path: root/arch/arm/include/asm/gpio.h
2019-05-01rockchip: arm: use 'arch-rockchip' for common headerKever Yang
rockchip platform header file is in 'arch-rockchip' instead of arch-$(SOC) for all SoCs. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-04-12gpio: do not include <asm/arch/gpio.h> on ARCH_BCM63158Philippe Reynes
As no gpio.h is defined for this architecture, to avoid a compilation failure, do not include <asm/arch/gpio.h> for arch bcm63158. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2019-04-12gpio: do not include <asm/arch/gpio.h> on ARCH_BCM6858Philippe Reynes
As no gpio.h is defined for this architecture, to avoid compilation failure, do not include <asm/arch/gpio.h> for arch bcm6858. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2018-09-11gpio: do not include <asm/arch/gpio.h> for ARCH_K3Lokesh Vutla
As no gpio.h is defined in arch/arm/mach-k3/include/, to avoid compilation failure, do not include asm/arch/gpio.h. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-03-14gpio: do not include <asm/arch/gpio.h> for ARCH_STIPatrice Chotard
As no gpio.h is defined in arch/arm/include/asm/arch-stih410, to avoid compilation failure, do not include asm/arch/gpio.h. This is needed for example when including sdhci.h, which include asm/gpio.h>. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-29gpio: do not include <asm/arch/gpio.h> for UniPhierMasahiro Yamada
I implemented a GPIO driver based on Driver Model for the UniPhier SoC family, but I could not find any good reason why such SoC specific GPIO headers are needed. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-01-09gpio: Replace ARM gpio.h with the common API in include/asm-genericJoe Hershberger
ARM boards should use the generic GPIO API This means changing gpio to unsigned type Remove the unused gpio_toggle() function which is not part of the API Comment that free should not modify pin state Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> fixed merge conflict in da8xx_gpio.c, tegra2_gpio.c, and extended to the new mxs_gpio.c. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-07-04GPIO: Tegra2: add GPIO driver for Tegra2Tom Warren
Signed-off-by: Tom Warren <twarren@nvidia.com>
