path: root/arch/arm/lib/ashrdi3.S
2016-06-03arm: lib: fix push/pop-section directivesStephen Warren
With the existing code, function symbols are defined in .text, and the body is defined in .text.xxx. This causes (at least some version of) the linker not to emit the function body into the final binary, since it's part of a different section to the symbols being referenced. This of course causes a wide variety of failures. This change moves the push/pop-section directives before the function symbols, and after any relate ENDPROC macro invocations, so that symbols and bodies are all in the "pushed" sections, and thus the function bodies are emitted into the binary. This solves (at least) the boot problems currently seen on Tegra systems that use SPL (i.e. all ARMv7 Tegras). Fixes: 13b0a91a6d48 ("arm: lib: Split asm symbols into different .text subsections") Cc: Marek Vasut <marex@denx.de> Cc: Tom Warren <twarren@nvidia.com> Cc: Simon Glass <sjg@chromium.org> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2016-06-02arm: lib: Split asm symbols into different .text subsectionsMarek Vasut
Split each symbol in lib1funcs into different .text.foo section instead of placing all of them into plain .text . This allows the linker to collect and discard unused assembler symbols. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-02arm: lib: Sync libgcc shift operationsMarek Vasut
Sync the libgcc shift operations with Linux kernel 4.4.6 , commit 0d1912303e54ed1b2a371be0bba51c384dd57326 . Syncing these three files is easy, as there is almost no change in them, except the addition of Thumb support. This patch also defines CONFIG_THUMB2_KERNEL and CONFIG_ARM_ASM_UNIFIED which is necessary for correct build of these files both in ARM and Thumb mode, just like Linux does. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-02arm: lib: Drop underscore from private libgcc filenamesMarek Vasut
Drop the underscore from the filenames of files implementing libgcc routines. There is no functional change. This change is done to make sync with Linux kernel easier. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
