path: root/arch/arm/mach-aspeed
2018-05-07regmap: change regmap_init_mem() to take ofnode instead udeviceMasahiro Yamada
Currently, regmap_init_mem() takes a udevice. This requires the node has already been associated with a device. It prevents syscon/regmap from behaving like those in Linux. Change the first argumenet to take a device node. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08aspeed: Refactor SCU to use consistent mask & shiftmaxims@google.com
Refactor SCU header to use consistent Mask & Shift values. Now, consistently, to read value from SCU register, mask needs to be applied before shift. Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08aspeed: Refactor AST2500 RAM Driver and Sysreset Drivermaxims@google.com
This change switches all existing users of ast2500 Watchdog to Driver Model based Watchdog driver. To perform system reset Sysreset Driver uses first Watchdog device found via uclass_first_device call. Since the system is going to be reset anyway it does not make much difference which watchdog is used. Instead of using Watchdog to reset itself, SDRAM driver now uses Reset driver to do that. These were the only users of the old Watchdog API, so that API is removed. This all is done in one change to avoid having to maintain dual API for watchdog in between. Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08aspeed: Make SCU lock/unlock functions part of SCU APImaxims@google.com
Make functions for locking and unlocking SCU part of SCU API. Many drivers need to modify settings in SCU and thus need to unlock it first. This change makes it possible. Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08aspeed: Watchdog Timer Drivermaxims@google.com
This driver supports ast2500 and ast2400 SoCs. Only ast2500 supports reset_mask and thus the option of resettting individual peripherals using WDT. Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-28aspeed: Support for ast2500 Eval Boardmaxims@google.com
ast2500 Eval Board device tree and board specific configuration. Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-28aspeed: Board init functions and common configs for ast2500 based boardsmaxims@google.com
Add configuration file with parameters that are very likely to be shared by all ast2500-based boards. Add ast2500-board.c file with the init code that is very likely to be shared by all ast2500-based boards. Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-28aspeed: Add basic ast2500-specific drivers and configurationmaxims@google.com
Clock Driver This driver is ast2500-specific and is not compatible with earlier versions of this chip. The differences are not that big, but they are in somewhat random places, so making it compatible with ast2400 is not worth the effort at the moment. SDRAM MC driver The driver is very ast2500-specific and is completely incompatible with previous versions of the chip. The memory controller is very poorly documented by Aspeed in the datasheet, with any mention of the whole range of registers missing. The initialization procedure has been basically taken from Aspeed SDK, where it is implemented in assembly. Here it is rewritten in C, with very limited understanding of what exactly it is doing. Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-28aspeed: Add drivers common to all Aspeed SoCsmaxims@google.com
Add support for Watchdog Timer, which is compatible with AST2400 and AST2500 watchdogs. There is no uclass for Watchdog yet, so the driver does not follow the driver model. It also uses fixed clock, so no clock driver is needed. Add support for timer for Aspeed ast2400/ast2500 devices. The driver actually controls several devices, but because all devices share the same Control Register, it is somewhat difficult to completely decouple them. Since only one timer is needed at the moment, this should be OK. The timer uses fixed clock, so does not rely on a clock driver. Add sysreset driver, which uses watchdog timer to do resets and particular watchdog device to use is hardcoded (0) Reviewed-by: Simon Glass <sjg@chromium.org>
