path: root/arch/arm/include
2015-06-28Revert "sunxi/nand: Add support to the SPL for loading u-boot from internal ↵Ian Campbell
NAND memory" This reverts commit f76eba38b3eda905ff3bdc18dd1240d3dcbc6e5a. This patch did not have a full and proper copyright/S-o-b chain. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Conflicts: include/configs/sun6i.h include/configs/sun8i.h
2015-06-15Merge git://git.denx.de/u-boot-usbTom Rini
2015-06-15am33xx: Re-enable SW levelling for DDR2Tom Rini
The recent changes for hw leveling on am33xx were not intended for DDR2 boards, only DDR3. Update emif_sdram_type to take a sdram_config value to check against. This lets us pass in the value we would use to configure, when we have not yet configured the board yet. In other cases update the call to be as functional as before and check an already programmed value in. Tested-by: Yan Liu <yan-liu@ti.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-06-15ARM: BeagleBoard-x15: Enable i2c5 clocksLokesh Vutla
On AM57xx evm I2C5 is used to detect the LCD board by reading the EEPROM present on the bus. Enable i2c5 clocks to help that. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-12ARM: DRA7: CPSW: Remove IO delay hackLokesh Vutla
Now all manual mode configurations are done as part of IO delay recalibration sequence, remove the hack done for CPSW. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-06-12ARM: DRA7: Add support for manual mode configurationLokesh Vutla
In addition to the regular mux configuration, certain pins of DRA7 require to have "manual mode" also programmed, when predefined delay characteristics cannot be used for the interface. struct iodelay_cfg_entry is introduced for populating manual mode IO timings. For configuring manual mode, along with the normal pad configuration do the following steps: - Select MODESELECT field of each assocaited PAD. CTRL_CORE_PAD_XXX[8]:MODESELECT = 1(Enable MANUAL_MODE macro along with mux) - Populate A_DELAY, G_DELAY values that are specified in DATA MANUAL. And pass the offset of the CFG_XXX register in iodelay_cfg_entry. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2015-06-12ARM: DRA7: Add support for IO delay configurationLokesh Vutla
On DRA7, in addition to the regular muxing of pins, an additional hardware module called IODelay which is also expected to be configured. This "IODelay" module has it's own register space that is independent of the control module. It is advocated strongly in TI's official documentation considering the existing design of the DRA7 family of processors during mux or IODelay recalibration, there is a potential for a significant glitch which may cause functional impairment to certain hardware. It is hence recommended to do muxing as part of IOdelay recalibration. IODELAY recalibration sequence: - Complete AVS voltage change on VDD_CORE_L - Unlock IODLAY config registers. - Perform IO delay calibration with predefined values. - Isolate all the IOs - Update the delay mechanism for each IO with new calibrated values. - Configure PAD configuration registers - De-isolate all the IOs. - Relock IODELAY config registers. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2015-06-12ARM: DRA7: Add support for virtual mode configurationLokesh Vutla
In addition to the regular mux configuration, certain pins of DRA7 require to have "virtual mode" also programmed. This allows for predefined delay characteristics to be used by the SoC to meet timing characterstics needed for the interface. Provide easy to use macro to do the same. For configuring virtual mode, along with normal pad configuration add the following two steps: - Select MODESELECT field of each assocaited PAD. CTRL_CORE_PAD_XXX[8]:MODESELECT = 1 - DELAYMODE filed should be configured with value given in DATA Manual. CTRL_CORE_PAD_XXX[7:4]:DELAYMODE =[0-15] (as given in DATA manual). Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2015-06-12ARM: DRA7: Add pinctrl register definitionsLokesh Vutla
Adopting the pinctrl register definitions from Linux kernel to be consistent. Old definitions will be removed once all the pinctrl data is adapted to new definitions. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2015-06-12ARM: DRA7: Make do_set_mux32() genericLokesh Vutla
do_set_mux32() is redefined in dra7xx and beagle_x15 boards. IO delay recalibration sequence also needs this. Making it generic to avoid duplication. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2015-06-12ARM: DRA7: Add is_dra72x cpu check definitionLokesh Vutla
A generic is_dra72x cpu check is useful for grouping all the revisions under that. This is used in the subsequent patches. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-12ARM: DRA7: DDR3: Add support for HW levelingLokesh Vutla
DRA7 EMIF supports Full leveling for DDR3. Adding support for the Full leveling sequence. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-09tegra: Allow board-specific initSimon Glass
Add a hook to allows boards to add their own init to board_init(). Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-06-09tegra: Add missing tegra124 peripheralsSimon Glass
There are some missing entries in the tables. Add them. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-06-09tegra: Introduce SRAM repair on tegra124Simon Glass
This is required in order to avoid instability when running from caches after the kernel starts. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-06-09tegra: clock: Support enabling external clocksSimon Glass
Add a simple function to enable external clocks. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-06-08arm: exynos: USB3 PHY base definition for Exynos5 SoCsLukasz Majewski
After that change it would be possible to call samsung_get_base_usb3_phy() function to get proper base address Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com>
2015-06-08Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-06-08colibri_vf: Enable board specific USB initialisation for USB pen gpioSanchayan Maity
Add IOMUX for the pad used as USB pen. This needs to be driven low for the Iris and Viola boards where it is pulled up high by default. This is required for the USB host functionality to work on these boards. Use the board specific weak initialisation function, to drive the pin low which would be called on "usb start". Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
2015-06-08arm: vf610: Add iomux support for DSPIBhuvanchandra DV
Add iomux definitions for DSPI second instance. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
2015-06-08arm: vf610: Add clock support for DSPIBhuvanchandra DV
2015-06-08colibri_vf: Add pinmux entries for GPIOsBhuvanchandra DV
Inorder to use the pins as GPIO, apart from setting the alt-function, pinmuxing need to be done, this patch adds pinmux entries of few GPIOs. Acked-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
2015-06-08dm: gpio: vf610: Add GPIO driver supportBhuvanchandra DV
Add GPIO driver support to Freescale VF610 Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
2015-06-01Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
2015-06-01arm: rmobile: alt: Update to QoS revision 0.31 and 0.321Nobuhiro Iwamatsu
This updates r8a7794 QoS to revision 0.31 for ES1 and revision 0.321 for ES2. Signed-off-by: Kouei Abe <kouei.abe.cp@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-05-29sunxi/nand: Add support to the SPL for loading u-boot from internal NAND memoryDaniel Kochmański
This commit adds support to the sunxi SPL to load u-boot from the internal NAND. Note this only adds support to access the boot partitions to load u-boot, full NAND support to load the kernel, etc. from the nand data partition will come later. Signed-off-by: Roy Spliet <r.spliet@ultimaker.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-05-29sunxi: Match sun4i, sun6i, sun9i CCI definitions for NAND and DMARoy Spliet
Make sure definitions for NAND clock and DMA gate bits are the same across boards. Signed-off-by: Roy Spliet <r.spliet@ultimaker.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-05-29sunxi: Add DMA definitionsRoy Spliet
2015-05-29sun9i: Basic sun9i (A80) supportHans de Goede
Add initial sun9i (A80) support, only uart + mmc are supported for now. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-28ARMv7M: add STM32F1 supportMatt Porter
Add ARMv7M STM32F1 support including clocks, timer, gpio, and flash. Signed-off-by: Matt Porter <mporter@konsulko.com>
2015-05-26Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-05-26i2c, mxc: rework i2c base address names for different SoCsHeiko Schocher
rework and unify i2c address names for different SoCs, which use the mxc_i2c driver. Signed-off-by: Heiko Schocher <hs@denx.de>
2015-05-26arm, imx6, i2c: add I2C4 for MX6DLHeiko Schocher
add I2C4 modul for MX6DL based boards. Signed-off-by: Heiko Schocher <hs@denx.de>
2015-05-26imx: dma: correct MXS_DMA_ALIGNMENTPeng Fan
We should not hardcode MXS_DMA_ALIGNMENT to 32, since we can not guarantee that socs' cache line size is 32 bytes. If on chips whose cache line size is 64 bytes, error occurs: " NAND: ERROR: v7_dcache_inval_range - start address is not aligned - 0xbdf1d1a0 ERROR: v7_dcache_inval_range - stop address is not aligned - 0xbdf1f4a0 ERROR: v7_dcache_inval_range - start address is not aligned - 0xbdf1d1a0 " Align MXS_DMA_ALIGNMENT with ARCH_DMA_MINALIGN whose value is same to CONFIG_SYS_CACHELINE_SIZE if CONFIG_SYS_CACHELINE_SIZE defined. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2015-05-22Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2015-05-20arm/ls1021a: Remove ccsr_ddr from immap_ls102xa.hYork Sun
ccsr_ddr structure is already defined in fsl_immap.h. Remove this duplicated define. Move fixed timing into ls1021atwr.h. Signed-off-by: York Sun <yorksun@freescale.com> CC: Alison Wang <alison.wang@freescale.com> Acked-by: Alison Wang <alison.wang@freescale.com>
2015-05-19sunxi: video: Fix lvds panel support for sun6i+Hans de Goede
We've never tested the lvds panel support on sun6i+ SoCs until now, and unsurprisingly the lvds code needed some fixes to work on my ga10h A33 tablet with lvds panel. This makes the panel on that tablet actually work. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-19sunxi: Make DRAM_ODT_EN Kconfig setting a boolHans de Goede
Make DRAM_ODT_EN Kconfig setting a bool, add a separate DRAM_ODT_CORRECTION setting for A23 SoCs and use DRAM_ODT_EN Kconfig everywhere instead of only in dram_sun4i.c and hardcoding odt_en elsewhere. Note this commit makes no functional changes for existing boards, its purpose is to allow changing the odt_en value on future A33 boards. For sun4i/sun5i/sun7i boards which set DRAM_ODT_EN=y (which no defconfigs currently do) this patch turns on odt for both the DQ and the DQS lines, whereas previously it was possibly (but not desirable) to turn odt on only for one of them by setting the in DRAM_ODT_EN option to 1 or 2 instead of 3. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
2015-05-19sunxi: add support for UART2 on A23/A33Laurent Itti
Add support for UART2 (2-pin version but note that RTS/CTS pins are available pn that port for possible future use), can be selected in config by using CONFIG_CONS_INDEX=3 Signed-off-by: Laurent Itti <laurentitti@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-05-19imx: mx6: add get_cpu_temp_grade to obtain cpu temperature grade from OTPTim Harvey
The MX6 has a temperature grade defined by OCOTP_MEM0[7:6] which is at 0x480 in the Fusemap Description Table in the reference manual. Return this value as well as min/max temperature based on the value. Note that the IMX6SDLRM and the IMX6SXRM do not indicate this in the their Fusemap Description Table however Freescale has confirmed that these eFUSE bits match the description within the IMX6DQRM and that they will be added to the next revision of the respective reference manuals. This has been tested with IMX6 Automative and Industrial parts. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-19imx: mx6: add get_cpu_speed_grade_hz func to return MHz speed grade from OTPTim Harvey
The IMX6 has four different speed grades determined by eFUSE SPEED_GRADING indicated by OCOTP_CFG3[17:16] which is at 0x440 in the Fusemap Description Table. Return this frequency so that it can be used elsewhere. Note that the IMX6SDLRM and the IMX6SXRM do not indicate this in the their Fusemap Description Table however Freescale has confirmed that these eFUSE bits match the description within the IMX6DQRM and that they will be added to the next revision of the respective reference manuals. These have been tested with IMX6 Quad/Solo/Dual-light 800Mhz and 1GHz grades. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-19mx6: add OTP bank1 registersTim Harvey
2015-05-19imx: mx6sx enable SION for i2c pin muxPeng Fan
Enable IOMUX_CONFIG_SION for all I2C pin mux settings, otherwise we will get erros when doing i2c operations. error log like the following: " wait_for_sr_state: failed sr=81 cr=a0 state=2020 i2c_init_transfer: failed for chip 0xb retry=1 " Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-05-15mx6: Set shared override bit in PL310 AUX_CTRL registerFabio Estevam
Having bit 22 cleared in the PL310 Auxiliary Control register (shared attribute override enable) has the side effect of transforming Normal Shared Non-cacheable reads into Cacheable no-allocate reads. Coherent DMA buffers in Linux always have a Cacheable alias via the kernel linear mapping and the processor can speculatively load cache lines into the PL310 controller. With bit 22 cleared, Non-cacheable reads would unexpectedly hit such cache lines leading to buffer corruption. This was inspired by a patch from Catalin Marinas [1] and also from recent discussions in the linux-arm-kernel list [2] where Russell King and Rob Herring suggested that bootloaders should initialize the cache. [1] http://lists.infradead.org/pipermail/linux-arm-kernel/2010-November/031810.html [2] https://lkml.org/lkml/2015/2/20/199 Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com>
2015-05-14i2c: mxc: refactor i2c driver and support dmPeng Fan
1. Introduce a new structure `struct mxc_i2c_bus`, this structure will used for non-DM and DM. 2. Remove `struct mxc_i2c_regs` structure, but use register offset to access registers based on `base` entry of `struct mxc_i2c_bus`. 3. Remove most `#ifdef I2C_QUIRK_REG`. Using driver_data to contain platform flags. A new flag is introduced, I2C_QUIRK_FLAG. 4. Most functions use `struct mxc_i2c_bus` as one of the parameters. Make most functions common to DM and non-DM, try to avoid duplicated code. 5. Support DM, but pinctrl is not included. Pinmux setting is still set by setup_i2c, but we do not need bus_i2c_init for DM. 6. struct i2c_parms and struct sram_data are removed. 7. Remove bus_i2c_read bus_i2c_write prototype in header file. The frist paramter of bus_i2c_init is modified to i2c index. Add new prototype i2c_idle_bus and force_bus_idle. Since bus_i2c_init is not good for DM I2C and pinctrl is missed, we use a weak function for i2c_idle_bus. Board file take the responsibility to implement this function, like this: " int i2c_idle_bus(struct mxc_i2c_bus *i2c_bus) { if (i2c_bus->index == 0) force_bus_idle(i2c_pads_info0); else if (i2c_bus->index == 1) force_bus_idle(i2c_pads_info1); else xxxxxx } " 8. Introduce a weak function, enable_i2c_clk 9. Tested on an i.MX7 platform. Log info: => dm tree Class Probed Name ---------------------------------------- root [ + ] root_driver simple_bus [ ] |-- soc simple_bus [ ] | |-- aips-bus@30000000 simple_bus [ ] | | |-- anatop@30360000 simple_bus [ ] | | `-- snvs@30370000 simple_bus [ ] | |-- aips-bus@30400000 simple_bus [ ] | `-- aips-bus@30800000 i2c [ ] | |-- i2c@30a20000 i2c [ ] | `-- i2c@30a40000 simple_bus [ ] `-- regulators => i2c dev 0 Setting bus to 0 => i2c probe Valid chip addresses: 08 50 => i2c md 8 31 0031: 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-14imx: mx27 move GPIO_PORTx to gpio.hPeng Fan
These GPIO_PORTx macros should be in gpio.h, but not in imx-regs.h. Also, imx-regs.h and iomux-v3.h has same macro defintion for GPIO_PORTx, and both of them are included in mxc_i2c.c(include mxc_i2c.h). This will incur build warnings with macro redefinition. Since iomux-v3.h is not compatible with mx27, we can not simply include iomux-v3.h for mx27, so move the GPIO_PORTx to gpio.h to fix the build warning. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-05-14arm: Add a prototype for save_boot_params_ret()Simon Glass
It is convenient for some boards to implement save_boot_params() in C rather than assembler. Provide a way to return in this case. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-14sunxi: ohci: Add ohci usb host controller supportHans de Goede
This commit adds support for the OHCI companion controller, which makes usb-1 devices directly plugged into to usb root port work. Note for now this switches usb-keyboard support for sunxi back from int-queue support to the old interrupt polling method. Adding int-queue support to the ohci code and switching back to int-queue support is in the works. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-13ARM: tegra: Enable SMMU when going non-secureThierry Reding
Make sure to enable the SMMU when booting the kernel in non-secure mode. This is necessary because some of the SMMU registers are restricted to TrustZone-secured requestors, hence the kernel wouldn't be able to turn the SMMU on. At the same time, enable translation for all memory clients for the same reasons. The kernel will still be able to control SMMU IOVA translation using the per-SWGROUP enable bits. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13tegra124: Reserve secure RAM using MC_SECURITY_CFG{0, 1}_0Ian Campbell
These registers can be used to prevent non-secure world from accessing a megabyte aligned region of RAM, use them to protect the u-boot secure monitor code. At first I tried to do this from s_init(), however this inexplicably causes u-boot's networking (e.g. DHCP) to fail, while networking under Linux was fine. So instead I have added a new weak arch function protect_secure_section() called from relocate_secure_section() and reserved the region there. This is better overall since it defers the reservation until after the sec vs. non-sec decision (which can be influenced by an envvar) has been made when booting the os. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> [Jan: tiny style adjustment] Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Thierry Reding <treding@nvidia.com> Tested-by: Thierry Reding <treding@nvidia.com> Tested-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Tom Warren <twarren@nvidia.com>
