path: root/arch/arm/include/asm/macro.h
2015-03-10Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
Conflicts: README Signed-off-by: Tom Rini <trini@konsulko.com>
2015-03-09armv8/vexpress64: make multientry conditionalLinus Walleij
While the Freescale ARMv8 board LS2085A will enter U-Boot both on a master and a secondary (slave) CPU, this is not the common behaviour on ARMv8 platforms. The norm is that U-Boot is entered from the master CPU only, while the other CPUs are kept in WFI (wait for interrupt) state. The code determining which CPU we are running on is using the MPIDR register, but the definition of that register varies with platform to some extent, and handling multi-cluster platforms (such as the Juno) will become cumbersome. It is better to only enable the multiple entry code on machines that actually need it and disable it by default. Make the single entry default and add a special ARMV8_MULTIENTRY KConfig option to be used by the platforms that need multientry and set it for the LS2085A. Delete all use of the CPU_RELEASE_ADDR from the Vexpress64 boards as it is just totally unused and misleading, and make it conditional in the generic start.S code. This makes the Juno platform start U-Boot properly. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-01-31Errata/ARM57: Add basic constructs to handle and apply A57 specific erratasBhupesh Sharma
This patch adds basic constructs in the ARMv8 u-boot code to handle and apply Cortex-A57 specific erratas. As and example, the framework showcases how erratas 833069, 826974 and 828024 can be handled and applied. Later on this framework can be extended to include other erratas. Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
2014-10-28gic: fixed compilation error in GICv2 wait for interrupt macroYehuda Yitschak
a hexadicemal value was missing the "0x" prefix which caused assembler error Signed-off-by: Yehuda Yitschak <yehuday@marvell.com>
2014-09-25armv8/fsl-lsch3: Release secondary cores from boot hold off with Boot PageYork Sun
Secondary cores need to be released from holdoff by boot release registers. With GPP bootrom, they can boot from main memory directly. Individual spin table is used for each core. Spin table and the boot page is reserved in device tree so OS won't overwrite. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Arnab Basu <arnab.basu@freescale.com>
2014-01-09arm64: core supportDavid Feng
Relocation code based on a patch by Scott Wood, which is: Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: David Feng <fenghua@phytium.com.cn>
2010-04-13Move architecture-specific includes to arch/$ARCH/include/asmPeter Tyser
This helps to clean up the include/ directory so that it only contains non-architecture-specific headers and also matches Linux's directory layout which many U-Boot developers are already familiar with. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
