path: root/arch/arm/include/asm/sections.h
2013-03-15Introduce generic link section.h symbol filesSimon Glass
We create a separate header file for link symbols defined by the link scripts. It is helpful to have these all in one place and try to make them common across architectures. Since Linux already has a similar file, we bring this in even though many of the symbols there are not relevant to us. Each architecture has its own asm/sections.h where symbols specifc to that architecture can be added. For now everything except AVR32 just includes the generic header. One change is needed in arch/avr32/lib/board.c to make this conversion work. Reviewed-by: Tom Rini <trini@ti.com> (version 5) Signed-off-by: Simon Glass <sjg@chromium.org>
