path: root/arch/arm/lib/stack.c
2017-04-06Remove various unused interrupt related codeTom Rini
With d53ecad92f06 some unused interrupt related code was removed. However all of these options are currently unused. Rather than migrate some of these options to Kconfig we just remove the code in question. The only related code changes here are that in some cases we use CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename and move the value local to the code in question. Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi") Signed-off-by: Tom Rini <trini@konsulko.com>
2016-05-02Change my mailaddressAndreas Bießmann
I'll switch my mails to my own server, so drop all gmail references. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-02-17common/board_f: factor out reserve_stacksAndreas Bießmann
Introduce arch_reserve_stacks() to tailor gd->start_addr_sp and gd->irq_sp to the architecture needs. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
