path: root/arch/arm/include
2016-04-06spi: kirkwood_spi: Add support for multiple chip-selects on MVEBUStefan Roese
Currently only chip-select 0 is supported by the kirkwood SPI driver. The Armada XP / 38x SoCs also use this driver and support multiple chip selects. This patch adds support for multiple CS on MVEBU. The register definitions are restructured a bit with this patch. Grouping them to the corresponding registers. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-04-01sunxi: Add support for Allwinner A64 SoCsSiarhei Siamashka
The Allwinner A64 SoC is used in the Pine64. This patch adds all bits necessary to compile U-Boot for it running in AArch64 mode. Unfortunately SPL is not ready yet due to legal problems, so we need to boot using the binary boot0 for now. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> [agraf: remove SPL code, move to AArch64] Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-03-31sunxi: clk: Fix USB PHY clock macros for A83TChen-Yu Tsai
The A83T has 3 PHYs, the last one being HSIC, which has 2 clocks. Also there is only 1 OHCI. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-03-29Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2016-03-29armv8/ls2080ardb: Enable VID supportRai Harninder
This patch enable VID support for ls2080ardb platform. It uses the common VID driver. Signed-off-by: Rai Harninder <harninder.rai@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29armv8: fsl-layerscape: Add LS1023A SVRMingkai Hu
Signed-off-by: Mingkai Hu <mingkai.hu@nxp.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29armv8: fsl-layerscape: Fix LS1043A SVR registerMingkai Hu
2016-03-29armv8: fsl-lsch3: Disable SMMU during secure bootSaksham Jain
During secure boot, SMMU is enabled on POR by SP bootrom. SMMU needs to be put in bypass mode in uboot to enable CAAM transcations to pass through. For non-secure boot, SP BootROM doesn't enable SMMU, which is in bypass mode out of reset. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29armv8: ls2080: Add config for endianess of CCSR GURSaksham Jain
The GUR (DCFG) registers in CCSR space are in little endian format. Define a config CONFIG_SYS_FSL_CCSR_GUR_LE in arch/arm/include/asm/arch-fsl-layerscape/config.h Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29armv8: ls2080: Change env variable "fdt_high"Saksham Jain
"fdt_high" env variable was set to 0xcfffffff for secure boot. Change it to 0xa0000000 for LS2080 to be consistent with non-secure boot targets. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29armv8: fsl-lsch3: Copy Bootscript and header from NOR to DDRSaksham Jain
To unify steps for secure boot for xip (eg. NOR) and non-xip memories (eg. NAND, SD), bootscipts and its header are copied to main memory. Validation and execution are performed from there. For other ARM Platforms (ls1043 and ls1020), to avoid disruption of existing users, this copy step is not used for NOR boot. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29armv8: ls2080: Add bootscript header addr for secure bootSaksham Jain
During secure boot, Linux image along with other images are validated using bootscript. This bootscript also needs to be validated before it executes. This requires a header for bootscript. When secure boot is enabled, default bootcmd is changed to first validate bootscript using the header and then execute the script. For ls2080, NOR memory map is different from other ARM SoCs. So a new address on NOR is used for this bootscript header (0x583920000). The Bootscript address is mentioned in this header along with addresses of other images. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29armv8: ls2080rdb: ls2080qds: Add secure boot supportSaksham Jain
Sec_init has been called at the beginning to initialize SEC Block (CAAM) which is used by secure boot validation later for both ls2080a qds and rdb. 64-bit address in ESBC Header has been enabled. Secure boot defconfigs are created for boards (NOR boot). Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29armv8: fsl-lsch3: Add new header for secure bootSaksham Jain
For secure boot, a header is used to identify key table, signature and image address. A new header structure is added for lsch3. Currently key extension (IE) feature is not supported. Single key feature is not supported. Keys must be in table format. Hence, SRK (key table) must be present. Max key number has increase from 4 to 8. The 8th key is irrevocable. A new barker Code is used. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29armv8: ls2080: Add configs for SEC, SecMon, SRK and DCFGSaksham Jain
Add configs for various IPs used during secure boot. Add address and endianness for SEC and Security Monitor. SRK are fuses in SFP (fuses for public key's hash). These are stored in little endian format. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29armv8: ls2080: Add SFP Configs for LS2080Saksham Jain
In LS2080, SFP has version 3.4. It is in little endian. The base address is 0x01e80200. SFP is used in Secure Boot to read fuses. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-28dm: i2c: mxc_i2c: implement i2c_idle_busPeng Fan
Implement i2c_idle_bus in driver, then setup_i2c can be dropped for boards which enable DM_I2C/DM_GPIO/PINCTRL. The i2c_idle_bus force bus idle flow follows setup_i2c in arch/arm/imx-common/i2c-mxv7.c This patch is an implementation following linux kernel patch: " commit 1c4b6c3bcf30d0804db0d0647d8ebeb862c6f7e5 Author: Gao Pan <b54642@freescale.com> Date: Fri Oct 23 20:28:54 2015 +0800 i2c: imx: implement bus recovery Implement bus recovery methods for i2c-imx so we can recover from situations where SCL/SDA are stuck low. Once i2c bus SCL/SDA are stuck low during transfer, config the i2c pinctrl to gpio mode by calling pinctrl sleep set function, and then use GPIO to emulate the i2c protocol to send nine dummy clock to recover i2c device. After recovery, set i2c pinctrl to default group setting. " See Documentation/devicetree/bindings/i2c/i2c-imx.txt for detailed description. 1. Introuduce scl_gpio/sda_gpio/bus in mxc_i2c_bus. 2. Discard the __weak attribute for i2c_idle_bus and implement it, since we have pinctrl driver/driver model gpio driver. We can use device tree, but not let board code to do this. 3. gpio state for mxc_i2c is not a must, but it is recommended. If there is no gpio state, driver will give tips, but not fail. 4. The i2c controller was first probed, default pinctrl state will be used, so when need to use gpio function, need to do "pinctrl_select_state(dev, "gpio")" and after force bus idle, need to switch back "pinctrl_select_state(dev, "default")". This is example about how to use the gpio force bus idle function: " &i2c1 { clock-frequency = <100000>; pinctrl-names = "default", "gpio"; pinctrl-0 = <&pinctrl_i2c1>; pinctrl-1 = <&pinctrl_i2c1_gpio>; scl-gpios = <&gpio1 28 GPIO_ACTIVE_HIGH>; sda-gpios = <&gpio1 29 GPIO_ACTIVE_HIGH>; status = "okay"; [....] }; [.....] pinctrl_i2c1_gpio: i2c1grp_gpio { fsl,pins = < MX6UL_PAD_UART4_TX_DATA__GPIO1_IO28 0x1b8b0 MX6UL_PAD_UART4_RX_DATA__GPIO1_IO29 0x1b8b0 >; }; " Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com>
2016-03-27ARM: asm: types: Introduce DMA_ADDR_T_64BITLokesh Vutla
dma_addr_t holds any valid DMA address. If the DMA API only uses 32-bit addresses, dma_addr_t need only be 32 bits wide. Bus addresses, e.g., PCI BARs, may be wider than 32 bits, but drivers do memory-mapped I/O to ioremapped kernel virtual addresses, so they don't care about the size of the actual bus addresses. Also 32 bit ARM systems with LPAE enabled can use 64bit address space, but DMA still use 32bit address like in case of DRA7 and Keystone platforms. This is inspired from the Linux kernel types implementation[1] [1] https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/include/linux/types.h#n142 Acked-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-27arm: Add support for HYP mode and LPAE page tablesAlexander Graf
We currently always modify the SVC versions of registers and only support the short descriptor PTE format. Some boards however (like the RPi2) run in HYP mode. There, we need to modify the HYP version of system registers and HYP mode only supports the long descriptor PTE format. So this patch introduces support for both long descriptor PTEs and HYP mode registers. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-03-27arm64: Add 32bit arm compatible dcache definitionsAlexander Graf
We want to be able to reuse device drivers from 32bit code, so let's add definitions for all the dcache options that 32bit code has. While at it, fix up the DCACHE_OFF configuration. That was setting the bits to declare a PTE a PTE and left the MAIR index bit at 0. Drop the useless bits and make the index explicit. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-03-27ARM: OMAP5/DRA7: Expose do_set_iodelayNishanth Menon
do_set_iodelay can now be used from board files based on needs of the platforms variation they have. Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-27ARM: OMAP5/DRA7: Split iodelay functionality into sub stepsNishanth Menon
Since many platforms may need different pad configuration required depending on variation of the platform with minor deltas, it is easier to maintain a sub step based approach to allow for pin mux and iodelay configuration which may depend on the platform variations and need to be done in IO isolation. While we retain the older __recalibrate_iodelay function which provides a ready sequencing, __recalibrate_iodelay_start and __recalibrate_iodelay_end may be alternatively used now and the callers will be responsible for the correct sequencing of operations. Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-27ARM: DRA72x: Add support for detection of SR2.0Ravi Babu
Add support for detection of SR2.0 version of DRA72x family of processors. Signed-off-by: Ravi Babu <ravibabu@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-26stm32f746-disco: enable flash supportVikas Manocha
This patch enables embedded flash for stm32f746 discovery board. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2016-03-26stm32: stm32f4: move flash driver to mtd driver locationVikas Manocha
Same flash driver can be used by other stm32 families like stm32f7. Better place for this driver would be mtd driver location. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2016-03-25Merge git://www.denx.de/git/u-boot-marvellTom Rini
2016-03-24arm: mvebu: spi.h: Add registers for direct write accessStefan Roese
The direct write config register is needed for SPI direct write mode configuration. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Signed-off-by: Stefan Roese <sr@denx.de>
2016-03-23sunxi: Fix gmac not working due to cpu_eth_init no longer being calledHans de Goede
cpu_eth_init is no longer called for dm enabled eth drivers, this was causing the sunxi gmac eth controller to no longer work in u-boot. This commit fixes this by calling the clock, reset and pinmux setup function from s_init() and enabling the phy power pin (if any) from board_init(). The enabling of phy power cannot be done from s_init because it uses dm and dm is not ready yet at this point. Note that the mdelay is dropped as the phy gets enabled much earlier now, so it is no longer needed. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Tested-by: Karsten Merker <merker@debian.org> Tested-by: Michael Haas <haas@computerlinguist.org>
2016-03-23sunxi: Support SID e-fuses on A83T and H3Chen-Yu Tsai
On the A83T and H3, the SID block is at a different address. Furthurmore, the e-fuses are at an offset of 0x200 within the hardware's address space. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-03-21driver/ddr/fsl: Add workaround for erratum A-009803Shengzhou Liu
During initial DDR training, false parity errors may be detected. This patch adds workaround to fix the erratum. Tested on LS2085QDS and LS2080RDB. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-21pci/layerscape: add defines for LUTStuart Yoder
The per-PCI controller LUT (Look-Up-Table) is a 32-entry table that maps PCI requester IDs (bus/dev/fun) to a stream ID. Add defines for the register offsets. Signed-off-by: Stuart Yoder <stuart.yoder@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-21armv8: ls2080a: update stream ID partitioning infoStuart Yoder
Update comments around how stream IDs are partitioned. Stream IDs allocated to PCI are no longer divided up by controller, but are instead a contiguous range Signed-off-by: Stuart Yoder <stuart.yoder@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-21arm: ls102xa: fdt: Update FSL_QSPI_COMPAT and FSL_DSPI_COMPATAlison Wang
As the compatible property values for QSPI and DSPI dts nodes are changed in kernel, FSL_QSPI_COMPAT and FSL_DSPI_COMPAT need to be updated too. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-21armv8: ls2080ardb: invert irq pins polarity for AQR405 PHYShaohui Xie
To use AQR405 PHY's interrupt, we need to invert the relative IRQ pins polarity by setting IRQCR register, because AQR405 interrupt is low active but GIC accepts high active. Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-21armv8: lsch3: Enable WUO config for RNI-20 nodePrabhakar Kushwaha
Enable wuo config to accelerate coherent ordered writes for LS2080A and LS2085A. WRIOP IP is connected to RNI-20 Node. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-15ARM: DRA7: DDR: Enable SR in Power Management ControlNishanth Menon
If EMIF is idle for certain amount of DDR cycles, EMIF will put the DDR in self refresh mode to save power if EMIF_PWR_MGMT_CTRL register is programmed. And also before entering suspend-resume ddr needs to be put in self-refresh. Linux kernel does not program this register before entering suspend and relies on u-boot setting. So configuring it in u-boot. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-15arm64: Remove non-full-va map codeAlexander Graf
By now the code to only have a single page table level with 64k page size and 42 bit address space is no longer used by any board in tree, so we can safely remove it. To clean up code, move the layerscape mmu code to the new defines, removing redundant field definitions. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-03-15thunderx: Move mmu table into board fileAlexander Graf
The MMU range table can vary depending on things we may only find out at runtime. While the very simple ThunderX variant does not change, other boards will, so move the definition from a static entry in a header file to the board file. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-03-15arm64: Make full va map code more dynamicAlexander Graf
The idea to generate our pages tables from an array of memory ranges is very sound. However, instead of hard coding the code to create up to 2 levels of 64k granule page tables, we really should just create normal 4k page tables that allow us to set caching attributes on 2M or 4k level later on. So this patch moves the full_va mapping code to 4k page size and makes it fully flexible to dynamically create as many levels as necessary for a map (including dynamic 1G/2M pages). It also adds support to dynamically split a large map into smaller ones when some code wants to set dcache attributes. With all this in place, there is very little reason to create your own page tables in board specific files. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-03-15arm64: Disable TTBR1 maps in EL1Alexander Graf
When running in EL1, AArch64 knows two page table maps. One with addresses that start with all zeros (TTBR0) and one with addresses that start with all ones (TTBR1). In U-Boot we don't care about the high up maps, so just disable them to ensure we don't walk an invalid page table by accident. Reported-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2016-03-15thunderx: Calculate TCR dynamicallyAlexander Graf
Based on the memory map we can determine a lot of hard coded fields of TCR, like the maximum VA and max PA we want to support. Calculate those dynamically to reduce the chance for pit falls. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-03-15omap4: Reboot mode supportPaul Kocialkowski
Reboot mode is written to SAR memory before reboot in the form of a string. This mechanism is supported on OMAP4 by various TI kernels. It is up to each board to make use of this mechanism or not. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-03-15omap4: Properly enable USB PHY clocksPaul Kocialkowski
This correctly enables the USB PHY clocks, by enabling CM_ALWON_USBPHY_CLKCTRL and correctly setting CM_L3INIT_USBPHY_CLKCTRL's value. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-03-15omap-common: Rename set_muxconf_regs_essential to set_muxconf_regsPaul Kocialkowski
There is no distinction between essential and non-essential mux configuration, so it doesn't make sense to have an "essential" prefix. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-03-15omap4: Export jedec sdram timingsPaul Kocialkowski
Individual boards might provide their own emif_get_device_timings function and use the jedec timings in their own way, hence those have to be exported. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-03-15omap4: Export elpidia sdram timingsPaul Kocialkowski
Individual boards might provide their own emif_get_device_timings function and use the elpidia timings in their own way, hence those have to be exported. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-03-15omap4: Export elpidia sdram device detailsPaul Kocialkowski
Individual boards might provide their own emif_get_device_details function and use elpidia device details in their own way, hence those have to be exported. This also wraps existing definitions with the proper ifdef logic. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-03-15omap3: Use a define for reboot reason offsetPaul Kocialkowski
This introduces a define for the offset to the reboot reason, rather than hardcoding it. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-15omap3: String-based reboot mode handlingPaul Kocialkowski
This switches reboot mode handling to a string-based interface, that allows more flexibility to set a common interface with the next generations of OMAP devices. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-15Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
