path: root/arch/arm/include
2014-05-24Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-05-23armv7:TI: Add <asm/ti-common/sys_proto.h> and migrate omap_hw_init_contextTom Rini
The omap_hw_init_context function (and assorted helpers) is the same for all OMAP-derived parts as when CHSETTINGS are used, that's the same and our DDR base is also always the same. In order to make this common we simply need to update the names of the define for DDR address space which is also common. Cc: Sricharan R. <r.sricharan@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tom Rini <trini@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2014-05-23ARM: DRA72x: Add Silicon ID supportLokesh Vutla
Add silicon ID code for DRA722 silicon. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Tom Rini <trini@ti.com>
2014-05-23ARM: omap: merge GPMC initialization code for all platformpekon gupta
GPMC controller on TI's OMAP SoC is general purpose controller to interface with different types of external devices like; - parallel NOR flash - parallel NAND flash - OneNand flash - SDR RAM - Ethernet Devices like LAN9220 Though GPMC configurations may be different for each platform depending on clock-frequency and external device interfacing with controller. But initialization sequence remains common across all platfoms. Thus this patch merges gpmc_init() scattered in different arch-xx/mem.c files into single omap-common/mem-common.c However, actual platforms specific register config values are still sourced from corresponding platform specific headers like; AM33xx: arch/arm/include/asm/arch-am33xx/mem.h OMAP3: arch/arm/include/asm/arch-omap3/mem.h OMAP4: arch/arm/include/asm/arch-omap4/mem.h OMAP4: arch/arm/include/asm/arch-omap5/mem.h Also, CONFIG_xx passed by board-profile decide config for which set of macros need to be used for initialization CONFIG_NAND: initialize GPMC for NAND device CONFIG_NOR: initialize GPMC for NOR device CONFIG_ONENAND: initialize GPMC for ONENAND device Signed-off-by: Pekon Gupta <pekon@ti.com> [trini: define GPMC_SIZE_256M for omap3] Signed-off-by: Tom Rini <trini@ti.com>
2014-05-23Merge branch 'u-boot-sh/rmobile' into 'u-boot-arm/master'Albert ARIBAUD
2014-05-23Merge branch 'u-boot-microblaze/zynq' into 'u-boot-arm/master'Albert ARIBAUD
2014-05-23ARM: omap5: add platform specific info for GPMC and ELM controllerspekon gupta
This patch moves platform specific information for GPMC and ELM controller into separate header files, so that any derivative devices do not mess other header files. Platform specific information added into arch-xx/../hardware.h - CPU related platform specific details like base-address of GPMC and ELM Platform specific information added into arch-xx/../mem.h - Generic configs for GPMC and ELM initialization. - Hardware parameters or constrains specific to GPMC and ELM IP like; number of max number of chip-selects available Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-05-23ARM: omap4: add platform specific info for GPMC and ELM controllerspekon gupta
2014-05-22Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-05-21arm: rmobile: koelsch: Fix QoS revision 0.240 and 0.320Nobuhiro Iwamatsu
Add register define of DBSC3 operation adjustment register, and add initial value. Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-05-21gpio: r8a7790-gpio: Fix typo in macroNobuhiro Iwamatsu
Fix typo from __ASM_R8A7790_H__ to __ASM_R8A7790_GPIO_H__. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-05-21gpio: r8a7791-gpio: Fix typo in macroNobuhiro Iwamatsu
Fix typo from __ASM_R8A7791_H__ to __ASM_R8A7791_GPIO_H__. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-05-21arm: rmobile: Add define of SCIF register for R8A7790 and R8A7791Nobuhiro Iwamatsu
2014-05-20Merge remote-tracking branch 'u-boot/master'Albert ARIBAUD
Conflicts: boards.cfg Conflicts were trivial once u-boot-arm/master boards.cfg was reformatted (commit 6130c146) to match u-boot/master's own reformatting (commit 1b37fa83).
2014-05-16Merge remote-tracking branch 'u-boot-sh/rmobile'Albert ARIBAUD
Conflicts: boards.cfg Trivial conflict, maintainer change plus board addition
2014-05-16Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-05-16Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-05-15Merge branch 'u-boot-tegra/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-05-15Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-05-15Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
2014-05-15usb: tegra: support device modeStephen Warren
A few changes are made to the Tegra EHCI driver so that it can set everything up for device-mode operation on the first USB controller. This can be used in conjunction with ci_udc.c to operate as a USB device. Detailed changes are: * Rename set_host_mode() to set_up_vbus() since that's really what it does. * Modify set_up_vbus() to know whether it's initializing in host or device mode, and: - Skip the external VBUS check in device mode, since external VBUS is expected in this case. - Disable VBUS output in device mode. * Modify init_phy_mux() to know whether it's initializing in host or device mode, and hence skip setting USBMODE_CM_HC (which enables host mode) in device mode. See the comments in that function for why this is safe w.r.t. the ordering requirements of PHY selection. * Modify init_utmi_usb_controller() to force "b session valid" in device mode, since the HW requires this. This is done in UTMI-specific code, since we only support device mode on the first USB controller, and that controller can only talk to a UTMI PHY. * Enhance ehci_hcd_init() to error-check the requested host-/device-mode vs. the dr_mode (dual-role mode) value present in device tree, and the HW configurations which support device mode. * Enhance ehci_hcd_init() not to skip HW initialization when switching between host and device mode on a controller. This requires remembering which mode the last initialization used. Cc: Jim Lin <jilin@nvidia.com> Cc: Stefan Agner <stefan@agner.ch> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-05-14ARM: zynq: ehci: Added USB host driver supportMichal Simek
Added USB host driver for zynq. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-14ARM: zynq: Add MIO detection codeMichal Simek
Add run-time MIO pin detection to get actual pin configuration for specific periphery. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-14ARM: zynq: Fix bootmode maskMike Looijmans
Bootmode mask was defined as 0x0F, but documentation mentions 0x07. Experiments show that bit "3" is the JTAG chain configuration. Change the mask to "7" to allow systems with a different chain configuration to boot correctly. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Acked-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-14ARM: zynq: Added efuse status register base addressSiva Durga Prasad Paladugu
Added efuse status register base address. This register is used for determining whether efuse was blown or not. Also, added the zynq_get_silicon_version() to get the silicon version of the zynq board. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13ARM: OMAP5: add CKO buffer control maskDmitry Lifshitz
Add CKOBUFFER_CLK_EN bit mask enabling FREF_XTAL_CLK clock. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
2014-05-13ARM: OMAP5: add UART4 supportDmitry Lifshitz
Add UART4 base address. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
2014-05-13am33xx: add SSC enable macroYegor Yefremov
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
2014-05-13ARM: tegra: add function to enable input clamping on tristateStephen Warren
The HW-defined procedure for booting Tegra requires that CLAMP_INPUTS_WHEN_TRISTATED be enabled before programming the pinmux. Add a function to the pinmux driver to allow boards to do this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-05-13ARM: tegra: add GPIO initialization table functionStephen Warren
The HW-defined procedure for booting Tegra requires that some pins be set up as GPIOs immediately at boot in order to avoid glitches on those pins, when the pinmux is programmed. Add a feature to the GPIO driver which executes a GPIO configuration table. Board files will use this to implement the correct HW initialization procedure. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-05-13ARM: tegra: allow pinmux mux option not to be set by init tablesStephen Warren
Define enum PMUX_FUNC_DEFAULT, which indicates that a table entry passed to pinmux_config_pingrp()/pinmux_config_pingrp_table() shouldn't change the mux option in HW. For pins that will be used as GPIOs, the mux option is irrelevant, so we simply don't want to define any mux option in the pinmux initialization table. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-05-13ARM: tegra: set CONFIG_SYS_MMC_MAX_DEVICEStephen Warren
If CONFIG_API is ever to be enabled on Tegra, this define must be set, since api/api_storage.c uses it. A couple of annoyting things about CONFIG_SYS_MMC_MAX_DEVICE 1) It isn't documented in README. The same is true for a lot of similar defines used by api_storage.c. 2) It doesn't represent MAX_DEVICE but rather NUM_DEVICES, since the valid values are 0..n-1 not 0..n. However, I this patch does not address those shortcomings. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-05-13S5P: Exynos: Add GPIO pin numbering and rename definitionsAkshay Saraswat
This patch includes following changes : * Adds gpio pin numbering support for EXYNOS SOCs. To have consistent 0..n-1 GPIO numbering the banks are divided into different parts where ever they have holes in them. * Rename GPIO definitions from GPIO_... to S5P_GPIO_... These changes were done to enable cmd_gpio for EXYNOS and cmd_gpio has GPIO_INPUT same as s5p_gpio driver and hence getting a error during compilation. * Adds support for name to gpio conversion in s5p_gpio to enable gpio command EXYNOS SoCs. Function has been added to asm/gpio.h to decode the input gpio name to gpio number. Example: SMDK5420 # gpio set gpa00 Signed-off-by: Leela Krishna Amudala <l.krishna@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-12common/board_f: Initialized global data for generic boardYork Sun
Some platforms (tested on mpc85xx, mpc86xx) use global data before calling function baord_inti_f(). The data should not be cleared later. Any arch which uses global data in generic board board_init_f() should define CONFIG_SYS_GENERIC_GLOBAL_DATA. Signed-off-by: York Sun <yorksun@freescale.com> CC: Scott Wood <scottwood@freescale.com> CC: Simon Glass <sjg@chromium.org> CC: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-12bd_info: remove bi_barudrate member from struct bd_infoMasahiro Yamada
gd->bd->bi_baudrate is a copy of gd->baudrate. Since baudrate is a common feature for all architectures, keep gd->baudrate only. It is true that bi_baudrate was passed to the kernel in that structure but it was a long time ago. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
2014-05-09imx25: Add new hardware registersThomas Diener
Signed-off-by: Thomas Diener <dietho@gmx.de>
2014-05-09iomux-v3: Add support for mx6sl LVE bitFabio Estevam
On mx6sl there is a LVE (Low Voltage Enable) bit in the IOMUXC_SW_PAD_CTL register that can enable or disable low voltage on the pad. LVE is bit 22 of IOMUXC_SW_PAD_CTL register, but in order to make the calculation easier we can define it as a flag in bit 1, since this bit is unused. Add support for it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Otavio Salvador <otavio@ossystems.com.br>
2014-05-09Merge branch 'u-boot/master'Albert ARIBAUD
Conflicts: drivers/net/Makefile (trivial merge)
2014-04-30usb: ehci: rmobile: Add support ehci host driver of rmobile SoCsNobuhiro Iwamatsu
The rmobile SoC has usb host controller. This supports USB controllers listed in the R8A7790, R8A7791 and R8A7740. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Reviewed-by: Marek Vasut <marex@denx.de>
2014-04-29Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
2014-04-28mx6slevk: Add SPI NOR flash supportFabio Estevam
mx6slevk has a m25p32 SPI NOR flash connected to ESCSPI port. Add support for it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-04-28arm: rmobile: Add register infomation of PLL regsiterNobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-28arm: rmobile: r8a7791: Add support ES2 revisionNobuhiro Iwamatsu
There is ES2 is a new revision to R8A7791. This adds support this revision. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-28arm: rmobile: r8a7790: Add support ES2 revisionNobuhiro Iwamatsu
There is ES2 is a new revision to R8A7790. This adds support this revision. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-28arm: rmobile: Add prototype for function to get the CPU information to rmobile.hNobuhiro Iwamatsu
These functions are defined but has no prototype declaration. Add them. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-28arm: rmobile: Coordinate the common part of the header file of r8a7790 and ↵Nobuhiro Iwamatsu
r8a7791 Header files of R8A7790 and R8A7791 have common part of many. This coordinates as rcar-base.h. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-21Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-04-17arm, da850: staticize funtionsManish Badarkhe
Make funtions static which are locally used in file and remove the declaration from header file. Signed-off-by: Manish Badarkhe <badarkhe.manish@gmail.com>
2014-04-17keystone2: net: add keystone ethernet driverKaricheri, Muralidharan
Ethernet driver configures the CPSW, SGMI and Phy and uses the the Navigator APIs. The driver supports 4 Ethernet ports and can work with only one port at a time. Port configurations are defined in board.c. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: WingMan Kwok <w-kwok2@ti.com>
2014-04-17keystone2: add keystone multicore navigator driverVitaly Andrianov
Multicore navigator consists of Network Coprocessor (NetCP) and Queue Manager sub system. More details on the hardware can be obtained from the following links:- Network Coprocessor: http://www.ti.com/lit/pdf/sprugz6 Multicore Navigator: http://www.ti.com/lit/pdf/sprugr9 Multicore navigator driver implements APIs to configure the Queue Manager and NetCP Pkt DMA. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: WingMan Kwok <w-kwok2@ti.com> Acked-by: Tom Rini <trini@ti.com>
