path: root/arch/arm/lib
2020-05-18common: Drop asm/ptrace.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop init.h from common headerSimon Glass
2020-05-18common: Drop image.h from common headerSimon Glass
2020-05-18common: Drop bootstage.h from common headerSimon Glass
Move this fairly uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-07cmd: cache: Fix non-cached memory cachabilityPatrice Chotard
If dcache is switched OFF to ON state and if non-cached memory is used, this non-cached memory must be re-declared as uncached to mmu each time dcache is set ON. Introduce noncached_set_region() to set this non-cached region's mmu settings. Let architecture override it by defining it as a weak function. For ARM architecture, noncached_set_region() defines all noncached region as non-cacheable. Issue found on STM32MP1 platform using dwc_eth_qos ethernet driver, when going from dcache OFF to dcache ON state, ethernet driver issued TX timeout errors when performing dhcp or ping. It can be reproduced with the following sequence: dhcp while true ; do ping 192.168.1.300 ; dcache off ; ping 192.168.1.300 ; dcache on ; done Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Cc: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Ramon Fried <rfried.dev@gmail.com> Cc: Stephen Warren <swarren@nvidia.com> Reviewed-by: Marek Vasut <marex@denx.de>
2020-05-04Merge tag 'u-boot-imx-20200502' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-imx i.MX for 2020.07 ---------------- - imxrt: fix LCD clock, fix doc - new board: Coral Dev - imx8: enable Cache in SPL. SNVS, update SCFW API - imx8MM: fix reset, 8MQ quand and QuadLite, CPU speed grading - MX6ULL : is_imx6ull to include i.MX6ULZ - Net: add config to enable TXC delay Travis: https://travis-ci.org/github/sbabic/u-boot-imx/builds/682033914
2020-05-01common/board_r: arm: Merge initr_enable_interrupts into interrupts_initOvidiu Panait
initr_enable_interrupts() is an ARM-specific wrapper over enable_interrupts(), which is run during the common init sequence. It can be eliminated by moving the enable_interrupts() call to the end of interrupt_init() function, in arch/arm/lib/interrupts*.c. Signed-off-by: Ovidiu Panait <ovpanait@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-05-01arm: caches: manage phys_addr_t overflow in mmu_set_region_dcache_behaviourPatrick Delaunay
Solved the overflow on phys_addr_t type for start + size in mmu_set_region_dcache_behaviour() function. This overflow is avoided by dividing start and end by 2 before addition, and we only expecting that start and size are even. This patch doesn't change the current function behavior if the parameters (start or size) are not aligned on MMU_SECTION_SIZE. For example, this overflow occurs on ARM32 with: start = 0xC0000000 and size = 0x40000000 then start + size = 0x100000000 and end = 0x0. For information the function behavior change with risk of regression, if we just shift start and size before the addition. Example with 2MB section size: MMU_SECTION_SIZE 0x200000 and MMU_SECTION_SHIFT = 21 with start = 0x1000000, size = 0x1000000, - with the proposed patch, start = 0 and end = 0x1 as previously - with the more simple patch: end = (start >> MMU_SECTION_SHIFT) + (size >> MMU_SECTION_SHIFT) the value of end change: start >> 21 = 0, size >> 21 = 0 and end = 0x0 !!! Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-05-01arm: caches: add DCACHE_DEFAULT_OPTIONPatrick Delaunay
Add the new flags DCACHE_DEFAULT_OPTION to define the default option to use according the compilation flags CONFIG_SYS_ARM_CACHE_*. This new compilation flag allows to simplify dram_bank_mmu_setup() and can be used as third parameter (option=dcache option to select) of mmu_set_region_dcache_behaviour function. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-05-01arm: caches: protect dram_bank_mmu_setup access to bi_dramPatrick Delaunay
Add protection in dram_bank_mmu_setup() to avoid access to bd->bi_dram before relocation. This patch allow to use the generic weak function dram_bank_mmu_setup to activate the MMU and the data cache in SPL or in U-Boot before relocation, when bd->bi_dram is not yet initialized. In this cases, the MMU must be initialized explicitly with mmu_set_region_dcache_behaviour function. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-05-01ARM: reset: use do_reset in SPL/TPL if SYSRESET was not enabled for themClaudius Heine
In case CONFIG_SYSRESET is set, do_reset from reset.c will not be available anywere, even if SYSRESET is disabled for SPL/TPL. 'do_reset' is called from SPL for instance from the panic handler and PANIC_HANG is not set Signed-off-by: Claudius Heine <ch@denx.de> Reviewed-by: Marek Vasut <marex@denx.de>
2020-04-24common/board_f: Make reserve_mmu genericOvidiu Panait
Introduce arch_reserve_mmu to allow for architecture-specific reserve_mmu routines. Also, define a weak nop stub for it. Signed-off-by: Ovidiu Panait <ovpanait@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-24arm: asm/cache.c: Introduce arm_reserve_mmuOvidiu Panait
As a preparation for turning reserve_mmu into an arch-specific variant, introduce arm_reserve_mmu on ARM. It implements the default routine for reserving memory for MMU TLB and needs to be weakly defined in order to allow for machines to override it. Without this decoupling, after introducing arch_reserve_mmu, there would be two weak definitions for it, one in common/board_f.c and one in arch/arm/lib/cache.c. Signed-off-by: Ovidiu Panait <ovpanait@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-24common/board_f: Move arm-specific reserve_mmu to arch/arm/lib/cache.cOvidiu Panait
Move the ARM-specific reserve_mmu definition from common/board_f.c to arch/arm/lib/cache.c. Signed-off-by: Ovidiu Panait <ovpanait@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-17ARM: bootm: take into account gd->ram_topPatrice Chotard
If gd->ram_top has been tuned using board_get_usable_ram_top(), it must be taken into account when reserving arch lmb. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Patrick DELAUNAY <patrick.delaunay@st.com> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-04-16arm: set the relocated gd with gd->new_gdPatrick Delaunay
Simplify the arm relocation behavior and get gd directly form new_gd, as it is already done in crt0_64.S: ldr x18, [x18, #GD_NEW_GD] /* x18 <- gd->new_gd */ This patch avoid assumption on new GD location (new GD is below bd - with #GD_SIZE offset). Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-02-25arch: arm: Fix SZ_64K undeclared compilation errorWasim Khan
Macro SZ_64K is undeclared. Include sizes.h to fix the compilation error. Signed-off-by: Wasim Khan <wasim.khan@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-01-17common: Move hang() to the same header as panic()Simon Glass
At present panic() is in the vsprintf.h header file. That does not seem like an obvious choice for hang(), even though it relates to panic(). So let's put hang() in its own header. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Migrate a few more files] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-01-17common: Move reset_cpu() to the CPU headerSimon Glass
Move this function out of common.h and into a relevant header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17common: Move relocate_code() to init.hSimon Glass
This is an init function so move it out of the common header. Avoid using the typedef so that we don't have to include the global_data header file. Also tidy up the function style in comments while we are here. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-10arch: arm: Program GIC LPI configuration tableBharat Kumar Reddy Gooty
Programs the following: 1. Redistributor PROCBASER configuration table (which is common for all redistributors) 2. Redistributor pending table (PENDBASER), for all the available redistributors. Signed-off-by: Bharat Kumar Reddy Gooty <bharat.gooty@broadcom.com> Signed-off-by: Vladimir Olovyannikov <vladimir.olovyannikov@broadcom.com>
2019-12-02common: Move enable/disable_interrupts out of common.hSimon Glass
Move these two functions into the irq_funcs.h header file. Also move interrupt_handler_t as this is used by the irq_install_handler() function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move interrupt functions into a new headerSimon Glass
These functions do not use driver model but are fairly widely used in U-Boot. But it is not clear that they will use driver model anytime soon, so we don't want to label them as 'legacy'. Move them to a new irq_func.h header file. Avoid the name 'irq.h' since it is widely used in U-Boot already. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02arm: powerpc: Tidy up code style for interrupt functionsSimon Glass
Remove the unwanted space before the bracket. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move ARM cache operations out of common.hSimon Glass
These functions are CPU-related and do not use driver model. Move them to cpu_func.h Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move some cache and MMU functions out of common.hSimon Glass
These functions belong in cpu_func.h. Another option would be cache.h but that code uses driver model and we have not moved these cache functions to use driver model. Since they are CPU-related it seems reasonable to put them here. Move them over. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02arm: powerpc: Tidy up code style for cache functionsSimon Glass
2019-12-02common: Move some SMP functions out of common.hSimon Glass
These functions belong in cpu_func.h so move them over. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-11-17spl: separate SPL_FRAMEWORK config for spl and tplHeiko Stuebner
Right now enabling SPL_FRAMEWORK will also enable it for the TPL in all cases, making the TPL bigger. There may be cases where the TPL is really size constrained due to its underlying ram size. Therefore introduce a new TPL_FRAMEWORK option and make the relevant conditionals check for both. The default is set to "y if SPL_FRAMEWORK" to mimic the previous behaviour where the TPL would always get the SPL framework if it was enabled in SPL. Signed-off-by: Heiko Stuebner <heiko.stuebner@theobroma-systems.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-07arm: caches: Disable mmu only if mmu is availableLokesh Vutla
As part of disabling caches MMU as well gets disabled. But MMU is not available on all armv7 cores like R5F. So disable MMU only if it is available. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-10-25boot: arm: Enable support for custom board_prep_linuxLokesh Vutla
Once the arch specific boot_prepare_linux completes, boards wants to have a custom preparation for linux. Add support for a custom board_prep_linux. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-10-11arm64: print instructions leading to exceptionHeinrich Schuchardt
If an exception occurs in a loaded image and the relocation offset is unknown, it is helpful to know the instructions pointed to by the program counter. This patch adds the missing output. A possible output is: Code: 910c4021 aa1303e0 f9400662 d63f0040 (e7f7defb) The parentheses indicate the instruction causing the exception. The output can be disassembled using scripts/decodecode: echo 'Code: 90000360 9100b800 94002782 17ffff8f (e7f7defb)' | \ ARCH=arm64 scripts/decodecode Code: 90000360 9100b800 94002782 17ffff8f (e7f7defb) All code ======== 0: 90000360 adrp x0, 0x6c000 4: 9100b800 add x0, x0, #0x2e 8: 94002782 bl 0x9e10 c: 17ffff8f b 0xfffffffffffffe48 10:* e7f7defb .inst 0xe7f7defb ; undefined <-- trapping instruction Code starting with the faulting instruction =========================================== 0: e7f7defb .inst 0xe7f7defb ; undefined We already have implemented the same for armv7. For testing command 'exception undefined' can be used. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-08-30board_f: fix noncached reservation calculationStephen Warren
The current code in reserve_noncached() has two issues: 1) The first update of gd->start_addr_sp always rounds down to a section start. However, the equivalent calculation in cache.c:noncached_init() always first rounds up to a section start, then subtracts a section size. These two calculations differ if the initial value is already rounded to section alignment. 2) The second update of gd->start_addr_sp subtracts exactly CONFIG_SYS_NONCACHED_MEMORY, whereas the equivalent calculation in cache.c:noncached_init() rounds the noncached size up to section alignment before subtracting it. The two calculations differ if the noncached region size is not a multiple of the MMU section size. In practice, one/both of those issues causes a practical problem on Jetson TX1; U-Boot triggers a synchronous abort during initialization, likely due to overlapping use of some memory region. This change fixes both these issues by duplicating the exact calculations from noncached_init() into reserve_noncached(). However, this fix assumes that gd->start_addr_sp on entry to reserve_noncached() exactly matches mem_malloc_start on entry to noncached_init(). I haven't traced the code to see whether it absolutely guarantees this in all (or indeed any!) cases. Consequently, I added some comments in the hope that this condition will continue to be true. Fixes: 5f7adb5b1c02 ("board_f: reserve noncached space below malloc area") Cc: Vikas Manocha <vikas.manocha@st.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2019-08-11env: Move env_get() to env.hSimon Glass
Move env_get() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-07-23Merge tag 'efi-2019-10-rc1-2' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-efi Pull request for UEFI sub-system for v2019.10-rc1 (2) * Implement the EVT_SIGNAL_VIRTUAL_ADDRESS_CHANGE event. * Address errors of type -Werror=address-of-packed-member when building with GCC9.1 * Fix an error when adding memory add addres 0x00000000. * Rework some code comments for Sphinx compliance.
2019-07-17spl: Allow performing BSS init early before board_init_f()Andreas Dannenberg
On some platform we have sufficient memory available early on to allow setting up and using a basic BSS prior to entering board_init_f(). Doing so can for example be used to carry state over to board_init_r() without having to resort to extending U-Boot's global data structure. To support such scenarios add a Kconfig option called CONFIG_SPL_EARLY_BSS to allow moving the initialization of BSS prior to entering board_init_f(), if enabled. Note that using this option usually should go along with using CONFIG_SPL_SEPARATE_BSS and configuring BSS to be located in memory actually available prior to board_init_f(). Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
2019-07-16efi_loader: use predefined constants in crt0_*_efi.SHeinrich Schuchardt
We should use predefined constants instead of magic numbers. Move some constant definitions from include/pe.h to include/asm-generic/pe.h. Use these constants in crt0_*_efi.S. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-07-10arm64: add an option to switch visibility of CONFIG_SYS_INIT_SP_BSS_OFFSETMasahiro Yamada
By default, CONFIG_SYS_INIT_SP_BSS_OFFSET was made invisible by not giving a prompt to it. The only way to define it is to hard-code an extra entry in SoC/board Kconfig, like arch/arm/mach-tegra/tegra{186,210}/Kconfig. Add a prompt to it in order to allow defconfig files to specify the value of CONFIG_SYS_INIT_SP_BSS_OFFSET. With this, CONFIG_SYS_INIT_SP_BSS_OFFSET would become always visible. So, we need a new bool option to turn it off by default. I move the 'default 524288' to the common place. This value is not too big, but is big enough to avoid the overwrap of DT in most platforms. If 512KB is not a suitable choice for your platform, you can change it from your defconfig or menuconfig etc. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2019-05-18CONFIG_SPL_SYS_[DI]CACHE_OFF: addTrevor Woerner
While converting CONFIG_SYS_[DI]CACHE_OFF to Kconfig, there are instances where these configuration items are conditional on SPL. This commit adds SPL variants of these configuration items, uses CONFIG_IS_ENABLED(), and updates the configurations as required. Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Make the default depend on the setting for full U-Boot, update more zynq hardware] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-09arm: zimage: add barebox image magic numberChristoph Fritz
For chainboot configurations or test environments, this patch allows booting barebox images by using command bootz. Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com>
2019-05-08arm: add a separate stack for TPLKever Yang
TPL stack may different from SPL and sys stack, add support for separate one when the board defines it. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-05-08arm: remove ARCH_ROCKCHIP macro in common codeKever Yang
This is fix to: e2a12f590d rockchip: use 'arch-rockchip' as header file path The V2 of origin patch set has fix this, but we merge V1 by mistake, so lets correct it. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-05-01rockchip: arm: use 'arch-rockchip' for common headerKever Yang
rockchip platform header file is in 'arch-rockchip' instead of arch-$(SOC) for all SoCs. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-04-22arm: arm64 32bit address relocationIbai Erkiaga
Current relocation code is limited to 21bit PC-relative addressing which might not be enough for bigger code sizes. The following patch increases the addressing to 32bit PC-relative. This feature is specially interesting if U-Boot is build without optimiation (-O0) as the text section is increased significativelly. Signed-off-by: Ibai Erkiaga <ibai.erkiaga-elorza@xilinx.com>
2019-04-12arm: print information about loaded UEFI imagesHeinrich Schuchardt
If an exception occurs in a UEFI loaded image we need the start address of the image to determine the relocation offset. This patch adds the necessary lines after the registers in the crash dump for armv8. A possible output would be: UEFI image [0x00000000bffe6000:0x00000000bffe631f] pc=0x138 '/\snp.efi' With the offset 0x138 we can now find the relevant instruction in the disassembled 'snp.efi' binary. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-03-22arm: lib: bootm: Push the Starting kernel print to the endKeerthy
Push the Starting kernel print to the end just before the dm_remove_devices call. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-02-28ARM: cache: Fix incorrect bitwise operationMarek Vasut
The loop implemented in the code is supposed to check whether the PL310 operation register has any bit from the mask set. Currently, the code checks whether the PL310 operation register has any bit set AND whether the mask is non-zero, which is incorrect. Fix the conditional. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dalon Westergreen <dwesterg@gmail.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Tom Rini <trini@konsulko.com> Fixes: 93bc21930a1b ("armv7: add PL310 support to u-boot") Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Dinh Nguyen <dinguyen@kernel.org>
