path: root/arch/arm/lib
2014-10-25lib: bootm: add missing includeJeroen Hofstee
since the vxworks weaks are reimplement make sure their prototypes are visible. Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-10-25leds: missing includeJeroen Hofstee
2014-10-24arm: board: use __weakJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-10-21ARM: prevent compiler warnings from bootm.cEric Nelson
Without preceding declarations, "make C=1" generates "Should it be static?" warnings for symbols do_bootm_linux, boot_prep_vxworks, and boot_jump_vxworks Include of bootm.h also identified a signature mismatch (const on argv[]). Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-10-06arm: cache: Add support for write-allocate D-CacheMarek Vasut
Add configuration for the write-allocate mode of L1 D-Cache on ARM. This is needed for D-Cache operation on Cortex-A9 on the SoCFPGA . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Pavel Machek <pavel@denx.de>
2014-09-25armv8/fsl-lsch3: Release secondary cores from boot hold off with Boot PageYork Sun
Secondary cores need to be released from holdoff by boot release registers. With GPP bootrom, they can boot from main memory directly. Individual spin table is used for each core. Spin table and the boot page is reserved in device tree so OS won't overwrite. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Arnab Basu <arnab.basu@freescale.com>
2014-09-16Revert "ARM: SPL: do not set gd again"Tom Rini
At the high level, the problem is that we set gd multiple times (and still do, even after the commit we're reverting). We set important parts of gd to the copy which is not above stack but rather in the data section. For the release, we're going to revert this change and for the next release we shall correct things to only, really, set gd once to an appropriate location and ensure that comments about it are correct too. This reverts commit f0c3a6c4ad09210d5d4aeafe87685ee75e5683d6. Acked-by: Albert Aribaud <albert.u.boot@aribaud.net> Signed-off-by: Tom Rini <trini@ti.com>
2014-09-11arm: Fix _start for CONFIG_SYS_DV_NOR_BOOT_CFGBenoît Thébaudeau
The boards using CONFIG_SYS_DV_NOR_BOOT_CFG (i.e. calimain, da850evm_direct_nor and enbw_cmc) had the _start symbol defined after the CONFIG_SYS_DV_NOR_BOOT_CFG word rather than before it in arch/arm/lib/vectors.S. Because of that, if by lack of luck 'gd->mon_len = (ulong)&__bss_end - (ulong)_start' (see setup_mon_len()) was a multiple of 4 kiB (see reserve_uboot()), then the last BSS word overlapped the first word of the following reserved RAM area (or went beyond the top of RAM without such an area) after relocation because __image_copy_start did not match _start (see relocate_code()). This was broken by commit 41623c9 'arm: move exception handling out of start.S files', which defined _start twice (before and after the CONFIG_SYS_DV_NOR_BOOT_CFG word), then by commit 0a26e1d 'arm: fix a double-definition error of _start symbol', which kept the definition of the _start symbol after the CONFIG_SYS_DV_NOR_BOOT_CFG word. This new commit fixes this issue by restoring the original behavior, i.e. by defining the _start symbol before the CONFIG_SYS_DV_NOR_BOOT_CFG word. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Manfred Rudigier <manfred.rudigier@omicron.at> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Heiko Schocher <hs@denx.de>
2014-09-11arm: Make reset position-independentBenoît Thébaudeau
Some boards, like mx31pdk and tx25, require the beginning of the SPL code to be position-independent. For these two boards, this is because they use the i.MX external NAND boot, which starts by executing the first NAND Flash page from the NFC page buffer. The SPL then needs to copy itself to its actual link address in order to free the NFC page buffer and use it to load the non-SPL image from Flash before running it. This means that the SPL runtime address differs from its link address between the reset and the initial copy performed by board_init_f(), so this part of the SPL binary must be position-independent. This requirement was broken by commit 41623c9 'arm: move exception handling out of start.S files', which used an absolute address to branch to the reset routine. This new commit restores the original behavior, which just performed a relative branch. This fixes the boot of mx31pdk and tx25. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com> Reported-by: Helmut Raiger <helmut.raiger@hale.at> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Magnus Lilja <lilja.magnus@gmail.com> Cc: John Rigby <jcrigby@gmail.com> Tested-by: Magnus Lilja <lilja.magnus@gmail.com>
2014-09-09eabi_compat: add __aeabi_memcpy __aeabi_memsetJeroen Hofstee
cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-09-09ARM: SPL: do not set gd againJeroen Hofstee
Just before calling board_init_f, crt0.S has already reserved space for the initial gd on the stack. There should be no need to allocate it again. cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-09-05arm:reset: call the reset_misc() before the cpu resetPrzemyslaw Marczak
On an Odroid U3 board, the SOC is unable to reset the eMMC card in the DWMMC mode by the cpu software reset. Manual reset of the card by switching proper gpio pin - fixes this issue. Such solution needs to add a call to pre reset function. This is done by the reset_misc() function, which is called before reset_cpu(). The function reset_misc() is a weak function. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Changes v4: - arch/arm/reset: fix weak function attribute to proper style Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-08-30arm64: Correct passing of Linux kernel argsTom Rini
The Documentation/arm64/booting.txt document says that pass in x1/x2/x3 as 0 as they are reserved for future use. Signed-off-by: Tom Rini <trini@ti.com>
2014-08-30ARM: Fix overflow in MMU setupMarek Vasut
The patch fixes a corner case where adding size to DRAM start resulted in a value (1 << 32), which in turn overflew the u32 computation, which resulted in 0 and it therefore prevented correct setup of the MMU tables. The addition of DRAM bank start and it's size can end up right at the end of the address space in the special case of a machine with enough memory. To prevent this overflow, shift the start and size separately and add them only after they were shifted. Hopefully, we only have systems in tree which have DRAM size aligned to 1MiB boundary. If not, this patch would break such systems. On the other hand, such system would be broken by design anyway. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-08-29arm: include config.h in arch/arm/lib/vectors.SChristian Riesch
config.h is required for CONFIG_SYS_DV_NOR_BOOT_CFG. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Reported-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Heiko Schocher <hs@denx.de> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
2014-08-04arm: Support pre-relocation malloc()Simon Glass
Add support for re-relocation malloc() in arm's start-up code. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-08-04arm: Set up global data before board_init_f()Simon Glass
At present arm defines CONFIG_SYS_GENERIC_GLOBAL_DATA, meaning that the global_data pointer is set up in board_init_f(). However it is actually set up before this, it just isn't zeroed. If we zero the global data before calling board_init_f() then we don't need to define CONFIG_SYS_GENERIC_GLOBAL_DATA. Make this change (on arm32 only) to simplify the init process. I don't have the ability to test aarch64 yet. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Tom Rini <trini@ti.com>
2014-07-28ARM: HYP/non-sec/PSCI: emit DT nodesMarc Zyngier
Generate the PSCI node in the device tree. Also add a reserve section for the "secure" code that lives in in normal RAM, so that the kernel knows it'd better not trip on it. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-28ARM: convert arch_fixup_memory_node to a generic FDT fixup functionMa Haijun
Some architecture needs extra device tree setup. Instead of adding yet another hook, convert arch_fixup_memory_node to be a generic FDT fixup function. [maz: collapsed 3 patches into one, rewrote commit message] Signed-off-by: Ma Haijun <mahaijuns@gmail.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-28ARM: HYP/non-sec: allow relocation to secure RAMMarc Zyngier
The current non-sec switching code suffers from one major issue: it cannot run in secure RAM, as a large part of u-boot still needs to be run while we're switched to non-secure. This patch reworks the whole HYP/non-secure strategy by: - making sure the secure code is the *last* thing u-boot executes before entering the payload - performing an exception return from secure mode directly into the payload - allowing the code to be dynamically relocated to secure RAM before switching to non-secure. This involves quite a bit of horrible code, specially as u-boot relocation is quite primitive. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-28ARM: HYP/non-sec: add separate section for secure codeMarc Zyngier
In anticipation of refactoring the HYP/non-secure code to run from secure RAM, add a new linker section that will contain that code. Nothing is using it just yet. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-28ARM: add missing HYP mode constantMarc Zyngier
In order to be able to use the various mode constants (far more readable than random hex values), add the missing HYP and A values. Also update arm/lib/interrupts.c to display HYP instead of an unknown value. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-28ARM: HYP/non-sec: move switch to non-sec to the last boot phaseMarc Zyngier
Having the switch to non-secure in the "prep" phase is causing all kind of troubles, as that stage can be called multiple times. Instead, move the switch to non-secure to the last possible phase, when there is no turning back anymore. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-04ARM: cache_v7: use __weakJeroen Hofstee
This is not only more readable but also prevents a warning about a missing prototype. The prototypes which are actually missing are added. cc: Albert Aribaud <albert.u.boot@aribaud.net> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Tom Rini <trini@ti.com>
2014-07-03arm: Add support for semihosting for armv8 fastmodel targets.Darwin Rambo
The armv8 ARM Trusted Firmware (ATF) can be used to load various ATF images and u-boot, and does this for virtual platforms by using semihosting. This commit extends this idea by allowing u-boot to also use semihosting to load the kernel/ramdisk/dtb. This eliminates the need for a bootwrapper and produces a more realistic boot sequence with virtual models. Though the semihosting code is quite generic, support for armv7 in fastmodel is less useful due to the wide range of available silicon and the lack of a free armv7 fastmodel, so this change contains an untested armv7 placeholder for the service trap opcode. Please refer to doc/README.semihosting for a more detailed description of semihosting and how it is used with the armv8 virtual platforms. Signed-off-by: Darwin Rambo <drambo@broadcom.com> Cc: trini@ti.com Cc: fenghua@phytium.com.cn Cc: bhupesh.sharma@freescale.com
2014-06-25Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-06-09arm: fix a double-definition error of _start symbolMasahiro Yamada
The symbol "_start" is defined twice in arch/arm/lib/vectors.S: around line 48 and line 54. If CONFIG_SYS_DV_NOR_BOOT_CFG is defined (as on calimain board), build fails: arch/arm/lib/vectors.S: Assembler messages: arch/arm/lib/vectors.S:54: Error: symbol `_start' is already defined make[1]: *** [arch/arm/lib/vectors.o] Error 1 make: *** [arch/arm/lib] Error 2 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-06-05arm: fdt_control: fix a build error with CONFIG_OF_EMBED=yMasahiro Yamada
The build fails if a non-generic ARM board is compiled with CONFIG_OF_EMBED=y. The correct symbol name for embedded FDT is not __dtb_db_begin, but __dtb_dt_begin. (A typo introduced by commit 6ab6b2af) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-20Merge remote-tracking branch 'u-boot/master'Albert ARIBAUD
Conflicts: boards.cfg Conflicts were trivial once u-boot-arm/master boards.cfg was reformatted (commit 6130c146) to match u-boot/master's own reformatting (commit 1b37fa83).
2014-05-15arm: move exception handling out of start.S filesAlbert ARIBAUD
Exception handling is basically identical for all ARM targets. Factorize it out of the various start.S files and into a single vectors.S file, and adjust linker scripts accordingly. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-05-15arm1136: move cache code from start.S to cache.cAlbert ARIBAUD
arch/arm/cpu/arm1136/start.S contain a cache flushing function. Remove the function and move its code into arch/arm/lib/cache.c. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-05-12bd_info: remove bi_barudrate member from struct bd_infoMasahiro Yamada
gd->bd->bi_baudrate is a copy of gd->baudrate. Since baudrate is a common feature for all architectures, keep gd->baudrate only. It is true that bi_baudrate was passed to the kernel in that structure but it was a long time ago. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
2014-04-08Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile include/configs/trats.h include/configs/trats2.h include/mmc.h
2014-04-08arm64 patch: gicv3 supportDavid Feng
This patch add gicv3 support to uboot armv8 platform. Changes for v2: - rename arm/cpu/armv8/gic.S with arm/lib/gic_64.S - move smp_kick_all_cpus() from gic.S to start.S, it would be implementation dependent. - Each core initialize it's own ReDistributor instead of master initializeing all ReDistributors. This is advised by arnab.basu <arnab.basu@freescale.com>. Signed-off-by: David Feng <fenghua@phytium.com.cn>
2014-04-07bootstage: arm: fix fdt stashing codeMela Custodio
The conditional is using a variable that is not defined. Signed-off-by: Rommel G Custodio <sessyargc+u-boot@gmail.com>
2014-04-07armv8: Flush dcache before switching to EL2York Sun
For ARMv8, U-boot has been running at EL3 with cache and MMU enabled. Without proper setup for EL2, cache and MMU are both disabled (out of reset). Before switching, we need to flush the dcache to make sure the data is in the main memory. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: David.Feng <fenghua@phytium.com.cn>
2014-04-07armv8/cache: Flush D-cache, invalidate I-cache for relocationYork Sun
If D-cache is enabled, we need to flush it, and invalidate i-cache before jumping to the new location. This should be done right after relocation. Signed-off-by: York Sun <yorksun@freescale.com> CC: David Feng <fenghua@phytium.com.cn>
2014-03-28kbuild: move asm-offsets.c from SoC directory to arch/$(ARCH)/libMasahiro Yamada
U-Boot has supported two kinds of asm-offsets.h. One is generic for all architectures and its source is located at ./lib/asm-offsets.c. The other is SoC specific and its source is under SoC directory. The problem here is that only boards with SoC directory can use the asm-offsets infrastructure. Putting asm-offsets.c right under CPU directory does not work. Now a new demand is coming. PowerPC folks want to use asm-offsets. But no PowerPC boards have SoC directory. It seems inconsistent that some boards add asm-offsets.c to SoC directoreis and some to CPU directories. It looks more reasonable to put asm-offsets.c under arch/$(ARCH)/lib. This commit merges asm-offsets.c under SoC directories into arch/$(ARCH)/lib/asm-offsets.c. By the way, I doubt the necessity of some entries in asm-offsets.c. I am leaving refactoring to the board maintainers. Please check "TODO" in the comment blocks in arch/{arm,nds32}/lib/asm-offsets.c. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Yuantian Tang <Yuantian.Tang@freescale.com>
2014-03-10ahci-plat: Provide a weak scsi_init hookIan Campbell
This allow the platform to register the platform ahci device. Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
2014-03-07kbuild: add CONFIG_ prefix to USE_PRIVATE_LIBGCCMasahiro Yamada
Before this commit, USE_PRIVATE_LIBGCC was defined in arch-specific config.mk and referenced in arch/$(ARCH)/lib/Makefile. We are not happy about parsing config.mk again and again. We have to keep the same behavior with a different way. By adding "CONFIG_" prefix, this macro appears in include/autoconf.mk, include/spl-autoconf.mk. (And treating USE_PRIVATE_LIBGCC as CONFIG macro is reasonable enough.) Tegra SoC family defined USE_PRIVATE_LIBGCC as "yes" in arch/arm/cpu/arm720t/tegra*/config.mk, whereas did not define it in arch/arm/cpu/armv7/tegra*/config.mk. It means Tegra enables PRIVATE_LIBGCC only for SPL. We can describe the same behavior by adding #ifdef CONFIG_SPL_BUILD # define CONFIG_USE_PRIVATE_LIBGCC #endif to include/configs/tegra-common.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-02-26Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: arch/arm/cpu/armv7/config.mk board/ti/am43xx/mux.c include/configs/am43xx_evm.h Signed-off-by: Tom Rini <trini@ti.com>
2014-02-26arm: Switch to -mno-unaligned-access when supported by the compilerTom Rini
When we tell the compiler to optimize for ARMv7 (and ARMv6 for that matter) it assumes a default of SCTRL.A being cleared and unaligned accesses being allowed and fast at the hardware level. We set this bit and must pass along -mno-unaligned-access so that the compiler will still breakdown accesses and not trigger a data abort. To better help understand the requirements of the project with respect to unaligned memory access, the Documentation/unaligned-memory-access.txt file has been added as doc/README.unaligned-memory-access.txt and is taken from the v3.14-rc1 tag of the kernel. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Mans Rullgard <mans@mansr.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-02-26arm: remove unneeded symbol offsets and _TEXT_BASEAlbert ARIBAUD
Remove the last uses of symbol offsets in ARM U-Boot. Remove some needless uses of _TEXT_BASE. Remove all _TEXT_BASE definitions. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-02-26arm: make _end compiler-generatedAlbert ARIBAUD
This prevents references to _end from generating absolute relocation records. This change is binary invariant for ARM targets. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-02-21common: Add get_effective_memsize() to memsize.cYork Sun
This function has been around for powerpc. It is used for systems with memory more than CONFIG_MAX_MEM_MAPPED. In case of non-contiguous memory, this feature can limit U-boot to one block without going over the limit. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-02-19Move #ifdef(CONFIG_DISPLAY_CPUINFO) from caller to calleeMasahiro Yamada
- When CONFIG_DISPLAY_CPUINFO is not enabled, print_cpuinfo() should be defined as an empty function in a header, include/common.h - Remove #ifdef CONFIG_DISPLAY_CPUINFO .. #endif from caller, common/board_f.c and arch/arm/lib/board.c - Remove redundant prototypes in arch/arm/lib/board.c, arch/arm/include/asm/arch-am33x/sys_proto.h and board/nokia/rx51/rx51.h, keeping the one in include/common.h - Add #ifdef CONFIG_DISPLAY_CPUINFO to the func definition where it is missing Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19dts: re-write dts/Makefile more simply with KbuildMasahiro Yamada
Useful rules in scripts/Makefile.lib allows us to easily generate a device tree blob and wrap it in assembly code. We do not need to parse a linker script to get output format and arch. This commit deletes ./u-boot.dtb since it is a copy of dts/dt.dtb. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-14arm: use canonical sub mnemonicAndreas Bießmann
Building some arm boards with older binutils may produce errors like this: ---8<--- crt0.S: Assembler messages: crt0.S:70: Error: register expected, not '#(184)' -- `sub sp,#(184)' --->8--- Use canonical version of the subtract mnemonic to avoid those issues. Reported-by: Alexey Smishlayev <alexey@xtech2.lv> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-01-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Bringing in the MMC tree means that CONFIG_BOUNCE_BUFFER needed to be added to include/configs/exynos5-dt.h now. Conflicts: include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2014-01-09arm64: core supportDavid Feng
Relocation code based on a patch by Scott Wood, which is: Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: David Feng <fenghua@phytium.com.cn>
