path: root/arch/arm/include/asm/omap_mmc.h
2013-03-08omap_hsmmc: add driver check for write protectionNikita Kiryanov
Add check for write protection in omap mmc driver. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: implement driver check for card detectionNikita Kiryanov
Implement driver check for card detection. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-03-08omap: consolidate common mmc definitionsNikita Kiryanov
The various mmc_host_def.h files are almost identical. Reduce code duplication by moving the similar definitions to a common header file. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
