which the SPL itself booted instead of using hard-coded boot device. This functionality is useful for example when booting sama5d2-xplained from SD card, where by default the SPL would try loading the U-Boot from eMMC and fail. This is because eMMC is on SDHCI0 (BOOT_DEVICE_MMC1), while SD slot is on SDHCI1 (BOOT_DEVICE_MMC2) and the SPL was hard-wired to always boot from BOOT_DEVICE_MMC1. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
2016-02-18ARM: at91: clock: add a new file to handle clockWenyou Yang
To reduce the duplicated code, add a new file to accommodate the peripheral's and system's clock handle code, shared with the SoCs with different ARM core. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Tested-by: Heiko Schocher <hs@denx.de> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-02-02board: atmel: sama5d2_xplained: add SPL supportWenyou Yang
The sama5d2 Xplained SPL supports the boot medias: spi flash and SD Card. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-11-30arm: at91/spl: atmel_sfr: move saic redirect to separate fileWenyou Yang
To make saic redirect code sharing with other SoCs, move the saic redirect code from SAMA5D4 particular file, mach-at91/armv7/sama5d4_devices.c to a separate file, mach-at91/atmel_sfr.c Move ATMEL_SFR_AICREDIR_KEY definition to sama5d4.h, because each SoC has its own value. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-11-30arm: at91/spl: matrix: move matrix init to separate fileWenyou Yang
To make the matrix initialization code sharing with other SoCs, move it from SAMA5D4 particular file, mach-at91/armv7/sama5d4_devices.c to a separate file, mach-at91/matrix.c Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-11-10Various Makefiles: Add SPDX-License-Identifier tagsTom Rini
After consulting with some of the SPDX team, the conclusion is that Makefiles are worth adding SPDX-License-Identifier tags too, and most of ours have one. This adds tags to ones that lack them and converts a few that had full (or in one case, very partial) license blobs into the equivalent tag. Cc: Kate Stewart <kstewart@linuxfoundation.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-12arm, at91: support for sam9260 based smartweb boardHeiko Schocher
add support for the at91sam9260 based board smartweb from siemens. SPL is used without serial support, as this SoC has only 4k sram for running SPL. Here a U-Boot bootlog: RomBOOT > U-Boot 2015.07-rc2-00109-g4ae828c (Jun 15 2015 - 09:31:16 +0200) CPU: AT91SAM9260 Crystal frequency: 18.432 MHz CPU clock : 198.656 MHz Master clock : 99.328 MHz Watchdog enabled DRAM: 64 MiB WARNING: Caches not enabled NAND: 256 MiB In: serial Out: serial Err: serial Net: macb0 Hit any key to stop autoboot: 0 U-Boot> Signed-off-by: Heiko Schocher <hs@denx.de>
2015-04-01ARM: atmel: at91sam9n12ek: enable spl supportBo Shen
Enable SPL support for at91sam9n12ek boards, now it supports boot up from NAND flash, serial flash. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-04-01ARM: atmel: at91sam9x5ek: enable spl supportBo Shen
Enable SPL support for at91sam9x5ek board. Now, it supports boot up from NAND flash and SPI flash. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-02-21ARM: at91: collect SoC sources into mach-at91Masahiro Yamada
This commit moves source files as follows: arch/arm/cpu/arm920t/at91/* -> arch/arm/mach-at91/arm920t/* arch/arm/cpu/arm926ejs/at91/* -> arch/arm/mach-at91/arm926ejs/* arch/arm/cpu/armv7/at91/* -> arch/arm/mach-at91/armv7/* arch/arm/cpu/at91-common/* -> arch/arm/mach-at91/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.co>
