path: root/arch/arm/include
2017-01-11tegra: lcd: video: integrate display driver for t30Marcel Ziswiler
On popular request make the display driver from T20 work on T30 as well. Turned out to be quite straight forward. However a few notes about some things encountered during porting: Of course the T30 device tree was completely missing host1x as well as PWM support but it turns out this can simply be copied from T20. The only trouble compiling the Tegra video driver for T30 had to do with some hard-coded PWM pin muxing for T20 which is quite ugly anyway. On T30 this gets handled by a board specific complete pin muxing table. The older Chromium U-Boot 2011.06 which to my knowledge was the only prior attempt at enabling a display driver for T30 for whatever reason got some clocking stuff mixed up. Turns out at least for a single display controller T20 and T30 can be clocked quite similar. Enjoy. (cherry picked from commit 5a472ddd7a2a017747d6c05c65eba2cd3804c02f)
2017-01-11video: dcu: Add DCU support for Vybrid SoCStefan Agner
The Vybrid SoC family has the same display controller unit (DCU) like the LS1021A SoC. This patch adds platform data, pinmux defines and clock control to enable the driver for Vybrid based boards too. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-11imx-common: add declaration for arch_auxiliary_core_check_upStefan Agner
Add declaration for arch_auxiliary_core_check_up which can be useful to add board specific behavior. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11MLK-12693-2 nand: mxs: correct bitflip for erased NAND pagePeng Fan
This patch is a porting of http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/commit/?h=imx_4.1.15_1.0.0_ga&id=e4dacc44d22e9474ec456cb330df525cd805ea38 " i.MX6QP and i.MX7D BCH module integrated a new feature to detect the bitflip number for erased NAND page. So for these two platform, set the erase threshold to gf/2 and if bitflip detected, GPMI driver will correct the data to all 0xFF. Also updated the imx6qp dts file to ditinguish the GPMI module for i.MX6Q with the one for i.MX6QP. " In this patch, i.MX6UL is added and threshold changed to use ecc_strength. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2017-01-11mmc: tegra: allow disabling external clock loopbackMarcel Ziswiler
Introduce CONFIG_TEGRA124_MMC_DISABLE_EXT_LOOPBACK to disable the external clock loopback and use the internal one on SDMMC3 as per the SDMMC_VENDOR_MISC_CNTRL_0 register's SDMMC_SPARE1 bits being set to 0xfffd according to the TRM. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11imx: make ipu's di configurableMax Krummenacher
The ipu has two display interfaces. Make the used one a parameter in struct display_info_t instead of using unconditionally DI0. DI0 is the default setting. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Reviewed-by: Eric Nelson <eric@nelint.com> (cherry picked from commit 15fde0fc11f93f19f40c9cda36e7c8d4848d9c75)
2016-11-13arm: Set TTB XN bit in case DCACHE_OFF for LPAE modeKeerthy
While we setup the mmu initially we mark set_section_dcache with DCACHE_OFF flag. In case of non-LPAE mode the DCACHE_OFF macro is rightly defined with TTB_SECT_XN_MASK set so as to mark all the 4GB XN. In case of LPAE mode XN(Execute-never) bit is not set with DCACHE_OFF. Hence XN bit is not set by default for DCACHE_OFF which keeps all the regions execute okay and this leads to random speculative fetches in random memory regions which was eventually caught by kernel omap-l3-noc driver. Fix this to mark the regions as XN by default. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-11-07armv8: add hooks for all cache-wide operationsStephen Warren
SoC-specific logic may be required for all forms of cache-wide operations; invalidate and flush of both dcache and icache (note that only 3 of the 4 possible combinations make sense, since the icache never contains dirty lines). This patch adds an optional hook for all implemented cache-wide operations, and renames the one existing hook to better represent exactly which operation it is implementing. A dummy no-op implementation of each hook is provided. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-10-30rk3288: sdram: auto-detect the capacityKever Yang
Add support for rk3288 dram capacity auto detect, support DDR3 and LPDDR3, DDR2 is not supported. The program will automatically detect: - channel number - rank number - column address number - row address number The dts file do not need to describe those info after apply this patch. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Tested-by: Simon Glass <sjg@chromium.org> Tested-by: Vagrant Cascadian <vagrant@debian.org> Tested-by: Vagrant Cascadian <vagrant@debian.org>
2016-10-30rockchip: rk3288: Move rockchip_get_cru() out of the driverSimon Glass
This function is called from outside the driver. It should be placed into common SoC code. Move it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2016-10-30rockchip: rk3399: Move rockchip_get_cru() out of the driverSimon Glass
This function is called from outside the driver. It should be placed into common SoC code. Move it. Also rename the driver symbol to be more consistent with the other rockchip clock drivers. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2016-10-30rockchip: rk3036: Move rockchip_get_cru() out of the driverSimon Glass
2016-10-30sunxi: Add support for SID e-fuses on sun9iChen-Yu Tsai
The A80 has SID e-fuses. Like other newer SoCs, the actual e-fuses are at an offset of 0x200 within the SID address space. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-10-30sunxi: add initial clock setup for sun9i for SPLPhilipp Tomsich
This is a cleaned up version set_pll() from Allwinner's boot0 source (bootloader/basic_loader/bsp/bsp_for_a80/common/common.c). [wens@csie.org: Added commit message; style cleanup] Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-10-30sunxi: add gtbus-initialisation for sun9iPhilipp Tomsich
On sun9i, the GTBUS manages transaction priority and bandwidth for multiple read ports when accessing DRAM. The initialisation mirrors the settings from Allwinner's boot0 for now, even though this may not be optimal for all applications (e.g. headless systems might want to give priority to IO modules). Adding a common callout to gtbus_init() from the SPL clock init with a weakly defined implementation in sunxi/clock.c to fallback to for platforms that don't require this. [wens@csie.org: Moved gtbus_sun9i.c to arch/arm/mach-sunxi/; style cleanup] Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-10-30sunxi: DRAM initialisation for sun9iPhilipp Tomsich
This adds DRAM initialisation code for sun9i, which calculates the appropriate timings based on timing information for the supplied DDR3 bin and the clock speeds used. With this DRAM setup, we have verified DDR3 clocks of up to 792MHz (i.e. DDR3-1600) on the A80-Q7 using a dual-channel configuration. [wens@csie.org: Moved dram_sun9i.c to arch/arm/mach-sunxi/; style cleanup] Signed-off-by: Chen-Yu Tsai <wens@csie.org> [hdegoede@redhat.com: Drop some huge non-documenting #if 0 ... #endif blocks] [hdegoede@redhat.com: Fix checkpatch warnings] Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-10-30sunxi: A64: enable USB supportAmit Singh Tomar
Mostly by adding MACH_SUN50I to some existing #ifdefs enable support for the the HCI0 USB host controller on the A64. Fix up some minor 64-bit hiccups on the way. Add the bare minimum DT bits to the A64 .dtsi and enable the controllers and the PHY on the Pine64. This is limited to the first USB controller at the moment, which is connected to the lower USB socket on the Pine64 board. [Andre: remove unneeded defines, enable OHCI, add commit message] Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com> Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-10-28Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: common/Kconfig configs/dms-ba16_defconfig
2016-10-26arm: imx: Add Engicam i.CoreM6 QDL Starter Kit initial supportJagan Teki
Boot Log for i.CoreM6 DualLite/Solo Starter Kit: ----------------------------------------------- U-Boot SPL 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46) Trying to boot from MMC1 U-Boot 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46 +0530) CPU: Freescale i.MX6SOLO rev1.3 at 792MHz CPU: Industrial temperature grade (-40C to 105C) at 31C Reset cause: POR DRAM: 256 MiB MMC: FSL_SDHC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: CPU Net Initialization Failed No ethernet found. Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device switch to partitions #0, OK mmc0 is current device reading boot.scr ** Unable to read file boot.scr ** reading zImage 6741808 bytes read in 341 ms (18.9 MiB/s) Booting from mmc ... reading imx6dl-icore.dtb 30600 bytes read in 19 ms (1.5 MiB/s) Booting using the fdt blob at 0x18000000 Using Device Tree in place at 18000000, end 1800a787 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 Boot Log for i.CoreM6 Quad/Dual Starter Kit: -------------------------------------------- U-Boot SPL 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46) Trying to boot from MMC1 U-Boot 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46 +0530) CPU: Freescale i.MX6Q rev1.2 at 792MHz CPU: Industrial temperature grade (-40C to 105C) at 28C Reset cause: POR DRAM: 512 MiB MMC: FSL_SDHC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: CPU Net Initialization Failed No ethernet found. Hit any key to stop autoboot: 0 icorem6qdl> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Acked-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-24imx: mx7: Add plugin supportPeng Fan
Add mx7_plugin.S which calls boot rom setup function, generate the second ivt, and jump back to boot rom. Signed-off-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Ye Li <ye.li@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-24imx: mx6: Add plugin supportPeng Fan
Add mx6_plugin.S which calls boot rom setup function, generate the second ivt, and jump back to boot rom. Signed-off-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Utkarsh Gupta <utkarsh.gupta@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Utkarsh Gupta <utkarsh.gupta@nxp.com>
2016-10-18arm: Add PSCI shutdown functionAlexander Graf
Using PSCI you can not only reset the system, you can also shut it down! This patch exposes a function to do exactly that to whatever code wants to make use of it. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-18arm: Disable HVC PSCI calls by defaultAlexander Graf
All systems that are running on armv8 are running bare metal with firmware that implements PSCI running in EL3. That means we don't really need to expose the hypercall variants of them. This patch leaves the code in, but makes the code explicit enough to have the compiler optimize it out. With this we don't need to worry about hvc vs smc calling convention when calling psci helper functions. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-12Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: include/configs/ls1021aqds.h include/configs/ls1021atwr.h
2016-10-08Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-10-08ARM: AM437X: Add Silicon ID supportLokesh Vutla
Add silicon ID code for AM437x silicon. This can be used to print the cpu info using CONFIG_DISPLAY_CPUINFO. Also printing "CPU :" along with cpu name in order to be consistent with other OMAP platforms. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-10-08arm: Add return value argument to longjmpAlexander Graf
The normal longjmp command allows for a caller to pass the return value of the setjmp() invocation. This patch adds that semantic to the arm implementation of it and adjusts the efi_loader call respectively. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-08ARM: keystone: rename clk_get_rate() to ks_clk_get_rate()Masahiro Yamada
The KeyStone platform has its own clk_get_rate() but its prototype is different from that of the common-clk (clk-uclass) framework. Prefix the KeyStone specific implementation with ks_ in order to avoid name-space conflict. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06ARM: Add register defines for am33xx ePWM registerstomas.melin@vaisala.com
Register definitions needed for configuring the ePWM module. Signed-off-by: Tomas Melin <tomas.melin@vaisala.com>
2016-10-06ARM: Introduce function to switch to hypervisor modeKeerthy
On some of the SoCs one cannot enable hypervisor mode directly from the u-boot because the ROM code puts the chip to supervisor mode after it jumps to boot loader. Hence introduce a weak function which can be overridden based on the SoC type and switch to hypervisor mode in a custom way. Cc: beagleboard-x15@googlegroups.com Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06ARM64: Add support for some of atomic64 operationsAdam Oleksy
These functions are needed in UBI/UBIFS on ZynqMP platform (ARM64). Signed-off-by: Adam Oleksy <adam.oleksy@nokia.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2016-10-06Various, accumulated typos collected from around the tree.Robert P. J. Day
Fix various misspellings of: * deprecated * partition * preceding,preceded * preparation * its versus it's * export * existing * scenario * redundant * remaining * value * architecture Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Stefan Roese <sr@denx.de>
2016-10-06spl: Move spl_board_load_image() into a generic headerSimon Glass
At present this is only used on ARM and sandbox, but it is just as applicable to other architectures. Move the function prototype into the generic SPL header. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06armv7: ls1021a: Move DDR config options to KconfigYork Sun
Move DDR3, DDR4 and related config options to Kconfig and clean up existing uses. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-06armv8: fsl-layerscape: Move DDR config options to KconfigYork Sun
Move DDR3, DDR4 and realted options to Kconfig and clean up existing uses. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-06arm: Move SYS_FSL_SRDS_* and SYS_HAS_SERDES to KconfigYork Sun
Move these options to Kconfig and clean up existing uses. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-06arm: Move FSL_HAS_DP_DDR and NUM_DDR_CONTROLLERS to KconfigYork Sun
Move this option to Kconfig and clean up existing uses. NUM_DDR_CONTROLLERS is also used by PowerPC SoCs. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-06arm: Move SYS_FSL_IFC_BANK_COUNT to KconfigYork Sun
Move this option to Kconfig and clean up existing uses. This option is also used by PowerPC SoCs. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-06arm: Move MAX_CPUS to KconfigYork Sun
Move MAX_CPUS option to Kconfig and clean up existing uses for ARM. This option is used by Freescale Layerscape SoCs. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-06armv8/fsl-lsch2: Implement workaround for PIN MUX erratum A010539Hou Zhiqiang
Pin mux logic has 2 options in priority order, one is through RCW_SRC and then through RCW_Fields. In case of QSPI booting, RCW_SRC logic takes the priority for SPI pads and do not allow RCW_BASE and SPI_EXT to control the SPI muxing. But actually those are DSPI controller's pads instead of QSPI controller's, so this workaround allows RCW fields SPI_BASE and SPI_EXT to control relevant pads muxing. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> [York Sun: Reformatted commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06armv8: fsl-layerscape: Fix "cpu status" commandYork Sun
The core position is not continuous for some SoCs. For example, valid cores may present at position 0, 1, 4, 5, 8, 9, etc. Some registers (including boot release register) only count existing cores. Current implementation of cpu_mask() complies with the continuous numbering. However, command "cpu status" queries the spin table with actual core position. Add functions to calculate core position from core number, to correctly calculate offsets. Tested on LS2080ARDB and LS1043ARDB. Signed-off-by: York Sun <york.sun@nxp.com>
2016-10-06armv8: fsl-lsch2: enable snoopable sata read and writeTang Yuantian
By default the SATA IP on the ls1043a/ls1046a SoCs does not generating coherent/snoopable transactions. This patch enable it in the SCFG_SNPCNFGCR register along with sata axicc register. In addition, the dma-coherent property must be set on the SATA controller nodes. Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com> [York Sun: Reformatted commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06armv8: fsl-lsch2: adjust sata parameterTang Yuantian
The default values for Port Phy2Cfg register and Port Phy3Cfg register are better, no need to overwrite them. Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-04imx-common: enlarge mux width to 4Peng Fan
For i.MX6, the mux width is 4, not 3. So enlarge the width. IOMUX_CONFIG_LPSR is changed from 0x8 to 0x20 to not use bit 3 of mux. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2016-10-04imx: iomux: fix snvs usage for i.MX6ULLPeng Fan
SNVS TAMPER pin and BOOT MODE pins are in SNVS IOMUXC module, not in IOMUXC, so correct the related registers' offset. Use IOMUX_CONFIG_LPSR flag for these pins, so we can differentiate them from iomuxc pins. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: "Benoît Thébaudeau" <benoit.thebaudeau.dev@gmail.com>
2016-10-04imx: imx6ull: adjust the ldo 1.2v bandgap voltagePeng Fan
Per to design team, on i.MX6UL, the LDO 1.2V bandgap voltage is 30mV higher, so we need to adjust the REFTOP_VBGADJ(anatop MISC0 bit[6:4]) setting to 2b'110. Signed-off-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Bai Ping <ping.bai@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2016-10-04imx: mx6ull: Update memory map addressPeng Fan
Update memory map address for mx6ull. Signed-off-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Ye Li <ye.li@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2016-10-04imx: mx6ull: update clock settings and CCM register mapPeng Fan
Update Clock settings and CCM register map for i.MX6ULL. Signed-off-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Ye Li <ye.li@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2016-10-04imx-common: introduce is_mx6ullPeng Fan
Introduce is_mx6ull macro. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2016-10-04imx: mx6ull: add mx6ull major cpu typePeng Fan
Add i.MX6ULL major cpu type. Signed-off-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Ye Li <ye.li@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de>
