When starting i.MX SoC's with BOOT_MODE b01, the boot ROM enteres
Serial Downloader mode. However, serial download does not necessarily
means booting from UART. The boot ROM also supports booting from USB.
Create a technology neutral boot mode called SDP (serial download
protocol).
At present this is only used on ARM and sandbox, but it is just as
applicable to other architectures. Move the function prototype into the
generic SPL header.
This enum is needed when SPL_DFU is enabled.
This enum is referenced from common/spl/spl.c.
Make spl_*_load_image() functions return a value instead of
hanging if a problem is encountered. This enables main spl code
to make the decision whether to hang or not, thus preparing
it to support alternative boot devices.
Some boot devices (namely nand and spi) do not hang on error.
Instead, they return normally and SPL proceeds to boot the
contents of the load address. This is considered a bug and
is rectified by hanging on error for these devices as well.
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Hans De Goede <hdegoede@redhat.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Jagan Teki <jteki@openedev.com>
This is already set up in crt0.S. We don't need a new structure and don't
really want one in the 'data' section of the image, since it will be empty
and crt0.S's changes will be ignored.
As an interim measure, remove it only if CONFIG_DM is not defined. This
allows us to press ahead with driver model in SPL and allow the stragglers
to catch up.
Some boards have a special way of loading U-Boot that does not fit with
the existing SPL code. For example sunxi uses an 'FEL' mode where U-Boot
is loaded over USB. Add a CONFIG option and boot mode for this.
Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
Acked-by: Hans de Goede <hdegoede@redhat.com>
Switch to the common spl.h file and zap the arch/spl.h . Since the arch/spl.h
contained various ad-hoc symbols, zap those symbols as well and rework the
board configuration a little so it doesn't depend on them.
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@altera.com>
Cc: Vince Bridgers <vbridger@altera.com>
Acked-by: Pavel Machek <pavel@denx.de>
Do not specify own zynq specific SPL macros
because there is no need for that.
Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
arch/arm/include/asm/spl.h requires all SoCs to have
arch/arm/include/asm/arch-*/spl.h.
But many of them just define BOOT_DEVICE_* macros.
Those macros are used in the "switch (boot_device) { ... }"
statement in common/spl/spl.c.
So they should not be archtecture specific, but be described as
a simpile enumeration.
This commit merges most of arch/arm/include/asm/arch-*/spl.h
into arch/arm/include/asm/spl.h.
With a little more effort, arch-zynq/spl.h and arch-socfpga/spl.h
will be merged, while I am not sure about OMAP and Exynos.
Cc: Tom Rini <trini@ti.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Tom Warren <twarren@nvidia.com>
CC: Stefano Babic <sbabic@denx.de>
CC: Minkyu Kang <mk7.kang@samsung.com>
Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
Acked-by: Michal Simek <monstr@monstr.eu>
Acked-by: Tim Harvey <tharvey@gateworks.com>
Tested-by: Bo Shen <voice.shen@atmel.com> [on sama5d3xek board for at91 part]
Tested-by: Stefano Babic <sbabic@denx.de> [applying Tim's i.MX6 patches]
Acked-by: Tom Rini <trini@ti.com>
[trini: Fixup common/cmd_io.c]
Note this is a tree-wide change affecting multiple architectures.
At present we use __bss_start, but mostly __bss_end__. This seems
inconsistent and in a number of places __bss_end is used instead.
Change to use __bss_end for the BSS end symbol throughout U-Boot. This
makes it possible to use the asm-generic/sections.h file on all
archs.
In SPL (CONFIG_SPL_FRAMEWORK) board_init_f must setup the stack pointer,
clear the BSS and call board_init_r. We mark this as weak as some
platforms may need to perform additional initalization at this point.
We provide a gd that we know will be in a usable location, once the BSS
has been cleared to help with this as well. Finally, we no longer call
relocate_code so remove that from the armv7 version.
Next, both board_init_f and jump_to_image_linux are going to be
inherently arch-specific, so move these versions to arch/arm/lib/spl.c
Add a new flag, CONFIG_SPL_FRAMEWORK to opt into the common/spl SPL
framework, enable on all of the previously using boards. We move the
spl_ymodem.c portion to common/ and spl_mmc.c to drivers/mmc/. We leave
the NAND one in-place as we plan to replace it later in this series.
We use common/spl to avoid linker problems with respect to merging
constant strings in objects. Otherwise all strings in common/ will be
linked in and kept which grows SPL in size too much.
Move the default omap/related-centric board_mmc_init to
arch/arm/cpu/armv7/omap-common/boot-common.c and move the type defines
to <asm/spl.h>. Also use mmc->read_bl_len rather than MMCSD_SECTOR_SIZE
Move the SPL prototypes from <asm/omap_common.h> into <asm/spl.h> and
add <asm/arch/spl.h> for arch specific portions of CONFIG_SPL_FRAMEWORK.
