path: root/arch/arm/include
2010-09-19ARM: add relocation supportHeiko Schocher
!! This breaks support for all arm boards !! To compile in old style, you must define CONFIG_SYS_ARM_WITHOUT_RELOC or you can compile with "CONFIG_SYS_ARM_WITHOUT_RELOC=1 ./MAKEALL board" !! This define will be removed soon, so convert your board to use relocation support Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de> Fix boot from NAND for non-ARM systems Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-19arm: get rid of bi_envHeiko Schocher
bi_env is nowhere used, so delete it! Signed-off-by: Heiko Schocher <hs@denx.de> similar patch posted from Dirk Behme Tue Jul 27 18:36:09 CEST 2010 http://lists.denx.de/pipermail/u-boot/2010-July/074542.html
2010-09-19New implementation for internal handling of environment variables.Wolfgang Denk
Motivation: * Old environment code used a pessimizing implementation: - variable lookup used linear search => slow - changed/added variables were added at the end, i. e. most frequently used variables had the slowest access times => slow - each setenv() would calculate the CRC32 checksum over the whole environment block => slow * "redundant" envrionment was locked down to two copies * No easy way to implement features like "reset to factory defaults", or to select one out of several pre-defined (previously saved) sets of environment settings ("profiles") * No easy way to import or export environment settings ====================================================================== API Changes: - Variable names starting with '#' are no longer allowed I didn't find any such variable names being used; it is highly recommended to follow standard conventions and start variable names with an alphanumeric character - "printenv" will now print a backslash at the end of all but the last lines of a multi-line variable value. Multi-line variables have never been formally defined, allthough there is no reason not to use them. Now we define rules how to deal with them, allowing for import and export. - Function forceenv() and the related code in saveenv() was removed. At the moment this is causing build problems for the only user of this code (schmoogie - which has no entry in MAINTAINERS); may be fixed later by implementing the "env set -f" feature. Inconsistencies: - "printenv" will '\\'-escape the '\n' in multi-line variables, while "printenv var" will not do that. ====================================================================== Advantages: - "printenv" output much better readable (sorted) - faster! - extendable (additional variable properties can be added) - new, powerful features like "factory reset" or easy switching between several different environment settings ("profiles") Disadvantages: - Image size grows by typically 5...7 KiB (might shrink a bit again on systems with redundant environment with a following patch series) ====================================================================== Implemented: - env command with subcommands: - env print [arg ...] same as "printenv": print environment - env set [-f] name [arg ...] same as "setenv": set (and delete) environment variables ["-f" - force setting even for read-only variables - not implemented yet.] - end delete [-f] name not implemented yet ["-f" - force delete even for read-only variables] - env save same as "saveenv": save environment - env export [-t | -b | -c] addr [size] export internal representation (hash table) in formats usable for persistent storage or processing: -t: export as text format; if size is given, data will be padded with '\0' bytes; if not, one terminating '\0' will be added (which is included in the "filesize" setting so you can for exmple copy this to flash and keep the termination). -b: export as binary format (name=value pairs separated by '\0', list end marked by double "\0\0") -c: export as checksum protected environment format as used for example by "saveenv" command addr: memory address where environment gets stored size: size of output buffer With "-c" and size is NOT given, then the export command will format the data as currently used for the persistent storage, i. e. it will use CONFIG_ENV_SECT_SIZE as output block size and prepend a valid CRC32 checksum and, in case of resundant environment, a "current" redundancy flag. If size is given, this value will be used instead of CONFIG_ENV_SECT_SIZE; again, CRC32 checksum and redundancy flag will be inserted. With "-b" and "-t", always only the real data (including a terminating '\0' byte) will be written; here the optional size argument will be used to make sure not to overflow the user provided buffer; the command will abort if the size is not sufficient. Any remainign space will be '\0' padded. On successful return, the variable "filesize" will be set. Note that filesize includes the trailing/terminating '\0' byte(s). Usage szenario: create a text snapshot/backup of the current settings: => env export -t 100000 => era ${backup_addr} +${filesize} => cp.b 100000 ${backup_addr} ${filesize} Re-import this snapshot, deleting all other settings: => env import -d -t ${backup_addr} - env import [-d] [-t | -b | -c] addr [size] import external format (text or binary) into hash table, optionally deleting existing values: -d: delete existing environment before importing; otherwise overwrite / append to existion definitions -t: assume text format; either "size" must be given or the text data must be '\0' terminated -b: assume binary format ('\0' separated, "\0\0" terminated) -c: assume checksum protected environment format addr: memory address to read from size: length of input data; if missing, proper '\0' termination is mandatory - env default -f reset default environment: drop all environment settings and load default environment - env ask name [message] [size] same as "askenv": ask for environment variable - env edit name same as "editenv": edit environment variable - env run same as "run": run commands in an environment variable ====================================================================== TODO: - drop default env as implemented now; provide a text file based initialization instead (eventually using several text files to incrementally build it from common blocks) and a tool to convert it into a binary blob / object file. - It would be nice if we could add wildcard support for environment variables; this is needed for variable name auto-completion, but it would also be nice to be able to say "printenv ip*" or "printenv *addr*" - Some boards don't link any more due to the grown code size: DU405, canyonlands, sequoia, socrates. => cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Stefan Roese <sr@denx.de>, Heiko Schocher <hs@denx.de> - Dropping forceenv() causes build problems on schmoogie => cc: Sergey Kubushyn <ksi@koi8.net> - Build tested on PPC and ARM only; runtime tested with NOR and NAND flash only => needs testing!! Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Cc: Stefan Roese <sr@denx.de>, Cc: Heiko Schocher <hs@denx.de> Cc: Sergey Kubushyn <ksi@koi8.net>
2010-09-19Make getenv() work before relocation.Wolfgang Denk
So far, getenv() would work before relocation is most cases, even though it was not intended to be used that way. When switching to a hash table based implementation, this would break a number of boards. For convenience, we make getenv() check if it's running before relocation and, if so, use getenv_f() internally. Note that this is limited to simple cases, as we use a small static buffer (32 bytes) in the global data for this purpose. For this reason, it is also not a good idea to convert all current uses of getenv_f() into getenv() - some of the existing use cases need to be able to deal with longer variable values, so getenv_f() is still needed and recommended for use before relocation. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-18ARM: Update ARM mach-typesThomas Weber
This patch updates the mach-types.h based on the latest linux kernel Signed-off-by: Thomas Weber <weber@corscience.de>
2010-09-09Merge branch 'master' of git://git.denx.de/u-boot-tiWolfgang Denk
2010-09-08ARMV7: OMAP3: Fix broken reset command on OMAP36XX/37XX and OMAP4Steve Sakoman
Using the reset command on OMAP36XX/37XX and OMAP4 caused a hang. This patch uses the reset bit appropriate for each CPU architecture. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-09-08ARMV7: OMAP3: Add clock setup for OMAP36XX/37XXSteve Sakoman
This patch configures clocks properly when a 36XX/37XX processor is detected. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-09-08ARMV7: OMAP3: Update CPU type detection for AM35XX/OMAP36XX/37XXSteve Sakoman
TI has added new processors to the OMAP3 family. This patch enhances the code in sysinfo.c to detect which family member is present. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-09-08ARMV7: OMAP: Move syslib.c to omap-common since it can be shared by OMAP3 ↵Steve Sakoman
and OMAP4 The functions in syslib.c can be shared, so this patch moves it from cpu/omap3 to cpu/omap-common Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-09-08Merge branch 'at91' of git://git.denx.de/u-boot-atmelWolfgang Denk
2010-09-08Merge branch 'master' of git://git.denx.de/u-boot-samsungWolfgang Denk
2010-09-07Merge branch 'master' of git://git.denx.de/u-boot-marvellWolfgang Denk
2010-09-07Merge branch 'master' of /home/wd/git/u-boot/masterWolfgang Denk
2010-09-03at91_pit: Fix AT91_PIT_MR_PIV_MASK macroAlexander Stein
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
2010-09-03AT91: fix at91sam9260.h for AT91SAM9XEReinhard Meyer
Define the different location of the GPBRs for the 9XE Define the proper CPU Name Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-09-03AT91SAM9XE: add embedded flash supportReinhard Meyer
2010-09-03AT91: add RTT and GPBR based RTCReinhard Meyer
2010-09-03AT91: MCI: add SD/MMC driver using mmc frameworkReinhard Meyer
2010-08-30ARMV7: S5P: rename the member of gpio structureMinkyu Kang
Typically we declare the name of gpio structure to "gpio", so it was duplicated around the name. (e.g: gpio->gpio_a) This patch modified the naming that is removing "gpio_". Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-30ARMV7: S5P: separate the peripheral clocksMinkyu Kang
Because of peripheral devices can select clock sources, separate the peripheral clocks. (pwm, uart and so on) It just return the pclk at s5pc1xx SoC, but s5pc210 SoC must be calculated by own clock register setting. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-27orion5x: fix comment-in-comment typo in cpu.hAlbert Aribaud
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-08-26ARMV7: S5P: fix the macro at samsung_get_base functionMinkyu Kang
New line is unnecessary at last line of macro. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-08-23S5P: mmc: fix the mmc offsetMinkyu Kang
This patch fixed the size of mmc structure. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-08-23ARMV7: S5P: rename from s5pc1xx to s5pMinkyu Kang
Because of these are common files around s5p Socs, rename from s5pc1xx to s5p. And getting cpu_id is SoC specific, so move to SoC's header file. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-23omap2: i2c: remove redundant header definitionsNishanth Menon
Remove the register offset and common defines which are already present in drivers/i2c/omap24xx.h. All of these defines carry the same value even. Cc: Steve Sakoman <steve@sakoman.com> Cc: Heiko <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Wolfang Denk <wd@denx.de> Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Steve Sakoman <steve@sakoman.com>
2010-08-23omap2: i2c: add syss offsetNishanth Menon
OMAP2420 ES2.3 trm defines syss register offset as 0x10. Add it. Cc: Steve Sakoman <steve@sakoman.com> Cc: Heiko <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Wolfang Denk <wd@denx.de> Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Steve Sakoman <steve@sakoman.com>
2010-08-18Merge branch 'master' of /home/wd/git/u-boot/masterWolfgang Denk
2010-08-18ARM: Update ARM mach-typesSandeep Paulraj
This patch updates the mach-types.h based on the latest linux kernel Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-08-17S5P: Use accessor functions instead of SoC specific defines to access the ↵Minkyu Kang
base address This patch is intended to prepare the other S5P SoC. (s5pc210) If use SoC specific defines then can't share with other SoC. So, make the accessor functions for access the base address by common way. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-12AM35x: Adding SCM general register definitionsAjay Kumar Gupta
Adding general register structure of system control module (SCM) of AM35x. This would be required to access devconf2 and ip_sw_reset register in musb module. Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com>
2010-08-10ARM: Add support for MB86R0x SoCsMatthias Weisser
Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2010-08-10orion5x: allow overriding default mappings windowsAlbert Aribaud
Turn all ORION5X_DEF{ADR,SZ}_xxx macros into ORION5X_{ADR,SZ}_xxx and allow defining them from board code to override defaults. This is particularly useful for defining board-specific FLASH address and size in board header file rather than having to tweak orion5x code. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-08-10Merge branch 'master' of git://git.denx.de/u-boot-marvellWolfgang Denk
2010-08-10Merge branch 'master' of git://git.denx.de/u-boot-tiWolfgang Denk
2010-08-08cmd_ide: add support for KirkwoodPrafulla Wadaskar
Added MVSATAC definitions to Kirkwood. Added support for Kirkwood in cmd_ide. Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-08-08cmd_ide: add support for orion5xAlbert Aribaud
Add MVSATAHC definitions to orion5x. Add support for orion5x in cmd_ide. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-08-07ARM: Define __raw_readX and __raw_writeXMarek Vasut
These functions are undefined on ARM when using __io. These are the commonly used versions and can be redefined. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-08-05ARMV7: Restructure omap3 musb driver to allow code sharing between OMAP3 and ↵Steve Sakoman
OMAP4 Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-08-05ARMV7: Modify i2c driver for more reliable operation on OMAP4Steve Sakoman
This patch modifies the init routine to follow the TRM recommendations. It also modifies the i2c_read_byte function to reflect subtle differences between the i2c controller in OMAP3 and OMAP4. Signed-off-by: Steve Sakoman <steve@sakoman.com> Acked-by: Nishanth Menon <menon.nishanth@gmail.com> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-08-05ARMV7: Add pad mux support for OMAP4Steve Sakoman
Add functional multiplexing support for OMAP4 pads. Configure all the pads for the OMAP4430 SDP and OMAP4 Panda boards Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-08-04Merge branch 'master' of git://git.denx.de/u-boot-samsungWolfgang Denk
2010-08-03S5P: support mmc driverMinkyu Kang
This patch adds support mmc driver for s5p SoC Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-07-16Merge branch 'master' of git://git.denx.de/u-boot-tiWolfgang Denk
2010-07-15Merge branch 'master' of git://git.denx.de/u-boot-pxaWolfgang Denk
2010-07-15Merge branch 'master' of ../masterWolfgang Denk
2010-07-15ARMV7: Add basic gpmc initialization for OMAP4Steve Sakoman
This patch adds a gpmc_init function for OMAP4 and adds calls to gpmc_init for existing OMAP4 boards: panda and sdp4430 Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-14PXA: Add PWM2 and PWM3 regs to pxa-regs.hMarek Vasut
2010-07-14PXA: Add hardware init helper macrosMarek Vasut
This patch adds macros for the following purposes: - GPIO configuration - SDRAM configuration - Wakeup - Clock configuration - Interrupt controller configuration These macros are intended to replace numerous copies of the same code. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-07-12mvgbe: add support for orion5x GbE controllerAlbert Aribaud
Add definitions and initialization in orion5x for mvgbe. Add orion5x in mvgbe SoC includes. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
