Previously, because we have no source code about the DRAM initialization
of V3s and missing some configurations (delays and MBUS QoS info), our
V3s DRAM initialization sequence is hacked from the H3 one.
As the SDK shipped with PineCube contains source code for V3s libdram,
we can retrieve these information from it and tweak some other magic
bits.
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
The registers which are managed by the meson-gxl-usb3 PHY driver are
actually "USB control" registers (which are "glue" registers which
manage OTG detection and routing of the OTG capable port between the
DWC2 peripheral-only controller and the DWC3 host-only controller).
Drop the meson-gxl-usb3 PHY driver now that the dwc3-meson-gxl-usb
driver supports the USB control registers on GXL and GXM SoCs (these
were previously managed by the meson-gxl-usb3 PHY driver).
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
The USB support was initialy done with a set of PHYs and dwc3-of-simple
because the architecture of the USB complex was not understood correctly
at the time (and proper documentation was missing...).
But with the G12A family, the USB complex was correctly understood and
implemented correctly.
This adds a proper driver for the glue, based on the G12A one, but with
enough changes to require a different driver in U-Boot.
Latest datasheet revE has removed MIMX8ML7D/5D/7C/5C parts, so
update u-boot to remove decoding and support for those parts.
Signed-off-by: Ye Li <ye.li@nxp.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Fix SSCG_PLL_REFCLK_SEL_x, the offset starts from 0, not 16
Reported-by: Coverity 3448860
Reviewed-by: Ye Li <ye.li@nxp.com>
Coverity reported dead code, however it is FRAC_PLL_REFCLK_SEL_MASK
was wrongly set.
Reported-by: Coverity 10045172
According to i.MX 7Dual Applications Processor Reference Manual, Rev. 1
The target interface CCM root index ranges [0,124], so the number
should be 125.
Reported-by: Coverity 18045
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
For 2020.10
- mx6: SOCs user selectable
Fix for imx6q_logic
Some DM conversion
- mx7: introduce secondary boot device
Travis: https://travis-ci.org/github/sbabic/u-boot-imx/builds/720918010
- Add basic Marvell/Cavium OcteonTX/TX2 support (Suneel)
- Infrastructure changes to PCI uclass to support these SoC's (Suneel)
- Add PCI, MMC & watchdog driver drivers for OcteonTX/TX2 (Suneel)
- Increase CONFIG_SYS_MALLOC_F_LEN for qemu-x86 (Stefan)
Signed-off-by: Suneel Garapati <sgarapati@marvell.com>
Add 64bit API for clrbits and setbits.
Total Compute is based on ARM architecture and has
the following features enabled in u-boot:
- PL011 UART
- PL180 MMC
- NOR Flash
- FIT image with Signature
- AVB
Signed-off-by: Usama Arif <usama.arif@arm.com>
Fill is code for programming the DDR_PHY_CMD_DESKEW_CONx registers,
which are optional, but can be used to fill in the byte lane delays.
Cc: Fabio Estevam <festevam@gmail.com>
Cc: NXP i.MX U-Boot Team <uboot-imx@nxp.com>
Cc: Peng Fan <peng.fan@nxp.com>
The i.MX6/i.MX7 is capable of booting a secondary "redundant" system
image in case the primary one is corrupted. The user can force this
boot mode as well by explicitly setting SRC GPR10 bit 30. This can be
potentially useful when upgrading the bootloader itself. Expose this
functionality to the user.
Reviewed-by: Stefano Babic <sbabic@denx.de>
Add the basic differentiation between i.MX6 and i.MX7 into the bmode
command, the mechanism really works almost the same on both platforms.
Port hypervisor related code from Mini-OS. This is referencing the code
of Mini-OS from [1] by Huang Shijie and Volodymyr Babchuk which is for
ARM64.
Update essential arch code to support required bit operations, memory
barriers etc.
Copyright for the bits ported belong to at least the following authors,
please see related files for details:
Copyright (c) 2002-2003, K A Fraser
Copyright (c) 2005, Grzegorz Milos, gm281@cam.ac.uk,Intel Research Cambridge
Copyright (c) 2014, Karim Allah Ahmed <karim.allah.ahmed@gmail.com>
[1] - https://github.com/zyzii/mini-os.git
Signed-off-by: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com>
Signed-off-by: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com>
[trini: Drop wmb() from musb-net/linux-compat.h now]
Introduce a minimal Xen guest board running as a virtual
machine under Xen Project's hypervisor [1], [2].
Part of the code is ported from Xen mini-os and also uses
work initially done by different authors from NXP: please see
relevant files for their copyrights.
[1] https://xenbits.xen.org
[2] https://wiki.xenproject.org/
Signed-off-by: Andrii Anisov <andrii_anisov@epam.com>
The hardcoded platform variables such as DRAM base address are not
common to Aspeed SoCs AST24xx/AST25xx/AST26xx. This patch replaces
those hardcoded with macros defined in a newly added header, where
the basic SoC HW information are assigned accordingly.
Signed-off-by: Chia-Wei, Wang <chiawei_wang@aspeedtech.com>
This header file should not be included in other header files. Remove it
and use a forward declaration instead.
Use device tree and UCLASS_SYSCON driver to get
Generic Interrupt Controller (GIC) lpi address and
maximum GIC redistributors count.
Also update Kconfig to select REGMAP and SYSCON when
GIC_V3_ITS is enabled.
Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com>
As no gpio.h is defined for this architecture, to avoid
compilation failure, do not include <asm/arch/gpio.h> for
arch bcmns3.
Add API to save boot parameters passed from BL31
Use assembly implementation of save_boot_params instead of c function.
Because generally ATF does not set up SP_EL2 on exiting.
Thus, usage of a C function immediately after exiting with no stack
setup done by ATF explicitly, may cause SP_EL2 to be not sane,
which in turn causes a crash if this boot was not lucky to get
an SP_EL2 in valid range. Replace C implementation with assembly one
which does not use stack this early, and let u-boot to set up its stack
later.
Signed-off-by: Abhishek Shah <abhishek.shah@broadcom.com>
Signed-off-by: Rajesh Ravi <rajesh.ravi@broadcom.com>
Signed-off-by: Vladimir Olovyannikov <vladimir.olovyannikov@broadcom.com>
The LPAE versions of DCACHE_WRITEBACK and DCACHE_WRITETHROUGH are currently
defined as no-allocate for both reads and writes, which deviates from the
non-LPAE definition, and mostly defeats the purpose of enabling the caches
in the first place.
So align LPAE with !LPAE, and enable allocate-on-read for both. And while
at it, add some clarification about the meaning of the chosen values.
Signed-off-by: Ard Biesheuvel <ardb@kernel.org>
Add a new variable secondary_boot_code_start, which holds a pointer to
the start of the spin table code. This will help to relocate the code
section. While at it, move the size variable from the end to the
beginning so there is a common section for the variables. Remove any
other symbols.
Signed-off-by: Michael Walle <michael@walle.cc>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Only the PowerPC architecture needs this function. Remove it.
The generic armv8 code already has support to bring up the secondary
cores. Thus, don't hardcode the jump in the layerscape lowlevel_init to
the spin table code; instead just return early and let the common armv8
code handle the jump. This way we can actually use the CPU_RELEASE_ADDR
feature.
[Rebased, Removed kontron_sl28.h change as file does not exist]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Enable the gpio feature on fsl-layerscape platform.
Signed-off-by: hui.song <hui.song_1@nxp.com>
add one struct mpc8xxx_gpio_plat to enable gpio feature.
reset cause is a generic functionality based on the soc
cru registers in rockchip. This can be used for printing
the cause of reset in cpuinfo or some other place where
reset cause is needed.
Other than cpuinfo, reset cause can also be using during
bootcount for checking the specific reset cause and glow
the led based on the reset cause.
So, let's separate the reset cause code from cpuinfo, and
add a check to build it for rk3399, rk3288 since these two
soc are supporting reset cause as of now.
Tested-by: Suniel Mahesh <sunil@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
reset reason can be used several stages of U-Boot bootloader
like SPL, U-Boot proper based on the requirements.
Clearing the status register end of get_reset_cause will end
up showing the wrong reset cause when it read the second time.
For example, if board resets, SPL reads the reset status as
RST whereas U-Boot proper reads the status as POR.
However, based on the latest testing clearing reset status
won't be required for determine the last reset cause or
following resets.
Rockchip SoC's has a new revision chip for rk3288 SoCs.
RK3288 has a new revision chip called RK3288W which is similar
but different hclk_vio clock and fixed OHCI host.
Add common Rockchip SoC detection helper to support this rk3288w
detection.
The empty function define should not be in the header file, or else the
build will error with function multi definition after CONFIG_RAM_ROCKCHIP_DEBUG
is disabled.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
The Linux coding style guide (Documentation/process/coding-style.rst)
clearly says:
It's a **mistake** to use typedef for structures and pointers.
Besides, using typedef for structures is annoying when you try to make
headers self-contained.
Let's say you have the following function declaration in a header:
void foo(bd_t *bd);
This is not self-contained since bd_t is not defined.
To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h>
#include <asm/u-boot.h>
void foo(bd_t *bd);
Then, the include direcective pulls in more bloat needlessly.
If you use 'struct bd_info' instead, it is enough to put a forward
declaration as follows:
struct bd_info;
void foo(struct bd_info *bd);
Right, typedef'ing bd_t is a mistake.
I used coccinelle to generate this commit.
The semantic patch that makes this change is as follows:
<smpl>
typedef bd_t;
-bd_t
+struct bd_info
</smpl>
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Add SCFW API sc_misc_get_boot_container to get current boot container
set index.
The index value returns 1 for primary container set, 2 for secondary
container set.
Reviewed-by: Peng Fan <peng.fan@nxp.com>
For non-Quad SoCs, the fused cpu cores could be powered down in SPL
to save power.
iMX8MP has 6 fused parts in each qualification tier, with core, VPU,
ISP, NPU or DSP fused respectively.
The configuration tables for enabled modules:
MIMX8ML8DVNLZAA Quad Core, VPU, NPU, ISP, DSP
MIMX8ML7DVNLZAA Quad Core, NPU, ISP
MIMX8ML6DVNLZAA Quad Core, VPU, ISP
MIMX8ML5DVNLZAA Quad Core, VPU
MIMX8ML4DVNLZAA Quad Lite
MIMX8ML3DVNLZAA Dual Core, VPU, NPU, ISP, DSP
Add the support in U-Boot
Add logic to automatically update umctl2's setting based
on phy training CDD value for rank to rank space issue
Acked-by: Ye Li <ye.li@nxp.com>
Signed-off-by: Oliver Chen <Oliver.Chen@nxp.com>
Signed-off-by: Jacky Bai <ping.bai@nxp.com>
the DRAM Controller in i.MX8MP will support a feature called "Inline ECC".
This is supported for all 3 supported DRAM technologies (LPDDR4, DDR4 and
DDR3L). When this feature is enabled by software, the DRAM Controller
reserves 12.5% of DRAM capacity for ECC information, and presents only
the non-ECC portion (lower 87.5% of the installed capacity of DRAM) to
the rest of the SoC.
The DRAM memory can be divided into 8 regions so that if a use case only
requires ECC protection on a subset of memory, then only that subset of
memory need support inline ECC. If this occurs, then there is no
performance penalty accessing the non-ECC-protected memory (no need to
access ECC for this portion of the memory map). This is all configured
with the DRAM Controller.
Signed-off-by: Sherry Sun <sherry.sun@nxp.com>
Provide function for setting arbitrary virtual-physical MMU mapping
and cache settings for the given region.
Update the comments in include/asm/system.h to the common style.
Compiling with clang on ARMv8 shows errors like:
./arch/arm/include/asm/system.h:162:32: note: use constraint modifier "w"
asm volatile("msr sctlr_el1, %0" : : "r" (val) : "cc");
%w0
These errors are due to using an incorrect size for the variables used
for writing to and reading from special registers which have 64 bits on
ARMv8.
Mask off reserved bits when reading the exception level.
Clang 9 supports -ffixed-x18.
This patchs adds glue logic to enable designware mac present on
Action Semi based S700 SoC, Configures SoC specific bits.
Undocumented bit that programs the PHY interface select register
comes from vendor source.
It has been tested on Cubieboard7-lite based on S700 SoC.
Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
This commit adds clocks needed for ethernet operations for
Actions OWL family of SoCs (S700 and S900).
The iMX7 defines further DDRC ZQCTLx registers, however those were
thus far missing from the list of registers and not programmed. On
systems with LPDDR2 or DDR3, those registers must be programmed with
correct values, otherwise the DRAM may not work. However, existing
systems which worked without programming these registers before are
now setting those registers to 0, which is the default value, so no
functional change there.
The iMX7D RM 9.2.4.9.3 Power removal flow Table 9-11. Re-enabling power
explicitly says both the DDR controller and the PHY must be reset in the
correct sequence. Currently the code only resets the controller. This
leads to a misbehavior where the system brings the DRAM up after reboot,
but the DRAM is unstable. Add the missing reset.
The easiest way to trigger this is by triggering WDT without having the
WDT assert WDOG_B signal, i.e. mw.w 0x30280000 0x25 .
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for efi-2020-07-rc4
This patch series addresses the following issues:
* allow compiling with clang
* add missing function descriptions to the HTML documentation
* simplify the validation of UEFI images
* validate load options in the UEFI boot manager
In a preparatory patch a structure definition is moved.
On ARM systems gd is stored in register r9 or x18. When compiling with
clang gd is defined as a macro calling function gd_ptr(). So we can not
make assignments to gd.
In the UEFI sub-system we need to save gd when leaving to UEFI binaries and
have to restore gd when reentering U-Boot.
Define a new function set_gd() for setting gd and use it in the UEFI
sub-system.
Tested-by: Tom Rini <trini@konsulko.com>
arch/arm/include/asm/system.h declares psci_arch_init(), but it is
surrounded by #ifdef CONFIG_ARMV8_PSCI.
psci_arch_init() is called for CONFIG_ARMV7_PSCI too. Add the missing
function declaration.
