On popular request make the display driver from T20 work on T30 as
well. Turned out to be quite straight forward. However a few notes
about some things encountered during porting: Of course the T30 device
tree was completely missing host1x as well as PWM support but it turns
out this can simply be copied from T20. The only trouble compiling the
Tegra video driver for T30 had to do with some hard-coded PWM pin
muxing for T20 which is quite ugly anyway. On T30 this gets handled by
a board specific complete pin muxing table. The older Chromium U-Boot
2011.06 which to my knowledge was the only prior attempt at enabling a
display driver for T30 for whatever reason got some clocking stuff
mixed up. Turns out at least for a single display controller T20 and
T30 can be clocked quite similar. Enjoy.
(cherry picked from commit 5a472ddd7a2a017747d6c05c65eba2cd3804c02f)
The Vybrid SoC family has the same display controller unit (DCU)
like the LS1021A SoC. This patch adds platform data, pinmux defines
and clock control to enable the driver for Vybrid based boards too.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Add declaration for arch_auxiliary_core_check_up which can be useful
to add board specific behavior.
This patch is a porting of
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/commit/?h=imx_4.1.15_1.0.0_ga&id=e4dacc44d22e9474ec456cb330df525cd805ea38
i.MX6QP and i.MX7D BCH module integrated a new feature to detect the
bitflip number for erased NAND page. So for these two platform, set the
erase threshold to gf/2 and if bitflip detected, GPMI driver will
correct the data to all 0xFF.
Also updated the imx6qp dts file to ditinguish the GPMI module for i.MX6Q
with the one for i.MX6QP.
In this patch, i.MX6UL is added and threshold changed to use ecc_strength.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Introduce CONFIG_TEGRA124_MMC_DISABLE_EXT_LOOPBACK to disable the external clock
loopback and use the internal one on SDMMC3 as per the SDMMC_VENDOR_MISC_CNTRL_0
register's SDMMC_SPARE1 bits being set to 0xfffd according to the TRM.
The ipu has two display interfaces. Make the used one a parameter
in struct display_info_t instead of using unconditionally DI0.
DI0 is the default setting.
Reviewed-by: Eric Nelson <eric@nelint.com>
(cherry picked from commit 15fde0fc11f93f19f40c9cda36e7c8d4848d9c75)
While we setup the mmu initially we mark set_section_dcache with
DCACHE_OFF flag. In case of non-LPAE mode the DCACHE_OFF macro
is rightly defined with TTB_SECT_XN_MASK set so as to mark all the
4GB XN. In case of LPAE mode XN(Execute-never) bit is not set with
DCACHE_OFF. Hence XN bit is not set by default for DCACHE_OFF which
keeps all the regions execute okay and this leads to random speculative
fetches in random memory regions which was eventually caught by kernel
omap-l3-noc driver.
Fix this to mark the regions as XN by default.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Reviewed-by: Alexander Graf <agraf@suse.de>
SoC-specific logic may be required for all forms of cache-wide
operations; invalidate and flush of both dcache and icache (note that
only 3 of the 4 possible combinations make sense, since the icache never
contains dirty lines). This patch adds an optional hook for all
implemented cache-wide operations, and renames the one existing hook to
better represent exactly which operation it is implementing. A dummy
no-op implementation of each hook is provided.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Add support for rk3288 dram capacity auto detect, support DDR3 and
LPDDR3, DDR2 is not supported.
The program will automatically detect:
- channel number
- rank number
- column address number
- row address number
The dts file do not need to describe those info after apply this patch.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Tested-by: Vagrant Cascadian <vagrant@debian.org>
This function is called from outside the driver. It should be placed into
common SoC code. Move it.
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Also rename the driver symbol to be more consistent with the other rockchip
clock drivers.
clock drivers.
The A80 has SID e-fuses. Like other newer SoCs, the actual e-fuses
are at an offset of 0x200 within the SID address space.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Acked-by: Hans de Goede <hdegoede@redhat.com>
This is a cleaned up version set_pll() from Allwinner's boot0 source
(bootloader/basic_loader/bsp/bsp_for_a80/common/common.c).
[wens@csie.org: Added commit message; style cleanup]
On sun9i, the GTBUS manages transaction priority and bandwidth
for multiple read ports when accessing DRAM. The initialisation
mirrors the settings from Allwinner's boot0 for now, even though
this may not be optimal for all applications (e.g. headless
systems might want to give priority to IO modules).
Adding a common callout to gtbus_init() from the SPL clock init
with a weakly defined implementation in sunxi/clock.c to fallback
to for platforms that don't require this.
[wens@csie.org: Moved gtbus_sun9i.c to arch/arm/mach-sunxi/; style cleanup]
This adds DRAM initialisation code for sun9i, which calculates the
appropriate timings based on timing information for the supplied
DDR3 bin and the clock speeds used.
With this DRAM setup, we have verified DDR3 clocks of up to 792MHz
(i.e. DDR3-1600) on the A80-Q7 using a dual-channel configuration.
[wens@csie.org: Moved dram_sun9i.c to arch/arm/mach-sunxi/; style cleanup]
[hdegoede@redhat.com: Drop some huge non-documenting #if 0 ... #endif blocks]
[hdegoede@redhat.com: Fix checkpatch warnings]
Mostly by adding MACH_SUN50I to some existing #ifdefs enable support
for the the HCI0 USB host controller on the A64.
Fix up some minor 64-bit hiccups on the way.
Add the bare minimum DT bits to the A64 .dtsi and enable the controllers
and the PHY on the Pine64.
This is limited to the first USB controller at the moment, which is
connected to the lower USB socket on the Pine64 board.
[Andre: remove unneeded defines, enable OHCI, add commit message]
Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
common/Kconfig
configs/dms-ba16_defconfig
Boot Log for i.CoreM6 DualLite/Solo Starter Kit:
U-Boot SPL 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46)
Trying to boot from MMC1
U-Boot 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46 +0530)
CPU: Freescale i.MX6SOLO rev1.3 at 792MHz
CPU: Industrial temperature grade (-40C to 105C) at 31C
Reset cause: POR
DRAM: 256 MiB
MMC: FSL_SDHC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: CPU Net Initialization Failed
No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
reading boot.scr
** Unable to read file boot.scr **
reading zImage
6741808 bytes read in 341 ms (18.9 MiB/s)
Booting from mmc ...
reading imx6dl-icore.dtb
30600 bytes read in 19 ms (1.5 MiB/s)
Booting using the fdt blob at 0x18000000
Using Device Tree in place at 18000000, end 1800a787
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
Boot Log for i.CoreM6 Quad/Dual Starter Kit:
CPU: Freescale i.MX6Q rev1.2 at 792MHz
CPU: Industrial temperature grade (-40C to 105C) at 28C
Reset cause: POR
DRAM: 512 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
No ethernet found.
icorem6qdl>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Matteo Lisi <matteo.lisi@engicam.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Acked-by: Peng Fan <peng.fan@nxp.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Add mx7_plugin.S which calls boot rom setup function, generate the second ivt,
and jump back to boot rom.
Signed-off-by: Ye Li <ye.li@nxp.com>
Add mx6_plugin.S which calls boot rom setup function, generate the second ivt,
Signed-off-by: Utkarsh Gupta <utkarsh.gupta@nxp.com>
Acked-by: Utkarsh Gupta <utkarsh.gupta@nxp.com>
Using PSCI you can not only reset the system, you can also shut it down!
This patch exposes a function to do exactly that to whatever code wants
to make use of it.
All systems that are running on armv8 are running bare metal with firmware
that implements PSCI running in EL3. That means we don't really need to expose
the hypercall variants of them.
This patch leaves the code in, but makes the code explicit enough to have the
compiler optimize it out. With this we don't need to worry about hvc vs smc
calling convention when calling psci helper functions.
include/configs/ls1021aqds.h
include/configs/ls1021atwr.h
Add silicon ID code for AM437x silicon. This can be used to print
the cpu info using CONFIG_DISPLAY_CPUINFO.
Also printing "CPU :" along with cpu name in order to be consistent
with other OMAP platforms.
The normal longjmp command allows for a caller to pass the return value
of the setjmp() invocation. This patch adds that semantic to the arm
implementation of it and adjusts the efi_loader call respectively.
The KeyStone platform has its own clk_get_rate() but its prototype
is different from that of the common-clk (clk-uclass) framework.
Prefix the KeyStone specific implementation with ks_ in order to
avoid name-space conflict.
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
Register definitions needed for configuring the
ePWM module.
Signed-off-by: Tomas Melin <tomas.melin@vaisala.com>
On some of the SoCs one cannot enable hypervisor mode directly from the
u-boot because the ROM code puts the chip to supervisor mode after it
jumps to boot loader. Hence introduce a weak function which can be
overridden based on the SoC type and switch to hypervisor mode in a
custom way.
Cc: beagleboard-x15@googlegroups.com
These functions are needed in UBI/UBIFS on ZynqMP platform (ARM64).
Signed-off-by: Adam Oleksy <adam.oleksy@nokia.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Fix various misspellings of:
* deprecated
* partition
* preceding,preceded
* preparation
* its versus it's
* export
* existing
* scenario
* redundant
* remaining
* value
* architecture
Reviewed-by: Jagan Teki <jteki@openedev.com>
At present this is only used on ARM and sandbox, but it is just as
applicable to other architectures. Move the function prototype into the
generic SPL header.
Move DDR3, DDR4 and related config options to Kconfig and clean up
existing uses.
Signed-off-by: York Sun <york.sun@nxp.com>
Move DDR3, DDR4 and realted options to Kconfig and clean up existing
uses.
Move these options to Kconfig and clean up existing uses.
Move this option to Kconfig and clean up existing uses.
NUM_DDR_CONTROLLERS is also used by PowerPC SoCs.
This option is also used by PowerPC SoCs.
Move MAX_CPUS option to Kconfig and clean up existing uses for ARM. This
option is used by Freescale Layerscape SoCs.
Pin mux logic has 2 options in priority order, one is through RCW_SRC
and then through RCW_Fields. In case of QSPI booting, RCW_SRC logic
takes the priority for SPI pads and do not allow RCW_BASE and SPI_EXT
to control the SPI muxing. But actually those are DSPI controller's
pads instead of QSPI controller's, so this workaround allows RCW
fields SPI_BASE and SPI_EXT to control relevant pads muxing.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
[York Sun: Reformatted commit message]
Reviewed-by: York Sun <york.sun@nxp.com>
The core position is not continuous for some SoCs. For example,
valid cores may present at position 0, 1, 4, 5, 8, 9, etc. Some
registers (including boot release register) only count existing
cores. Current implementation of cpu_mask() complies with the
continuous numbering. However, command "cpu status" queries the
spin table with actual core position. Add functions to calculate
core position from core number, to correctly calculate offsets.
Tested on LS2080ARDB and LS1043ARDB.
By default the SATA IP on the ls1043a/ls1046a SoCs does not
generating coherent/snoopable transactions. This patch enable
it in the SCFG_SNPCNFGCR register along with sata axicc register.
In addition, the dma-coherent property must be set on the SATA
controller nodes.
Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com>
The default values for Port Phy2Cfg register and
Port Phy3Cfg register are better, no need to overwrite them.
For i.MX6, the mux width is 4, not 3. So enlarge the width.
IOMUX_CONFIG_LPSR is changed from 0x8 to 0x20 to not use bit 3 of mux.
SNVS TAMPER pin and BOOT MODE pins are in SNVS IOMUXC module,
not in IOMUXC, so correct the related registers' offset.
Use IOMUX_CONFIG_LPSR flag for these pins, so we can differentiate
them from iomuxc pins.
Cc: "Benoît Thébaudeau" <benoit.thebaudeau.dev@gmail.com>
Per to design team, on i.MX6UL, the LDO 1.2V bandgap voltage
is 30mV higher, so we need to adjust the REFTOP_VBGADJ(anatop
MISC0 bit[6:4]) setting to 2b'110.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
Update memory map address for mx6ull.
Update Clock settings and CCM register map for i.MX6ULL.
Introduce is_mx6ull macro.
Add i.MX6ULL major cpu type.
Reviewed-by: Stefano Babic <sbabic@denx.de>
