The implementation of noncached_init() uses define MMU_SECTION_SIZE.
Define this on ARM64.
Move the prototype of noncached_{init,alloc}() to a location that
doesn't depend on !defined(CONFIG_ARM64).
Note that noncached_init() calls mmu_set_region_dcache_behaviour() which
relies on something having set up translation tables with 2MB block size.
The core ARMv8 MMU setup code does not do this by default, but currently
relies on SoC specific MMU setup code. Be aware of this before enabling
this feature on your platform!
Old sector number is not being cleared from FLASH_CR register. For example
when first erased sector was 001 and then you want to erase sector 010,
sector 011 gets erased instead.
This patch clears old sector number from FLASH_CR register before a new
one is written.
Signed-off-by: Vadzim Dambrouski <pftbest@gmail.com>
When building a Thumb-1-only target with CONFIG_SYS_THUMB_BUILD,
some files fail to build, most of the time because they include
mcr instructions, which only exist for Thumb-2.
This patch introduces a Kconfig option CONFIG_THUMB2 and uses
it to select between Thumb-2 and ARM mode for the aforementioned
files.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This patch fix compilation error:
drivers/mmc/zynq_sdhci.c:16:5: error: conflicting types for
‘zynq_sdhci_init’
int zynq_sdhci_init(phys_addr_t regbase)
In file included from drivers/mmc/zynq_sdhci.c:14:0:
./arch/arm/include/asm/arch/sys_proto.h:16:5: note: previous declaration
of ‘zynq_sdhci_init’ was here
int zynq_sdhci_init(unsigned long regbase);
The generic bitops headers are required when calling logarithmic
functions, such as ilog2().
Reviewed-by: Jagan Teki <jteki@openedev.com>
Freescale ARM-based Layerscape LS102xA contain a SATA controller
which comply with the serial ATA 3.0 specification and the
AHCI 1.3 specification.
This patch adds SATA feature on ls1021aqds and ls1021atwr boards.
Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
Freescale LayerScape with Chassis Generation 2 is a set of SoCs with
ARMv8 cores and 2rd generation of Chassis.
Signed-off-by: Li Yang <leoli@freescale.com>
Signed-off-by: Hou Zhiqiang <B48286@freescale.com>
Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com>
Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
There are two LS series processors are built on ARMv8 Layersacpe
architecture currently, LS2085A and LS1043A. They are based on
ARMv8 core although use different chassis, so create fsl-layerscape
to refactor the common code for the LS series processors which also
paves the way for adding LS1043A platform.
Config Security Level Register is different between different SoCs,
so put the CSL register definition into the arch specific directory.
Enable snooping for CAAM read & write transactions by
programming the SCFG snoop configuration register:
SCFG_SNPCNFGCR[SECRDSNP]
SCFG_SNPCNFGCR[SECWRSNP]
Signed-off-by: Horia Geantă <horia.geanta@freescale.com>
Reviewed-by: Zhengxiong Jin <Jason.Jin@freescale.com>
Data types and I/O functions have been defined for
64 bit physical addresses in arm.
Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com>
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Existing driver gets the actual omap hammc base address + 0x100
bytes as the first 0x100 bytes is not used by the driver. But
with DM conversion the base address from DT is different, to
accommodate the offset adding res0[0x100] to struct hsmmc.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
In K2G, Ethernet doesn't support SGMII instead it support RGMII,
adding support to the driver to connect to RGMII phy.
Signed-off-by: Vitaly Andrianov <vitalya@ti.com>
Phy mode is a board property and it can be different between
multiple board and ports, so it should not be hardcoded in
driver to one specific mode. So adding a field in eth_priv_t
structure to pass phy mode to driver.
Add clock information for Galileo
Since there is a common function to grab the serial number from the die id bits,
it makes sense have one to parse that serial number and feed it to the serial
ATAG.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
This introduces omap_die_id_display to display the full die id.
There is no need to store it in an environment variable, that no boot script
is using anyway.
Now that we have a common prototype to grab the omap die id, functions to figure
out a serial number and usb ethernet address can use it directly.
Those also get an omap_die_id prefix for better consistency.
This introduces omap4 support for omap_die_id, which matches the common
omap_die_id definition. It replaces board-specific code to grab the die id bits.
This replaces the previous get_dieid definition with omap_die_id, that matches
the common omap_die_id definition.
This introduces a common definition for omap_die_id, that aims at providing a
common interface for accessing omap platform's die id bits.
Update the L2 AUX CTRL settings for the SoCFPGA.
Enabling D and I prefetch bits helps improve SDRAM performance on the
platform.
Also, we need to enable bit 22 of the L2. By not having bit 22 set in the
PL310 Auxiliary Control register (shared attribute override enable) has the
side effect of transforming Normal Shared Non-cacheable reads into Cacheable
no-allocate reads.
Coherent DMA buffers in Linux always have a Cacheable alias via the
kernel linear mapping and the processor can speculatively load cache
lines into the PL310 controller. With bit 22 cleared, Non-cacheable
reads would unexpectedly hit such cache lines leading to buffer
corruption.
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Add 'volatile' qualifier to the asm statement in get_cr()
so that the statement is not optimized out by the compiler.
(http://comments.gmane.org/gmane.linux.linaro.toolchain/5163)
Without the 'volatile', get_cr() returns a wrong value which
prevents enabling the MMU and later causes a PCIE VA access
failure.
Signed-off-by: Alison Wang <alison.wang@freescale.com>
PCI driver currently hangs on mx6qp.
Toggle the reset bit with the appropriate timings to fix the issue.
Based on the FSL kernel driver implementation.
For EL3 and EL2, the documentation says that bits 31 and 23 are reserved
but should be written as 1.
For EL1, only bit 23 is not reserved, so only write bit 31 as 1.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Use the inner shareable attribute for memory, which makes more sense
considering that this code is called when caches are being enabled.
According to ARM PrimeCell PL175 documentation WAIT_OEN config value
is defined without any additional clocks added to the value set by a
client, the change fixes the wrong interface to WAIT_OEN config.
The change also touches a single user of LPC32xx EMC and corrects
configured "output enable delay" value on its side according to the
changed interface.
No functional change intended.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
The VF610 DDRMC driver code contains settings which are
board-specific. Move these out to boards so that new boards
can define their own without having to modify the driver.
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
This patch extends the misc_init_r() function on sunxi boards
to test for the presence of a suitable "sunxi" SPL header. If
found, and the loader ("fel" utility) provided a non-zero value
for the boot.scr address, then the corresponding environment
variable fel_scriptaddr gets set.
misc_init_r() also sets (or clears) the "fel_booted" variable depending
on the active boot device, using the same logic as spl_boot_device().
The goal is to provide sufficient information (within the U-Boot
environment) to make intelligent decisions on how to continue the boot
process, allowing specific customizations for the "FEL boot" case.
Signed-off-by: Bernhard Nortmann <bernhard.nortmann@web.de>
Acked-by: Hans de Goede <hdegoede@redhat.com>
This patch follows up on a discussion of ways to improve support
for the sunxi FEL ("USB boot") mechanism, especially with regard
to boot scripts, see:
https://groups.google.com/d/msg/linux-sunxi/wBEGUoLNRro/rHGq6nSYCQAJ
The idea is to convert the (currently unused) "pad" bytes in the
SPL header into an area where data can be passed to U-Boot. To
do this safely, we have to make sure that we're actually using
our "sunxi" flavor of the SPL, and not the Allwinner boot0.
The modified mksunxiboot introduces a special signature to the
SPL header in place of the "pub_head_size" field. This can be
used to reliably distinguish between compatible versions of sunxi
SPL and anything else (older variants or Allwinner's boot0).
Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
The sunxi platform currently doesn't seem to make any use of the
asm/arch-sunxi/spl.h file. This patch moves some declarations from
tools/mksunxiboot.c into it.
This enables us to reuse those definitions when extending the
sunxi board code (boards/sunxi/boards.c).
This code is no-longer used. Drop it.
Acked-by: Andreas Bießmann <andreas.devel@gmail.com>
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
Enabling a PLL while IDDQ is high. The Linux kernel checks for this
condition and warns about it verbosely, so while this seems to work
fine, fix it up according to the programming guidelines provided in
the Tegra K1 TRM (v02p), Section 5.3.8.1 ("PLLC and PLLC4 Startup
Sequence"). The Tegra114 TRM doesn't contain this information, but
the programming of PLLC is the same on Tegra114 and Tegra124.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Sequence").
Reported-by: Nicolas Chauvet <kwizart@gmail.com>
On currently supported SoCs, clk_m always runs at the same frequency as
the oscillator input. However newer SoC generations such as Tegra210 no
longer have that restriction. Prepare for that by separating clk_m from
the oscillator clock and allow SoC code to override the clk_m rate.
This function is deleted by commit 2fccd2d96bad
"tegra: Convert tegra GPIO driver to use driver model".
Signed-off-by: Axel Lin <axel.lin@ingics.com>
This arch does not seem to be supported / used at all in the current
U-Boot mainline source tree any more. So lets remove the core u8500 code
and code that was only referenced by this platform.
Please note that this patch also removes these config options:
- CONFIG_PL011_SERIAL_RLCR
- CONFIG_PL011_SERIAL_FLUSH_ON_INIT
As they only seem to be referenced by u8500 based boards. Without any
such board in the current code, these config option don't make sense
any more. Lets remove them as well.
If someone still wants to use this platform, then please send patches
to re-enable support by adding at least one board that references this
code.
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Cc: John Rigby <john.rigby@linaro.org>
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
* Add i.MX7D SABRESD target board support with enabled modules:
UART, PMIC, USB/OTG, SD, eMMC, ENET, I2C, 74LV IOX.
Build target: mx7dsabresd_config
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Signed-off-by: Fugang Duan <B38611@freescale.com>
Signed-off-by: Ye.Li <B37916@freescale.com>
Signed-off-by: Adrian Alonso <aalonso@freescale.com>
Rework imx_set_wdog_powerdown to be reused by imx6 and imx7
Add imx7d basic SoC system support
Misc arch dependent functions for system bring up
* Add Clock control module (CCM) support
* iMX7D SoC introduces 3 main clock sysmtem abstraction for clock
root frequency generation denominated clock slices.
Core clock slice: hihg speed clock for ARM core
Bus clock slice: for bus clocks
IP clock slice: Peripheral clocks
* At system boot ROM enables PLL_ARM, PLL_DDR, PLL_SYS, PLL_ENET
In u-boot, we have to:
- Configure PFD3- PFD7 for freq we needed in u-boot
- Set clock root for peripherals (ip channel)
* Add system arch level header files
- imx-regs.h: iMX7D SoC system architecture registers
- crm_regs.h: Clock control module registers
- sys_proto.h: helper callback function for SoC setup
Add system counter driver for imx7d and mx6ul
imx7 and imx6ul supports system counter timer as well as
GPT timer (arch/arm/imx-common/timer.c); The default for
imx7 is systemcounter timer.
Move common imx6 arch init setup, init.c can be extended
and reused to support imx7 SoC keeping init arch common
code.
