path: root/arch/arm/lib
2014-06-05arm: fdt_control: fix a build error with CONFIG_OF_EMBED=yMasahiro Yamada
The build fails if a non-generic ARM board is compiled with CONFIG_OF_EMBED=y. The correct symbol name for embedded FDT is not __dtb_db_begin, but __dtb_dt_begin. (A typo introduced by commit 6ab6b2af) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-20Merge remote-tracking branch 'u-boot/master'Albert ARIBAUD
Conflicts: boards.cfg Conflicts were trivial once u-boot-arm/master boards.cfg was reformatted (commit 6130c146) to match u-boot/master's own reformatting (commit 1b37fa83).
2014-05-15arm: move exception handling out of start.S filesAlbert ARIBAUD
Exception handling is basically identical for all ARM targets. Factorize it out of the various start.S files and into a single vectors.S file, and adjust linker scripts accordingly. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-05-15arm1136: move cache code from start.S to cache.cAlbert ARIBAUD
arch/arm/cpu/arm1136/start.S contain a cache flushing function. Remove the function and move its code into arch/arm/lib/cache.c. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-05-12bd_info: remove bi_barudrate member from struct bd_infoMasahiro Yamada
gd->bd->bi_baudrate is a copy of gd->baudrate. Since baudrate is a common feature for all architectures, keep gd->baudrate only. It is true that bi_baudrate was passed to the kernel in that structure but it was a long time ago. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
2014-04-08Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile include/configs/trats.h include/configs/trats2.h include/mmc.h
2014-04-08arm64 patch: gicv3 supportDavid Feng
This patch add gicv3 support to uboot armv8 platform. Changes for v2: - rename arm/cpu/armv8/gic.S with arm/lib/gic_64.S - move smp_kick_all_cpus() from gic.S to start.S, it would be implementation dependent. - Each core initialize it's own ReDistributor instead of master initializeing all ReDistributors. This is advised by arnab.basu <arnab.basu@freescale.com>. Signed-off-by: David Feng <fenghua@phytium.com.cn>
2014-04-07bootstage: arm: fix fdt stashing codeMela Custodio
The conditional is using a variable that is not defined. Signed-off-by: Rommel G Custodio <sessyargc+u-boot@gmail.com>
2014-04-07armv8: Flush dcache before switching to EL2York Sun
For ARMv8, U-boot has been running at EL3 with cache and MMU enabled. Without proper setup for EL2, cache and MMU are both disabled (out of reset). Before switching, we need to flush the dcache to make sure the data is in the main memory. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: David.Feng <fenghua@phytium.com.cn>
2014-04-07armv8/cache: Flush D-cache, invalidate I-cache for relocationYork Sun
If D-cache is enabled, we need to flush it, and invalidate i-cache before jumping to the new location. This should be done right after relocation. Signed-off-by: York Sun <yorksun@freescale.com> CC: David Feng <fenghua@phytium.com.cn>
2014-03-28kbuild: move asm-offsets.c from SoC directory to arch/$(ARCH)/libMasahiro Yamada
U-Boot has supported two kinds of asm-offsets.h. One is generic for all architectures and its source is located at ./lib/asm-offsets.c. The other is SoC specific and its source is under SoC directory. The problem here is that only boards with SoC directory can use the asm-offsets infrastructure. Putting asm-offsets.c right under CPU directory does not work. Now a new demand is coming. PowerPC folks want to use asm-offsets. But no PowerPC boards have SoC directory. It seems inconsistent that some boards add asm-offsets.c to SoC directoreis and some to CPU directories. It looks more reasonable to put asm-offsets.c under arch/$(ARCH)/lib. This commit merges asm-offsets.c under SoC directories into arch/$(ARCH)/lib/asm-offsets.c. By the way, I doubt the necessity of some entries in asm-offsets.c. I am leaving refactoring to the board maintainers. Please check "TODO" in the comment blocks in arch/{arm,nds32}/lib/asm-offsets.c. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Yuantian Tang <Yuantian.Tang@freescale.com>
2014-03-10ahci-plat: Provide a weak scsi_init hookIan Campbell
This allow the platform to register the platform ahci device. Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
2014-03-07kbuild: add CONFIG_ prefix to USE_PRIVATE_LIBGCCMasahiro Yamada
Before this commit, USE_PRIVATE_LIBGCC was defined in arch-specific config.mk and referenced in arch/$(ARCH)/lib/Makefile. We are not happy about parsing config.mk again and again. We have to keep the same behavior with a different way. By adding "CONFIG_" prefix, this macro appears in include/autoconf.mk, include/spl-autoconf.mk. (And treating USE_PRIVATE_LIBGCC as CONFIG macro is reasonable enough.) Tegra SoC family defined USE_PRIVATE_LIBGCC as "yes" in arch/arm/cpu/arm720t/tegra*/config.mk, whereas did not define it in arch/arm/cpu/armv7/tegra*/config.mk. It means Tegra enables PRIVATE_LIBGCC only for SPL. We can describe the same behavior by adding #ifdef CONFIG_SPL_BUILD # define CONFIG_USE_PRIVATE_LIBGCC #endif to include/configs/tegra-common.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-02-26Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: arch/arm/cpu/armv7/config.mk board/ti/am43xx/mux.c include/configs/am43xx_evm.h Signed-off-by: Tom Rini <trini@ti.com>
2014-02-26arm: Switch to -mno-unaligned-access when supported by the compilerTom Rini
When we tell the compiler to optimize for ARMv7 (and ARMv6 for that matter) it assumes a default of SCTRL.A being cleared and unaligned accesses being allowed and fast at the hardware level. We set this bit and must pass along -mno-unaligned-access so that the compiler will still breakdown accesses and not trigger a data abort. To better help understand the requirements of the project with respect to unaligned memory access, the Documentation/unaligned-memory-access.txt file has been added as doc/README.unaligned-memory-access.txt and is taken from the v3.14-rc1 tag of the kernel. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Mans Rullgard <mans@mansr.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-02-26arm: remove unneeded symbol offsets and _TEXT_BASEAlbert ARIBAUD
Remove the last uses of symbol offsets in ARM U-Boot. Remove some needless uses of _TEXT_BASE. Remove all _TEXT_BASE definitions. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-02-26arm: make _end compiler-generatedAlbert ARIBAUD
This prevents references to _end from generating absolute relocation records. This change is binary invariant for ARM targets. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-02-21common: Add get_effective_memsize() to memsize.cYork Sun
This function has been around for powerpc. It is used for systems with memory more than CONFIG_MAX_MEM_MAPPED. In case of non-contiguous memory, this feature can limit U-boot to one block without going over the limit. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-02-19Move #ifdef(CONFIG_DISPLAY_CPUINFO) from caller to calleeMasahiro Yamada
- When CONFIG_DISPLAY_CPUINFO is not enabled, print_cpuinfo() should be defined as an empty function in a header, include/common.h - Remove #ifdef CONFIG_DISPLAY_CPUINFO .. #endif from caller, common/board_f.c and arch/arm/lib/board.c - Remove redundant prototypes in arch/arm/lib/board.c, arch/arm/include/asm/arch-am33x/sys_proto.h and board/nokia/rx51/rx51.h, keeping the one in include/common.h - Add #ifdef CONFIG_DISPLAY_CPUINFO to the func definition where it is missing Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19dts: re-write dts/Makefile more simply with KbuildMasahiro Yamada
Useful rules in scripts/Makefile.lib allows us to easily generate a device tree blob and wrap it in assembly code. We do not need to parse a linker script to get output format and arch. This commit deletes ./u-boot.dtb since it is a copy of dts/dt.dtb. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-14arm: use canonical sub mnemonicAndreas Bießmann
Building some arm boards with older binutils may produce errors like this: ---8<--- crt0.S: Assembler messages: crt0.S:70: Error: register expected, not '#(184)' -- `sub sp,#(184)' --->8--- Use canonical version of the subtract mnemonic to avoid those issues. Reported-by: Alexey Smishlayev <alexey@xtech2.lv> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-01-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Bringing in the MMC tree means that CONFIG_BOUNCE_BUFFER needed to be added to include/configs/exynos5-dt.h now. Conflicts: include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2014-01-09arm64: core supportDavid Feng
Relocation code based on a patch by Scott Wood, which is: Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: David Feng <fenghua@phytium.com.cn>
2013-12-16common/cmd_bootm: extend do_bootm_vxworks to support the new VxWorks boot ↵Miao Yan
interface. The next version VxWorks adopts device tree (for PowerPC and ARM) as its hardware description mechanism. For PowerPC, the boot interface conforms to the ePAPR standard, which is: void (*kernel_entry)(ulong fdt_addr, ulong r4 /* 0 */, ulong r5 /* 0 */, ulong r6 /* EPAPR_MAGIC */, ulong r7 /* IMA size */, ulong r8 /* 0 */, ulong r9 /* 0 */) For ARM, the boot interface is: void (*kernel_entry)(void *fdt_addr) Signed-off-by: Miao Yan <miao.yan@windriver.com> [trini: Fix build error when !CONFIG_OF_FDT is set, typo on PowerPC, missing extern ft_fixup_num_cores] Signed-off-by: Tom Rini <trini@ti.com>
2013-12-11Revert "ARM: move interrupt_init to before relocation"Albert ARIBAUD
Revert commit 0f5141e9 which causes boards starting in FLASH to try and write to a FLASH location. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-11-08cosmetic: remove empty lines at the top of fileMasahiro Yamada
2013-10-31ARM: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-10-03ARM: extend non-secure switch to also go into HYP modeAndre Przywara
For the KVM and XEN hypervisors to be usable, we need to enter the kernel in HYP mode. Now that we already are in non-secure state, HYP mode switching is within short reach. While doing the non-secure switch, we have to enable the HVC instruction and setup the HYP mode HVBAR (while still secure). The actual switch is done by dropping back from a HYP mode handler without actually leaving HYP mode, so we introduce a new handler routine in our new secure exception vector table. In the assembly switching routine we save and restore the banked LR and SP registers around the hypercall to do the actual HYP mode switch. The C routine first checks whether we are in HYP mode already and also whether the virtualization extensions are available. It also checks whether the HYP mode switch was finally successful. The bootm command part only calls the new function after the non-secure switch. Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
2013-10-03ARM: trigger non-secure state switch during bootm executionAndre Przywara
To actually trigger the non-secure switch we just implemented, call the switching routine from within the bootm command implementation. This way we automatically enable this feature without further user intervention. Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
2013-09-23ARM: use r9 for gdJeroen Hofstee
To be more EABI compliant and as a preparation for building with clang, use the platform-specific r9 register for gd instead of r8. note: The FIQ is not updated since it is not used in u-boot, and under discussion for the time being. The following checkpatch warning is ignored: WARNING: Use of volatile is usually wrong: see Documentation/volatile-considered-harmful.txt Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-09-23ARM,relocate: do not use r9Jeroen Hofstee
r9 is a platform-specific register in ARM EABI and not per definition a general purpose register. Do not use it while relocating so it can be used for gd. cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-09-14arm: spl: Do not set the stack pointer twiceMasahiro Yamada
Because the stack pointer is already set in arch/arm/lib/crt0.S, we do not need to set it in arch/arm/lib/spl.c. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-08-15arm: spl: For Falcon Mode, set a default machid of ~0Tom Rini
With device trees, boards do not always set CONFIG_MACH_TYPE now, so we must not rely on this define being set. The kernel uses ~0 to see if we have a valid machine number or not, so set that as the default, invalid machine, id and only fix if CONFIG_MACH_TYPE is set. Acked-by: Dan Murphy <dmurphy@ti.com> Tested-by: Heiko Schocher <hs@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Tom Rini <trini@ti.com>
2013-07-25Merge branch 'u-boot/master' into u-boot-arm/masterAlbert ARIBAUD
2013-07-25ARM: move interrupt_init to before relocationRob Herring
interrupt_init also sets up the abort stack, but is not setup before relocation. So any aborts during relocation will hang and not print out any useful information. Fix this by moving the interrupt_init to after the stack setup in board_init_f. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c: common changes for multibus/multiadapter supportHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org> Cc: Henrik Nordström <henrik@henriknordstrom.net>
2013-07-16Build arch/$ARCH/lib/bootm.o depending on CONFIG_CMD_BOOTMDirk Eibach
MAKEALL is fine for ppc4xx and mpc85xx. Run checks were done on our controlcenterd hardware. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and serial. Conflicts: arch/arm/dts/exynos5250.dtsi Signed-off-by: Tom Rini <trini@ti.com>
2013-07-10bootm: Clean up bootz_setup() functionSimon Glass
This function has no prototype in the headers and passes void * around, thus requiring several casts. Tidy this up. - Add new patch to clean up bootz_setup() function Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26arm: Implement the 'fake' go commandSimon Glass
Implement this feature on ARM for tracing. It would be nice to have generic bootm support so that it is easily implemented on any arch. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-06-22pxa: fix memory coherency problem after relocationMike Dunn
On the xscale, the icache must be invalidated and the write buffers drained after writing code over the data bus, even if the caches are disabled. Tested on the pxa270. Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
2013-06-21arm: optimize relocate_code routineAlbert ARIBAUD
Use section symbols directly Drop support for R_ARM_ABS32 record types Eliminate unneeded intermediate registers Optimize relocation table iteration Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-06-21arm: make __rel_dyn_{start, end} compiler-generatedAlbert ARIBAUD
This change is only done where needed: some linker scripts may contain relocation symbols yet remain unchanged. __rel_dyn_start and __rel_dyn_end each requires its own output section; putting them in relocation sections changes their flags and breaks relocation. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-06-21arm: make __image_copy_{start, end} compiler-generatedAlbert ARIBAUD
This change is only done where needed: some linker scripts may contain __image_copy_{start,end} yet remain unchanged. Also, __image_copy_end needs its own section; putting it in relocation sections changes their flags and makes relocation break. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-06-21arm: generalize lib/bss.c into lib/sections.cAlbert ARIBAUD
File arch/arm/lib/bss.c was initially defined for BSS only, but is now going to also contain definitions for other section-boundary-related symbols, so rename it for better accuracy. Also, remove useless 'used' attributes. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
