We must enable the external 32kHz oscillator in order to work
around a known clock drift issue with the internal 32kHz oscillator.
This fixes the Linux kernel system clock drift.
Signed-off-by: Anthony Huereca <B04178@freescale.com>
Signed-off-by: Jiri Kotzian <B36968@freescale.com>
Signed-off-by: Justin Waters <justin.waters@timesys.com>
Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
This patch adds support for USB EHCI driver for Armada100 SOCs.
Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
This patch adds USB host controller's UTMI PHY interface driver for
Armada100 SOCs.
The video setup for the Epson display is provided. Addtionally
some extra info is displayed next to the Linux logo.
Make get_cpu_rev() publicly available (added to sys_proto.h).
Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
Define FEC_QUIRK_ENET_MAC and add to
arch-mx6/imx-regs.h
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
* For cold silicon the DDR timings need to be relaxed in order for
the device to boot with DDR at 266MHz
* Fix proposed by James Doublesin
Signed-off-by: Chase Maupin <Chase.Maupin@ti.com>
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
Acked-by: Jason Liu <jason.hui@linaro.org>
Move (E)CSPI register declarations into the imx-regs.h files for each supported CPU
Introduce two new macros to control conditional setup
MXC_CSPI - Used for processors with the Configurable Serial Peripheral Interface (MX3x)
MXC_ECSPI - For processors with Enhanced Configurable... (MX5x, MX6x)
Tested-by: Jason Liu <jason.hui@linaro.org>
The interface to the mxc_gpio driver uses integer (ordinal) values to
refer to all GPIOs on the i.MX processors. The registers themselves
and much of the i.MX documentation are banked in groups of 32, and these
macros allow the use of the port:index numbering for clarity.
GPIO_NUMBER() converts to ordinal value from port:index
GPIO_PORT() returns the port of an ordinal value
GPIO_INDEX() returns the index or offset of the ordinal.
Discussion on the mailing list at
http://lists.denx.de/pipermail/u-boot/2012-January/116927.html
Before we can send a command we need both the DATI (command inhibit on
mmc_dat line) bit and CMDI (command inhibit on mmc_cmd line) are clear.
The previous behavior of only checking on DATI was insufficient on some
cards and incorrect behavior in any case. This makes the code check
for both bits being clear and makes the error print more clear as
to what happened. DATI_CMDDIS is removed as it was unused elsewhere
in the code and stood for 'DATI is set, cmds are disabled still'.
Fix originally spotted by Peter Bigot.
Tested-by: Peter A. Bigot <bigotp@acm.org>
Tested-by: Robert Nelson <robertcnelson@gmail.com>
Tested-by: Andreas Müller <schnitzeltony@googlemail.com>
This patch moves hawkboard to the new spl infrastructure from the
older nand_spl one.
Removed the hawkboard_nand_config build option -- The spl code now
gets compiled with hawkboard_config, after building the main u-boot
image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard
to reflect the same.
Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
Cc: Christian Riesch <christian.riesch@omicron.at>
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Cc: Tom Rini <trini@ti.com>
Acked-by: Christian Riesch <christian.riesch@omicron.at>
ACTIM_CTRLA macro errently passes "b" parameter to ACTIM_CTRLA_TRAS()
instead of "c". To make usage more clear, replace all single-letter
macro parameters with more descriptive parameter names.
Signed-off-by: Peter Barada <peter.barada@logicpd.com>
add support for printing various clock frequency info found
in SOC such as ARM core frequency, DSP core frequency and DDR
frequency as part of bdinfo command.
Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
AM3517: Changed default clock rate for AM3517
Changed #define MPU_M_13_ES2 from 0x1F4 to 0x258, this allows
the AM3517 to boot up at 600MHz instead of 500 MHz
Signed-off-by: Schuyler Patton <spatton@ti.com>
CC: Tom Rini <tom.rini@gmail.com>
CC: Simon Schwarz <simonschwarzcor@gmail.com>
CC: Stefano Babic <sbabic@denx.de>
Adding ehci clock enabling mechanism part of clock framework.
When essential clocks are enabled during init phase usb host
clocks can also be enabled from clock framework.
Signed-off-by: Govindraj.R <govindraj.raja@ti.com>
Tested-by: Stefano Babic <sbabic@denx.de>
Clean up added ehci-omap.c and make it generic for re-use across
omap-soc having same ehci ip block. Also pass the modes to be configured
from board file and configure the ports accordingly. All usb layers
are not cache aligned, till then keep cache off for usb ops as ehci will use
internally dma for all usb ops.
* Add a generic common header ehci-omap.h having common ip block
data and reg shifts.
* Rename and modify ehci-omap3 to ehci.h retain only conflicting
sysc reg shifts remove others and move to common header file.
* pass the board data for beagle/panda accordinly to use
ehci ports.
Samsung's ARM Cortex-A15 based SoCs are known as Exynos5 series of
SoCs. This patch adds the support for Exynos5.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
This patch adds support the generic watchdog timer for s5pc1xx and exynos4
Cc: HeungJun, Kim <riverful.kim@samsung.com>
This patch adds power.h and SAMSUNG_BASE() macro for using Exynos4 power.
Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
This patch add watchdog.h for Exynos4
Add TCMPB3 field in pwm structure, earliar this was res1.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
This patch modifies mxcmmc.c to be used
not only by i.MX27 but also by i.MX31 boards.
Both use the same SD controller, but have different
clock set-ups.
The i.MX27 imx_get_XXXclock functions are made static to
generic.c and a public mxc_get_clock() function
is provided. Pins, base address and prototypes for
an i.MX31 specific board_init_mmc() are provided.
Some of the i.MX27 clock getters are unused and marked
as such to avoid warnings (./MAKEALL -s mx27), but
the code was left in for future use.
The uart txd pad can also provide the rxd function. But it does not stop its
tx role. This could be used for a half duplex serial port.
Change names to reduce confusion.
CC: Troy Kisky <troy.kisky@boundarydevices.com>
CC: Jason Liu <jason.hui@linaro.org>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Tom Rini <tom.rini@gmail.com>
The Buffer Logic of VPSS is Not Reset by System Reset Pin, see
http://www.ti.com/lit/er/sprz316b/sprz316b.pdf chapter Advisory 1.2.1
on page 9. Add workaroundcode proposed in the errata.
The OMAP-L138 has a pre-divider available on PLL0.
Add support to da850_lowlevel.c for configuring PLL0's pre-divider. This is
to achieve certain OPP's -- e.g. the 372MHz OPP used also by Linux.
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
CC: Heiko Schocher <hs@denx.de>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Acked-by: Heiko Schocher <hs@denx.de>
This adds support for SDMMC ports to the funcmux. Only one
option is supported: FUNCMUXO_SDMMC_8BIT which selects an 8-bit
wide SDIO interface where available.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Add support to funcmux for selecting I2C functions and programming
the pinmux appropriately.
We want to give a name to each available funcmux config. For now we just
use the pin group names (even through it is verbose) since there seems
to be nothing better.
We want to support config options other than zero, so move the test to the
end to allow intermediate code to OK such a config.
Add i2c driver board hookup for AM335X EVM
Signed-off-by: Chandan Nath <chandan.nath@ti.com>
Signed-off-by: Patil, Rachna <rachna@ti.com>
* implementation based on ti beagleboard/omap3evm
* timing data and i2c workaround for revision 0 boards taken from x-loader
* run-tested with overo revision 0 and 1 / boot from NAND and SDcard
* run-tested with x-loader
Signed-off-by: Andreas Müller <schnitzeltony@gmx.de>
* avoid potential buffer overflows
* allow SPL-build not to output "Texas Instruments Revision detection unimplemented"
This patch is added to support SPL feature on AM335X
platform. In this patch, MMC1 is configured as boot
device for SPL and support for other devices will be
added in the next patch series.
This patch add supports for mmc/sd driver on AM335X platform.
PLL and pinmux configurations for mmc/sd are configured in this
patch.
This patch is added to update incorrect ddr and timer
register offset.
This patch is added to replace CONFIG_AM335X symbol
with CONFIG_AM333XX for AM33XX platforms.
Tested-by: Thomas Weber <weber@corscience.de>
Fix boot issue on ES2.0 Panda by tuning some
IO settings. The CONTROL_EFUSE_2 register has
to be over-ridden in software for 4430 boards.
Commit 23e9f0723e48615332119de4f4ec7a833a282628
wrongly did this for CONTROL_EFUSE_1. Reverting
this and doing it for CONTROL_EFUSE_2.
Signed-off-by: Aneesh V <aneesh@ti.com>
Tested-by: Raúl Porcel <armin76@gentoo.org>
Now the values in the defines agree with those in the manuals.
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
Init peripheral access control register of AIPSTZ OPACRx:
Buffer Writes(BW): 0 -> not bufferable,
Supervisor Protect(SP): 0 -> not require supervisor privilege level for accesses.
Write Protect(WP): 0 -> allows write accesses.
Trusted Protect(TP): 0 -> allows unstrusted master
Signed-off-by: Jason Liu <jason.hui@linaro.org>
For the i.mx6q, the burned-in MAC address will be the following odering,
fuse: 0x620[7:0] MAC_ADDR[7:0] ---> mac[5]
fuse: 0x620[15:8] MAC_ADDR[15:8] ---> mac[4]
fuse: 0x620[23:16] MAC_ADDR[23:16] ---> mac[3]
fuse: 0x620[31:24] MAC_ADDR[31:24] ---> mac[2]
fuse: 0x630[7:0] MAC_ADDR[39:32] ---> mac[1]
fuse: 0x630[15:8] MAC_ADDR[47:40] ---> mac[0]
This patch also fix the error caculation for the fuse bank[0] address
Let dram_init function be a common function, so that other mx28 boards
can reuse it.
Acked-by: Marek Vasut <marek.vasut@gmail.com>
