path: root/arch/arm/include
2014-12-08Merge branch 'master' of git://git.denx.de/u-boot-tiTom Rini
2014-12-08Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2014-12-09ARM: UniPhier: detect the number of flash banks at run-timeMasahiro Yamada
Some UniPhier boards are equipped with an expansion slot that some optional SRAM/NOR-flash cards can be attached to. So, run-time detection of the number of flash banks would be more user-friendly. Until this commit, UniPhier boards have achieved this by (ab)using board_flash_wp_on() because the boot failed if flash_size got zero. Fortunately, this problem was solved by commit 70879a92561a (flash: do not fail even if flash_size is zero). Now it is possible to throw away such a tricky workaround. This commit also enables CONFIG_SYS_MAX_FLASH_BANKS_DETECT for further refactoring. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-08ARM: rpi_b: detect board revisionStephen Warren
Detect the board revision early during boot, and print the decoded model name. Eventually, this information can be used for tasks such as: - Allowing/preventing USB device mode; some models have a USB device on- board so only host mode makes sense. Others connect the SoC directly to the USB connector, so device-mode might make sense. - The on-board USB hub/Ethernet requires different GPIOs to enable it, although luckily the default appears to be fine so far. - The compute module contains an on-board eMMC device, so we could store the environment there. Other models use an SD card and so don't support saving the environment (unless we store it in a file on the FAT boot partition...) Set $fdtfile based on this information. At present, the mainline Linux kernel doesn't contain a separate DTB for most models, but I hope that will change soon. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-12-04arm: am33xx: Handle NAND+I2C boot-device the same way as NANDStefan Roese
Re-map NAND&I2C boot-device to the "normal" NAND boot-device. Otherwise the SPL boot IF can't handle this device correctly. Somehow booting with Hynix 4GBit NAND H27U4G8 on Siemens Draco leads to this boot-device passed to SPL from the BootROM. With this change, Draco boots just fine into main U-Boot. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Roger Meier <r.meier@siemens.com> Cc: Samuel Egli <samuel.egli@siemens.com>
2014-12-04arm: omap: add support for am57xx devicesFelipe Balbi
just add a few ifdefs around because this device is very similar to dra7xxx. Signed-off-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-12-04arm: omap_common: expose tps659038 and dra7xx_dpllsFelipe Balbi
expose those two definitions so they can be used by another board which we're adding in upcoming patches. Signed-off-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-12-04arm: omap5: tps659038: rename regulator definesFelipe Balbi
Those regulators don't have any coupling with what they supply, so remove the suffixes in order to not confuse anybody. Signed-off-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-27Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2014-11-28ARM: UniPhier: add dummy gpio.h to enable CONFIG_OF_CONTROLMasahiro Yamada
If CONFIG_OF_CONTROL is enabled, lib/fdtdec.c is compiled. It includes <asm/gpio.h> and then <asm/gpio.h> includes <asm/arch/gpio.h>. Consequently, all the SoCs that enable CONFIG_OF_CONTROL must have <asm/arch/gpio.h> even if they do not support GPIO. In the first place, GPIO has nothing to do with OF_CONTROL. It is wrong that lib/fdtdec.c includes GPIO functions; it should be split into two files, FDT-common things and GPIO things. It is, however, a pretty big work to fix that correctly. This is a compromised commit to add a dummy <asm/arch/gpio.h> to support OF_CONTROL for UniPhier platform. This dummy header will be removed after FDT-GPIO stuff is fixed correctly. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-11-26mtd: nand: s3c: Unify the register definition and namingMarek Vasut
Merge struct s3c2410_nand and struct s3c2440_nand into one unified struct s3c24x0_nand. While at it, fix up and rename the functions to retrieve the NAND base address and fix up the s3c NAND driver to reflect this change. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Vladimir Zapolskiy <vz@mleia.com>
2014-11-26Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2014-11-26Merge branch 'master' of http://git.denx.de/u-boot-samsungTom Rini
2014-11-25sun6i: Add gmac support for sun6i boardsHans de Goede
Hookup the gmac found on the sun6i / A31 SoCs. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-25sunxi: video: Add simplefb supportLuc Verhaegen
Add simplefb support, note this depends on the kernel having support for the clocks property which has recently been added to the simplefb devicetree binding. Signed-off-by: Luc Verhaegen <libv@skynet.be> [hdegoede@redhat.com: Use pre-populated simplefb node under /chosen as disussed on the devicetree list] Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>.
2014-11-25sunxi: video: Add cfb console driver for sunxiLuc Verhaegen
This adds a fixed mode hdmi driver for the sunxi platform. The fixed mode is a relatively safe 1024x768, more complete EDID handling is currently not provided. Only HDMI is supported today. This code is enabled when HPD detects an attached monitor. Current config is such that 8MB is shaved off at the top of the RAM. This avoids several memory handling issues, most significant is the fact that on linux on ARM you are not allowed to remap known RAM as IO. A clued in display driver will be able to recycle this reserved RAM in future though. cfbconsole was chosen as it provides the most important functionality: a working u-boot console, allowing for the debugging of certain issues without the need for a UART. Signed-off-by: Luc Verhaegen <libv@skynet.be> [hdegoede@redhat.com: Major cleanups and some small bugfixes] Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Anatolij Gustschin <agust@denx.de> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-25sunxi: Add video pll clock functionsHans de Goede
This is a preparation patch for adding support for HDMI out. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-25sun4i: Rename dram_clk_cfg to dram_clk_gateHans de Goede
The data sheet just calls it DRAM_CLK_REG, and on sun6i we've both a dram_clk_cfg and dram_clk_gate, and the sun4i reg matches dram_clk_gate on sun6i, so name it the same on sun4i. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-24arm: ls102xa: Remove bit reversing for SCFG registersAlison Wang
SCFG_SCFGREVCR is SCFG bit reverse register. This register must be written with 0xFFFFFFFF before writing to any other SCFG register. Then other SCFG register could be written in big-endian mode. Address: 157_0000h base + 200h offset = 157_0200h Bit 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15|16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 W/R SCFGREV Reset 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0-31 SCFGREV SCFG Bit Reverse Control Filed 32'h 0000_0000 - No bit reverse is applied 32'h FFFF_FFFF - Bit reverse is applied; so 31:0 will be stored/read as 0:31 This patch removes the bit reversing for SCFG registers in u-boot. It will be implemented through PBI commands in RCW .pbi write 0x570200, 0xffffffff .end So other SCFG register could be written in big-endian mode in u-boot or kernel directly. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-24arm: ls102xa: Add snoop disable for slave port 0, 1 and 2Jason Jin
Disable the snoop for slave interface 0, 1 and 2 to avoid the interleaving on the CCI400 BUS. Signed-off-by: Jason Jin <Jason.Jin@freescale.com> Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-24drivers: usb: fsl: Define USB configs for LS102XANikhil Badola
Define USB configs for LS1021XA such as CONFIG_SYS_FSL_USB1_ADDR, CONFIG_USB_MAX_CONTROLLER_COUNT Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-24Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-11-24Merge git://git.denx.de/u-boot-dmTom Rini
Conflicts: drivers/serial/serial-uclass.c Signed-off-by: Tom Rini <trini@ti.com>
2014-11-24arm: mx6: introduce disable_sata_clockNikita Kiryanov
Implement disable_sata_clock for mx6 SoCs. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de>
2014-11-21mx6: clock: Add thermal clock enable functionNitin Garg
Add api to check and enable pll3 as required for thermal sensor driver. Signed-off-by: Ye.Li <B37916@freescale.com> Signed-off-by: Nitin Garg <nitin.garg@freescale.com>
2014-11-21dm: at91: Add driver model support for the serial driverSimon Glass
Add driver model support while retaining the existing legacy code. This allows the driver to support boards that have converted to driver model as well as those that have not. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21dm: at91: Add platform data for GPIO on at91sam9260-based boardsSimon Glass
These boards all have the same GPIO arrangement, so add some common platform data that can be used by all boards. Remove the configs which are no longer required. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21dm: at91: Add driver model support for atmel GPIO driverSimon Glass
Modify this driver to support driver model, with platform data required to determine the GPIOs that it controls. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-20ARM: remove CONFIG_ARM926EJS definesMasahiro Yamada
CONFIG_CPU_ARM926EJS was introduced into Kconfig by commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs). This commit removes all the defines of CONFIG_ARM926EJS and replaces the only reference in arch/arm/lib/cache.c with CONFIG_CPU_ARM926EJS. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-20ARM: remove CONFIG_ARM920T definesMasahiro Yamada
CONFIG_CPU_ARM920T was introduced into Kconfig by commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs). This commit removes all the defines of CONFIG_ARM920T and replaces the only reference in drivers/usb/host/ohci-hcd.c with CONFIG_CPU_ARM920T. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-20ARM: remove CONFIG_ARMV7 definesMasahiro Yamada
Some (not all) of ARMv7 boards define CONFIG_ARMV7, which is useless. Besides, it is never referenced. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-20mx6: add weim registersFabio Estevam
2014-11-20imx: consolidate set_chipselect_size functionFabio Estevam
Move MX5 specific set_chipselect_size function into generic i.MX part, such that MX6 based boards are able to use this function as well. While doing this the iomuxc gpr member needed to be consolidated between MX5 and MX6. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-19arm: ls102xa: Fixed a register definition errorTang Yuantian
There are 8 SCFG_SPARECR registers in SCFG memory block, not one. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-19qe: add u-qe support to arm boardZhao Qiang
ls1021 is arm-core and support qe which is u-qe. add u-qe init for arm board. Signed-off-by: Zhao Qiang <B45475@freescale.com> [York Sun: Fix compiling error caused by u_qe_init()] Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-17ARM: atmel: add sama5d4ek board supportBo Shen
The code for this board supports following features: - Boot media support: NAND flash/SD card/SPI flash - Support LCD display - Support ethernet - Support USB mass storage Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-17arm, spl, at91: add at91sam9260 and at91sam9g45 spl supportHeiko Schocher
add support for using spl code on at91sam9260 and at91sam9g45 based boards. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Bo Shen <voice.shen@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> [adopt Bo's change in spl.c] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-17arm, at91: add missing ddr2 cr register MPDDRC_CR_EBISHARE defineHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-17Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
2014-11-17arm: odroid: usb: add support for usb host including ethernetSuriyan Ramasami
This change adds support for enabling the USB host features of the board. This includes the USB3503A hub and the SMC LAN9730 ethernet controller as well. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-11-17arm: odroid: enable/disable usb host phy for exynos4412Suriyan Ramasami
Enable/disable the usb host phy on the odroid U/X2 boards which are based on the Exynos4412 SOC. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-11-17DMC: Exynos5: Enable update mode for DREX controllerAlim Akhtar
As per Exynos5800 UM ver 0.00 section 17.13.2.1 CONCONTROL register bit 3 [update_mode], Exynos5800 does not support the PHY initiated update. And it is recommanded to set this field to 1'b1 during initialization. This patch sets this bit. Applying MC-initiated mode makes DDL tracking ON, that helps in compensate MIF voltage variation. Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com> Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-11-17Exynos5800: Introduce new proid for Exynos5800Akshay Saraswat
This patch intends to add a new proid for Exynos5800 which is a variant of Exynos5420. Product id for Exynos5800 is 0x5422. Both Exynos5420 and Exynos5800 are pin to pin compitable. This gives us an advantage of reusing Exynos5420 clock, pinmux, memory and other settings. Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-11-13Merge branch 'master' of git://git.denx.de/u-boot-sunxiTom Rini
2014-11-13Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-11-13sun6i: ehci: Add sun6i ehci supportHans de Goede
Add support for the 2 ehci controllers found on the sun6i (A31) soc. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Marek Vasut <marex@denx.de>
2014-11-13sun6i: Add dram initialization codeHans de Goede
Add full support for dram initialization, using a fixed clock and autodetection of the memory organization (numbers of channels, bus-width, etc.). This is based on dram_sun6i.c and dram.h from u-boot in the Allwinner A31 SDK, extended with extra initialization sequences and the autodetect algorithm from boot0. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-13sun4i: Rename dram files to dram_sun4i.xHans de Goede
In preparation for adding sun6i dram support. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-13sun6i: Add cpucfg register definitionsHans de Goede
Not used atm, for future use (e.g. PSCI). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-13sun6i: Add clock functions needed for SPL / DRAM initHans de Goede
Add clock_init_safe and clockset_pll5 functions, as these are needed for SPL support resp. DRAM init (which is needed for SPL too). Also add some extra clock register constant defines. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
