path: root/arch/arm/lib
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-13armv8: TPL_STACK will always be defined, so test CONFIG_TPL_NEEDS_SEPARATE_STACKPhilipp Tomsich
Now that TPL_STACK has been moved off the whitelist (ok, I'm lying: the 'moving off the whitelist' part comes in once moveconfig runs... which will be a few commits down the line) and added to Kconfig, we need to test CONFIG_TPL_NEEDS_SEPARATE_STACK to see whether the value from TPL_STACK should be used or whether we try to inherit whatever SPL uses. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13armv8: spl: Support separate stack for TPLPhilipp Tomsich
To allow a TPL and SPL to run from different addresses/memories, we need to split setup of the TPL and SPL stacks. To do so, we introduce CONFIG_TPL_STACK (not listed in Kconfig) which can be used to override the initial stack pointer for TPL. To provide backward compatibility for existing boards, this is added as an optional configuration item and the normal search order (i.e. SPL_STACK, then SYS_STACK) apply if not defined. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-29Revert "armv7m: Disable D-cache when booting nommu(ARMv7M) Linux kernel"Tom Rini
The author of the commit discovered later on that this was already being done in cleanup_before_linux() on arch/arm/cpu/armv7m/cpu.c. This reverts commit 8f079cccb369995e46a2ab530d5d60b88c1e70bb. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-12ARM: provide a valid exception stack address for startup codeLothar Waßmann
Create exception stack in IRAM if available to facilitate debugging of pre-relocation code by catching exceptions rather than stopping dead. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
2017-06-12arm: adjust PC displayed in exception handlers to point to the failing ↵Lothar Waßmann
instruction Adjust the program counter register to point to the failing instruction depending on the exeption type. This makes it easier to localize the offending instruction leading to a fatal exception. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
2017-06-12ARM: remove bogus cp_delay() functionLothar Waßmann
The cp_delay() function was introduced because of a missing 'volatile' attribute to the 'asm' statement in get_cr() which led to the 'mrc' instruction in get_cr() being optimised out eventually. This has been fixed in commit 53fd4b8c22bb ("arm: mmu: Add missing volatile for reading SCTLR register") but the bogus cp_delay() function which was introduced as a workaround for the malfunctioning get_cr() was never removed. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
2017-06-10Merge git://git.denx.de/u-boot-dmTom Rini
2017-06-09armv7m: Disable D-cache when booting nommu(ARMv7M) Linux kerneltnishinaga.dev@gmail.com
Disable D-Cache is required when booting nommu Linux kernel. (please see Linux kernel source "arch/arm/kernel/head-nommu.S") U-Boot is enabled D-cache and I-Cache at startup. However, it does not disable D-Cache before booting nommu Linux kernel. Therefore, I call dcache_disable() when the CPU is ARMv7M to fix this problem. Signed-off-by: Toshifumi NISHINAGA <tnishinaga.dev@gmail.com>
2017-06-09arm: Disable LPAE if not enabledSimon Glass
If CONFIG_ARMV7_LPAE is not defined we should make sure that the feature is disabled. This can happen if U-Boot is chain-loaded from another boot loader which does enable LPAE. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-09arm: Don't try to support CONFIG_ARMV7_LPAE on ARMv4TSimon Glass
At present if CONFIG_ARMV7_LPAE is defined then mmu_setup() will use instructions which are invalid on ARMv4T. This happens on Tegra since it has an ARMv4T boot CPU. Add a check for the architecture version to allow the code to be built. It will not actually be executed by the boot CPU, but needs to compile. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-09arm: Rename HCTR to HTCRSimon Glass
This appears to be a typo. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-05arm: Add Kconfig symbols used for Linux asm compatibilityPhil Edworthy
Rather than change asm files that come from Linux, add the symbols to Kconfig. Since one of the symbols is for thumb2 builds, make CPU_V7M always select them. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com>
2017-06-05arm: Add declarations to avoid needing to include headersSimon Glass
At present common.h includes various ARM-specific headers. In preparation for dropping this, add a few explicit declarations. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-05arm: Add explicit include of <asm/mach-types.h>Simon Glass
Rather than relying on common.h to provide this include, which is going away at some point, include it explicitly in each file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-01dm: Use dm.h header when driver mode is usedSimon Glass
This header includes things that are needed to make driver build. Adjust existing users to include that always, even if other dm/ includes are present Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-17armv8: fsl: move ccn504 code into FSL MakefileAndre Przywara
The generic ARMv8 assembly code contains routines for setting up a CCN interconnect, though the Freescale SoCs are the only user. Link this code only for Freescale targets, this saves some precious bytes in the chronically tight SPL. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2017-05-17armv8: SPL: only compile GIC code if neededAndre Przywara
Not every SoC needs to set up the GIC interrupt controller, so link think code only when the respective config option is set. This shaves off some bytes from the SPL code size. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-05-11spl: fdt: support for fdt fixup for falcon bootB, Ravi
Adding support for fdt fixup to update the memory node in device tree for falcon boot. This is needed for single stage or falcon bootmode, to pass memory configuration to kernel through DT memory node. Signed-off-by: Ravi Babu <ravibabu@ti.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-05-08spl: make image arg or fdt blob address reconfigurableVikas Manocha
At present fdt blob or argument address being passed to kernel is fixed at compile time using macro CONFIG_SYS_SPL_ARGS_ADDR. FDT blob from different media like nand, nor flash are copied to the address pointed by the macro. The problem is, it makes args/fdt blob compulsory to copy which is not required in cases like for NOR Flash. This patch removes this limitation. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2017-04-27arm/lib/bootm.c: keep ARM v7M in thumb mode during boot_jump_linux()Patrice Chotard
On ARM v7M, the processor will return to ARM mode when executing a blx instruction with bit 0 of the address == 0. Always set it to 1 to stay in thumb mode. Tested on STM32f746-disco board Similar commit: f99993c10882f7dc8ec35993d5febe59aac01e6a Author: Matt Porter <mporter@konsulko.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-04-18ARM: adjust arm-smccc code for use in U-BootMasahiro Yamada
Adjust ARM SMC Calling Convention code for U-Boot: - Replace the license block with SPDX - Change path to asm-offsets.h - Define UNWIND() as no-op - Add Kconfig entry - Add asm-offsets Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-04-08armv7m: add instruction & data cache supportVikas Manocha
This patch adds armv7m instruction & data cache support. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com>
2017-04-06Remove various unused interrupt related codeTom Rini
With d53ecad92f06 some unused interrupt related code was removed. However all of these options are currently unused. Rather than migrate some of these options to Kconfig we just remove the code in question. The only related code changes here are that in some cases we use CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename and move the value local to the code in question. Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi") Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-04arm: bootm: Add dm_remove_devices_flags() call to announce_and_cleanup()Stefan Roese
This patch adds a call to dm_remove_devices_flags() to announce_and_cleanup() so that drivers that have one of the removal flags set (e.g. DM_FLAG_ACTIVE_DMA_REMOVE) in their driver struct, may do some last-stage cleanup before the OS is started. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-18arm: Migrate SYS_THUMB_BUILD to Kconfig, introduce SPL_SYS_THUMB_BUILDTom Rini
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for various reasons. We also have cases where we only build SPL in Thumb2 mode due to size constraints and wish to build the rest of the system in ARM mode. So in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to control if we build everything or just SPL (or in theory, just U-Boot) in Thumb2 mode. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
2017-03-17arm: use common instructions applicable to armv7m & other arm archsVikas Manocha
This patch cleans the code by using instructions allowed for armv7m as well as other Arm archs. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-03-09do_smhload: fix return codeRyan Harkin
do_smhload was using a ulong to store the return value from smh_load_file. That returns an int, where -1 indicates an error. As a ulong will never be negative, smh_load_file errors were not detected and so_smhload always returned zero. Also, when errors were spotted, do_smhload was returning 1, rather than the enumeration CMD_RET_FAILURE (which is also 1). Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2017-03-01armv8: spl: Call spl_relocate_stack_gd for ARMv8Philipp Tomsich
As part of the startup process for boards using the SPL, we need to call spl_relocate_stack_gd. This is needed to set up malloc with its DRAM buffer. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-08arm64: fix comment in relocate_64.SMasahiro Yamada
There are two typos in the comment "invalide i-cache is enabled". We can fix it by invalide -> invalidate is -> if Or, if we want to match the comment to the code, we can say "skip invalidating i-cache if disabled". Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-08arm64: use store with auto-incrementMasahiro Yamada
Save one instruction. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-08arm64: use xzr to zero-out the bss sectionMasahiro Yamada
AArch64 has a zero register (xzr). Use it instead of x2. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-20ARM: Default to using optimized memset and memcpy routinesTom Rini
We have long had available optimized versions of the memset and memcpy functions that are borrowed from the Linux kernel. We should use these in normal conditions as the speed wins in many workflows outweigh the relatively minor size increase. However, we have a number of places where we're simply too close to size limits in SPL and must be able to make the size vs performance trade-off in those cases. Cc: Philippe Reynes <tremyfr@yahoo.fr> Cc: Eric Jarrige <eric.jarrige@armadeus.org> Cc: Heiko Schocher <hs@denx.de> Cc: Magnus Lilja <lilja.magnus@gmail.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Chander Kashyap <k.chander@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-19Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-01-18ARMv8/sec_firmware: relocated and renamed the config FSL_PPA_ARMV8_PSCIHou Zhiqiang
Moved the config FSL_PPA_ARMV8_PSCI from fsl-layerscape's Kconfig to Kconfig under armv8 and renamed it to SEC_FIRMWARE_ARMV8_PSCI. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8: aarch64: Fix the warning about x1-x3 nonzero issueAlison Wang
For 64-bit kernel, there is a warning about x1-x3 nonzero in violation of boot protocol. To fix this issue, input argument 4 is added for armv8_switch_to_el2 and armv8_switch_to_el1. The input argument 4 will be set to the right value, such as zero. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: Alexander Graf <agraf@suse.de> Tested-by: Ryan Harkin <ryan.harkin@linaro.org> Tested-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-04ARM: boot0 hook: remove macro, include whole header fileAndre Przywara
For prepending some board specific header area to U-Boot images we were so far including a header file with a macro definition containing the actual header specification. This works fine if there are just a few statements and if there is only one alternative. However adding more complex code quickly gets messy with this approach, so let's just drop that intermediate macro and let the #include actually insert the code directly. This converts the callers and the callees, but doesn't change anything at this point. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Steve Rae <steve.rae@raedomain.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-01-04armv8: prevent using THUMBAndre Przywara
The predominantely 32-bit ARM targets try to compile the SPL in Thumb mode to reduce code size. The 64-bit AArch64 instruction set does not know an alternative, concise encoding, so the Thumb build option should only be set for 32-bit targets. Likewise -marm machine options are only valid for ARMv7 targets. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2016-12-15ARMv8: Setup PSCI memory and device treemacro.wave.z@gmail.com
Newly add ARMv8 PSCI needs to be initialized, be copied or reserved in right place, this patch does all the setup steps. Signed-off-by: Hongbo Zhang <hongbo.zhang@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-12-15ARMv8: LS1043A: change macro CONFIG_ARMV8_PSCI definitionmacro.wave.z@gmail.com
NXP/Freescale uses macro CONFIG_ARMV8_PSCI to enable their private PSCI implementation in PPA firmware, but this macro naming too generic, so this patch replaces it with a specic one CONFIG_FSL_PPA_ARMV8_PSCI. And this macro CONFIG_ARMV8_PSCI will be used for a generic PSCI for ARMv8 which will be added in following patchs. Signed-off-by: Hongbo Zhang <hongbo.zhang@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-12-02libfdt: replace ARCH_FIXUP_FDT with ARCH_FIXUP_FDT_MEMORYMasahiro Yamada
Commit e2f88dfd2d96 ("libfdt: Introduce new ARCH_FIXUP_FDT option") allows us to skip memory setup of DTB, but a problem for ARM is that spin_table_update_dt() and psci_update_dt() are skipped as well if CONFIG_ARCH_FIXUP_FDT is disabled. This commit allows us to skip only fdt_fixup_memory_banks() instead of the whole of arch_fixup_fdt(). It will be useful when we want to use a memory node from a kernel DTB as is, but need some fixups for Spin-Table/PSCI. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Acked-by: Simon Glass <sjg@chromium.org> Fixed build error for x86: Signed-off-by: Simon Glass <sjg@chromium.org>
2016-11-27efi_loader: Allow to compile helloworld.efi w/o bundling itAlexander Graf
Today we can compile a self-contained hello world efi test binary that allows us to quickly verify whether the EFI loader framwork works. We can use that binary outside of the self-contained test case though, by providing it to a to-be-tested system via tftp. This patch separates compilation of the helloworld.efi file from including it in the u-boot binary for "bootefi hello". It also modifies the efi_loader test case to enable travis to pick up the compiled file. Because we're now no longer bloating the resulting u-boot binary, we can enable compilation always, giving us good travis test coverage. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-11-22armv8: fsl-layerscape: SMP support for loading 32-bit OSAlison Wang
Spin-table method is used for secondary cores to load 32-bit OS. The architecture information will be got through checking FIT image and saved in the os_arch element of spin-table, then the secondary cores will check os_arch and jump to 32-bit OS or 64-bit OS automatically. Signed-off-by: Alison Wang <alison.wang@nxp.com> Signed-off-by: Chenhui Zhao <chenhui.zhao@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-11-22armv8: Support loading 32-bit OS in AArch32 execution stateAlison Wang
To support loading a 32-bit OS, the execution state will change from AArch64 to AArch32 when jumping to kernel. The architecture information will be got through checking FIT image, then U-Boot will load 32-bit OS or 64-bit OS automatically. Signed-off-by: Ebony Zhu <ebony.zhu@nxp.com> Signed-off-by: Alison Wang <alison.wang@nxp.com> Signed-off-by: Chenhui Zhao <chenhui.zhao@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-11-17ls2080: Exit dpaa only right before exiting U-BootAlexander Graf
On ls2080 we have a separate network fabric component which we need to shut down before we enter Linux (or any other OS). Along with that also comes configuration of the fabric using a description file. Today we always stop and configure the fabric in the boot script and (again) exit it on device tree generation. This works ok for the normal booti case, but with bootefi the payload we're running may still want to access the network. So let's add a new fsl_mc command that defers configuration and stopping the hardware to when we actually exit U-Boot, so that we can still use the fabric from an EFI payload. For existing boot scripts, nothing should change with this patch. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: York Sun <york.sun@nxp.com> [agraf: Fix x86 build]
2016-11-14efi: arm: Add aarch64 EFI app supportSimon Glass
Add support for EFI apps on aarch64. This includes start-up and relocation code plus a link script. Signed-off-by: Simon Glass <sjg@chromium.org> [agraf: add kconfig dep] Signed-off-by: Alexander Graf <agraf@suse.de>
2016-11-14efi: arm: Add EFI app supportSimon Glass
Add support for EFI apps on ARM. This includes start-up and relocation code, plus a link script and some compiler setting changes. Signed-off-by: Simon Glass <sjg@chromium.org> [agraf: Remove whitespace change, add kconfig dep] Signed-off-by: Alexander Graf <agraf@suse.de>
2016-11-14elf: arm: Add a few ARM relocation typesSimon Glass
Rather than hard-coding the relocation type, add it to the ELF header file and use it from there. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2016-11-13arm: Set TTB XN bit in case DCACHE_OFF for LPAE modeKeerthy
While we setup the mmu initially we mark set_section_dcache with DCACHE_OFF flag. In case of non-LPAE mode the DCACHE_OFF macro is rightly defined with TTB_SECT_XN_MASK set so as to mark all the 4GB XN. In case of LPAE mode XN(Execute-never) bit is not set with DCACHE_OFF. Hence XN bit is not set by default for DCACHE_OFF which keeps all the regions execute okay and this leads to random speculative fetches in random memory regions which was eventually caught by kernel omap-l3-noc driver. Fix this to mark the regions as XN by default. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
