path: root/arch/arm/include/asm
2013-04-15Tegra: Split tegra_get_chip_type() into soc & sku funcsTom Warren
As suggested by Stephen Warren, use tegra_get_chip() to return the pure CHIPID for a Tegra SoC (i.e. 0x20 for Tegra20, 0x30 for Tegra30, etc.) and rename tegra_get_chip_type() to reflect its true function, i.e. tegra_get_chip_sku(), which returns an ID like TEGRA_SOC_T25, TEGRA_SOC_T33, etc. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-04-15Tegra114: Initialize System Counter (TSC) with osc frequencyTom Warren
T114 needs the SYSCTR0 counter initialized so the TSC can be read by the kernel. Do it in the bootloader since it's a write-once deal (secure/non-secure mode dependent). Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-04-15Tegra: Configure L2 cache control reg properly.Tom Warren
Without this change, kernel fails at calling function cache_clean_flush during kernel early boot. Aprocryphally, intended for T114 only, so I check for a T114 SoC. Works (i.e. dalmore 3.8 kernel now starts printing to console). Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-04-15ARM: tegra: support T33 SKU of Tegra30Stephen Warren
Make U-Boot aware of the T33 SKU of Tegra30, and treat it identically to any other Tegra30. An alternative would be to simply remove the SKU checking from tegra_get_chip_type(); most use of the value most likely simply wants to know the current chip, not the specific SKU. Or, the function could be split into separate tegra_get_chip() and tegra_get_sku() for the cases where differentiation really is required. I wonder whether tegra_get_chip_type() should printf() whenever any unkown chip/SKU is found, although perhaps the function is called so early that the printf() wouldn't actually make it to the UART anyway. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-04-14Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-04-13spi: mxc_spi: Set master mode for all channelsFabio Estevam
The glitch in the SPI clock line, which commit 3cea335c34 (spi: mxc_spi: Fix spi clock glitch durant reset) solved, is back now and itwas re-introduced by commit d36b39bf0d (spi: mxc_spi: Fix ECSPI reset handling). Actually the glitch is happening due to always toggling between slave mode and master mode by configuring the CHANNEL_MODE bits in this reset function. Since the spi driver only supports master mode, set the mode for all channels always to master mode in order to have a stable, "glitch-free" SPI clock line. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-04-12am335x: Really correct DDR timings on new BeagleBone partTom Rini
The previous timings were done on the internal-only A1 board which has different DDR part than all later revs. The timings need a slight adjustment to be correct in all cases with later revs. Signed-off-by: Tom Rini <trini@ti.com>
2013-04-12Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-04-12arm: Remove support for unused s3c64xxBenoît Thébaudeau
Following the removal of the smdk6400 board, the s3c64xx SoC becomes unused, so remove associated code. It will still be possible to restore it later from the Git history if necessary. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12arm: Remove support for smdk6400Benoît Thébaudeau
The migration of boards from Makefile to boards.cfg was due for v2012.03, but smdk6400 did not follow, and it does not build, so move it to scrapyard. It will still be possible to restore it from the Git history before fixing it. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-10am335x: Update timings for the beaglebone againTom Rini
After further testing we can run DDR at 400MHz so update the timings again. Tested-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Tom Rini <trini@ti.com>
2013-04-09am335x/ti814x: Correct MMC_BOOT_DEVICES_START/ENDTom Rini
Given that on TI814x we have MMC1/2 swapped, we also need to swap them in MMC_BOOT_DEVICES_START/END Reported-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Tom Rini <trini@ti.com>
2013-04-08OMAP3/4/5/AM33xx: Correct logic for checking FAT or RAW MMCTom Rini
In the case of booting from certain peripherals, such as UART, we must not see what the device descriptor says for RAW or FAT mode because in addition to being nonsensical, it leads to a hang. This is why we have a test currently for the boot mode being within range. The problem however is that on some platforms we get MMC2_2 as the boot mode and not the defined value for MMC2, and in others we get the value for MMC2_2. This is required to fix eMMC booting on omap5_uevm. Tested on am335x_evm (UART, NAND, SD), omap3_beagle (NAND, SD on classic, SD only on xM rev C5) and omap5_uevm (SD, eMMC). Signed-off-by: Tom Rini <trini@ti.com>
2013-04-08arm: omap4: Fix SDRAM AUTO DETECTIONLokesh Vutla
Commit "8602114 omap: emif: configure emif only when required" breaks SDRAM_AUTO_DETECTION. The issue is dmm_init() depends on emif_sizes[](SDRAM Auto detection) done in do_sdram_init(). The above commit moves dmm_init() above do_sdram_init() because of which dmm_init() uses uninitialized emif_sizes[]. So instead of using global emif_sizes[], get sdram details locally and calculate emif sizes. Reported-by: Michael Cashwell <mboards@prograde.net> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-04-08omap2420-h4: Fix booting from NOR flashHunter, Jon
The omap2420-h4 board is using a RAM based address as the linker location for code. This is causing several problems when attempting to run the latest u-boot code base on this board from flash. Update the default linker location for code to be in NOR flash. Please note that OMAP maps the NOR flash to address 0x08000000 by default and so use this as the default address for the NOR flash. Also remove legacy code that attempts to calculate where in flash the sdata structure, that holds the memory interface configuration data, is located. By changing the default linker location for code to flash this is no longer necessary. Signed-off-by: Jon Hunter <jon-hunter@ti.com>
2013-04-08omap_gpmc: change nandecc commandAndreas Bießmann
With uppcoming BCH support on OMAP devices we need to decide between differnt algorithms when switching the ECC engine. Currently we support 1-bit hammign and 8-bit BCH on HW backend. In order to switch between differnet ECC algorithms we need to change the interface of omap_nand_switch_ecc() also. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Tom Rini <trini@ti.com> Cc: Thomas Weber <thomas.weber.linux@googlemail.com>
2013-04-08omap3/omap_gpmc.h: add ooblayout for BCH8 as in kernelAndreas Bießmann
This patch adds BCH8 ooblayout for NAND as provided by 0e618ef0a6a33cf7ef96c2c824402088dd8ef48c in linux kernel. This Layout is currently only provided for 64 byte OOB. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Tom Rini <trini@ti.com> Cc: Ilya Yanok <ilya.yanok@cogentembedded.com> Cc: Scott Wood <scottwood@freescale.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-08asm/omap_gpmc.h: consolidate common definesAndreas Bießmann
arch/arm/include/asm/arch-am33xx/omap_gpmc.h and arch/arm/include/asm/arch-omap3/omap_gpmc.h are almost the same, consolidate the common parts into a new header. Introduce a new asm/omap_gpmc.h which defines the command part and pulls in the architecture specific one. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Tom Rini <trini@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-08omap3/cpu.h: add BCH supportAndreas Bießmann
This patch adds the BCH result registers to register mapping for OMAP3 gpmc. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Tom Rini <trini@ti.com> Cc: Ilya Yanok <ilya.yanok@cogentembedded.com> Cc: Scott Wood <scottwood@freescale.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-04Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-04-04exynos: change indentation of defines in cpu.hMinkyu Kang
Fix the indentation of some defines by tab. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-04-04Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-04-04ARM: bcm2835: fix get_timer() to return msStephen Warren
Apparently, CONFIG_SYS_HZ must be 1000. Change this, and fix the timer driver to conform to this. Have the timer implementation export a custom API get_timer_us() for use by the BCM2835 MMC API, which needs us resolution for a HW workaround. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2013-04-01Exynos: clock: Add generic api to get the clk freqPadmavathi Venna
Add generic api to get the frequency of the required peripherial. This API gets the source clock frequency and returns the required frequency by dividing with first and second dividers based on the requirement. Test with command "sf probe 1:0; time sf read 40008000 0 1000". Try with different numbers of bytes and see that sane values are obtained Build and boot U-boot with this patch, backlight works properly. Signed-off-by: Padmavathi Venna <padma.v@samsung.com> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-04-01Exynos: Add peripherial id for pwmPadmavathi Venna
Add peripherial id for pwm inorder to support generic api to get the clk frequency Test with command "sf probe 1:0; time sf read 40008000 0 1000". Try with different numbers of bytes and see that sane values are obtained Build and boot U-boot with this patch, backlight works properly. Signed-off-by: Padmavathi Venna <padma.v@samsung.com> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-29Exynos: Add hardware accelerated SHA256 and SHA1Akshay Saraswat
SHA-256 and SHA-1 accelerated using ACE hardware. Signed-off-by: ARUN MANKUZHI <arun.m@samsung.com> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-03-28ARM: mmu: Set domain permissions to client accessR Sricharan
The 'XN' execute never bit is set in the pagetables. This will prevent speculative prefetches to non executable regions. But the domain permissions are set as master in the DACR register. So the pagetable attribute for 'XN' is not effective. Change the permissions to client. This fixes lot of speculative prefetch aborts seen on OMAP5 secure devices. Signed-off-by: R Sricharan <r.sricharan@ti.com> Tested-by: Vincent Stehle <v-stehle@ti.com> Cc: Vincent Stehle <v-stehle@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-28ARM: mmu: Introduce weak dram_bank_setup functionR Sricharan
Introduce a weak version of dram_bank_setup function to allow a platform specific function. This is used in the subsequent patch to setup dram region without 'XN' attribute in order to enable the region under client permissions. Signed-off-by: R Sricharan <r.sricharan@ti.com> Cc: Vincent Stehle <v-stehle@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-28ARM: cache: declare set_section_dcacheVincent Stehlé
We declare the set_section_dcache function globally in the cache header, for later use by e.g. machine specific code. Signed-off-by: Vincent Stehlé <v-stehle <at> ti.com> Cc: Tom Rini <trini <at> ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-27video: exynos_dp: Remove callbacks from the driverAjay Kumar
Replaced the functionality of callbacks by using a standard set of functions. Instead of implementing and hooking up a callback, put the same code in one of the standard set of functions by overriding it. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-26Merge branch 'u-boot-tegra/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-26Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-25Tegra114: Dalmore: Add SDIO3 pad config to pinctrl_config tableTom Warren
SDIO1 (the SD-card slot on Dalmore) needs to have its pads setup before the MMC driver is added. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-25tegra114: add SPI driverAllen Martin
Add driver for tegra114 SPI controller. This controller is not compatible with either the tegra20 or tegra30 controllers, so it requires a new driver. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-25spi: add common fdt SPI driver interfaceAllen Martin
Add a common interface to fdt based SPI drivers. Each driver is represented by a table entry in fdt_spi_drivers[]. If there are multiple SPI drivers in the table, the first driver to return success from spi_init() will be registered as the SPI driver. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-25tegra: spi: pull register structs out of headersAllen Martin
Move register structs from headers into .c files and use common name. This is in preparation of making common fdt front end for SPI drivers. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-25tegra: spi: rename tegra SPI driversAllen Martin
Rename tegra SPI drivers to tegra20_flash and tegra20_slink in preparation for commonization and addition of tegra114_spi. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-25tegra: remove support for UART SPI switchAllen Martin
This feature was only used for tegra20 seaboard that had a pinmux conflict on the SPI pins. These boards were never manufactured, so remove this support to clean up SPI driver. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-24am335x_evm: Add better timings for the new BeagleBoard DDR3 partTom Rini
Tested-by: Rao Bodapati <rao@circuitco.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-03-24am33xx: support ti814x mmc reference clockMatt Porter
TI814x has a 192MHz hsmmc reference clock. Select that clock rate when building for TI814x. Signed-off-by: Matt Porter <mporter@ti.com>
2013-03-24am33xx: add dmm support to emif4 libraryMatt Porter
Adds a config_dmm() routine to support TI814X DMM configuration. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-24am33xx: add ti814x specific register definitionsMatt Porter
Support the ti814x specific register definitions within arch-am33xx. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-24am33xx: refactor am33xx mux support and add ti814x supportMatt Porter
AM33XX and TI814X have a similar mux though the pinmux register layout and address space differ. Add a separate ti814x mux include to support the TI814X-specific differences. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com> Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
2013-03-24am33xx: refactor am33xx clocks and add ti814x supportMatt Porter
Split clock.c for am335x and ti814x and add ti814x specific clock support. Signed-off-by: Matt Porter <mporter@ti.com>
2013-03-24am33xx: refactor emif4/ddr to support multiple EMIF instancesMatt Porter
The AM33xx emif4/ddr support closely matches what is need to support TI814x except that TI814x has two EMIF instances. Refactor all the emif4 helper calls and the config_ddr() init function to use an additional instance number argument. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-24am33xx: convert defines from am33xx-specific to generic namesMatt Porter
Eliminate AM33xx specific names to prepare for TI814x support within AM33xx-land. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-24am33xx: Add required includes to some omap/am33xx codeTom Rini
- In arch/arm/cpu/armv7/omap-common/timer.c, drivers/mtd/nand/omap_gpmc.c and drivers/net/cpsw.c add #include files that the driver needs but had been relying on <config.h> to bring in. - In arch/arm/cpu/armv7/omap-common/lowlevel_init.S add <config.h> - In am335x_evm.h and pcm051.h don't globally include <asm/arch/hardware.h> and <asm/arch/cpu.h> but just <asm/arch/omap.h> as that is the only include which defines things the config uses. Cc: Lars Poeschel <poeschel@lemonage.de> Signed-off-by: Tom Rini <trini@ti.com>
2013-03-24am335x: Enable DDR PHY dynamic power down bit for DDR3 boardsVaibhav Hiremath
Enable DDR PHY dynamic power down bit, which enables powering down the IO receiver when not performing read. This also helps in reducing overall power consumption in low power states (suspend/standby). Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Satyanarayana, Sandhya <sandhya.satyanarayana@ti.com> Cc: Tom Rini <trini@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-22Allow AM335x MPU core clock speed to be specified in the board config fileMark Jackson
Allow AM335x MPU core clock speed to be specified in the board config file. To use, add the following to the board's config file:- #define CONFIG_SYS_MPUCLK <desired clock freq in MHz> Signed-off-by: Mark Jackson <mpfj@newflow.co.uk> Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
2013-03-20ARM: rpi_b: enable SD controller, add related env/cmdsStephen Warren
Enable the SD controller driver for the Raspberry Pi. Enable a number of useful MMC, partition, and filesystem-related commands. Set up the environment to provide standard locations for loading a kernel, DTB, etc. Provide a boot command that loads and executes boot.scr.uimg from the SD card; this is written considering future extensibilty to USB storage. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
