path: root/arch/arm/include/asm/emif.h
2018-01-19cmd: ti: Generalize cmd_ddr3 commandLokesh Vutla
Keystone and DRA7 based TI platforms uses same EMIF memory controller. cmd_ddr3 command is customized for keystone platforms, make it generic so that it can be re used for DRA7 platforms. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-01-19arm: emif-common: Add suppport for enabling ECCLokesh Vutla
For data integrity, the EMIF1 supports ECC on the data written or read from the SDRAM. Add support for enabling ECC support in EMIF1. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Krunal Bhargav <k-bhargav@ti.com>
2018-01-19arm: emif-common: Add ecc specific emif registersLokesh Vutla
This is a slight difference in emif_ddr_phy_status register offsets for DRA7xx EMIF and older versions. And ecc registers are available only in DRA7xx EMIC. Add support for this difference and ecc registers. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-12-09arm: am33xx: Initialize EMIF REG_PR_OLD_COUNT for BBB and am335x-evmJyri Sarha
Initialize EMIF OCP_CONFIG registers REG_COS_COUNT_1, REG_COS_COUNT_2, and REG_PR_OLD_COUNT field for Beaglebone-Black and am335x-evm. With the default values LCDC suffers from DMA FIFO underflows and frame synchronization lost errors. The initialization values are the highest that work flawlessly when heavy memory load is generated by CPU. 32bpp colors were used in the test. On BBB the video mode used 110MHz pixel clock. The mode supported by the panel of am335x-evm uses 30MHz pixel clock. Signed-off-by: Jyri Sarha <jsarha@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-15ARM: DRA7: DDR: Enable SR in Power Management ControlNishanth Menon
If EMIF is idle for certain amount of DDR cycles, EMIF will put the DDR in self refresh mode to save power if EMIF_PWR_MGMT_CTRL register is programmed. And also before entering suspend-resume ddr needs to be put in self-refresh. Linux kernel does not program this register before entering suspend and relies on u-boot setting. So configuring it in u-boot. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14ARM: DRA7: emif: Enable interleaving for higher address spaceLokesh Vutla
Given that DRA7/OMAP5 SoCs can support more than 2GB of memory, enable interleaving for this higher memory to increase performance. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14ARM: DRA7: emif: Check for enable bits before updating leveling outputLokesh Vutla
Read and write leveling can be enabled independently. Check for these enable bits before updating the read and write leveling output values. This will allow to use the combination of software and hardware leveling. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-15am33xx: Re-enable SW levelling for DDR2Tom Rini
The recent changes for hw leveling on am33xx were not intended for DDR2 boards, only DDR3. Update emif_sdram_type to take a sdram_config value to check against. This lets us pass in the value we would use to configure, when we have not yet configured the board yet. In other cases update the call to be as functional as before and check an already programmed value in. Tested-by: Yan Liu <yan-liu@ti.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-06-12ARM: DRA7: DDR3: Add support for HW levelingLokesh Vutla
DRA7 EMIF supports Full leveling for DDR3. Adding support for the Full leveling sequence. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-02-16ARM: DRA7: EMIF: Update SDRAM_REF_CTRL register valueLokesh Vutla
The value in SDRAM_REF_CTRL controls the delay time between the initial rising edge of DDR_RESETn to rising edge of DDR_CKE (JEDEC specs this as 500us). In order to achieve this, SDRAM_REF_CTRL should be written with a value corresponding to 500us delay before starting DDR initialization sequence, and configure proper value at the end of sequence. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-01-13arm: am437x: Enable hardware leveling for EMIFJames Doublesin
Switch to using hardware leveling for certain parameters on the EMIF rather than using precalculated values. Doing this also means we have a common place now between am437x and am335x for setting emif_sdram_ref_ctrl with a value for the correct delay length. Tested-by: Felipe Balbi <balbi@ti.com> Tested-by: Tom Rini <trini@ti.com> Signed-off-by: James Doublesin <doublesin@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2014-08-09emif.h: remove duplicated argument to |maxin.john@enea.com
Remove the duplicated argument to | in two places. Reported by Coccinelle (http://coccinelle.lip6.fr/). Signed-off-by: Maxin B. John <maxin.john@enea.com>
2014-07-07am43xx: Tune the system to avoid DSS underflowsCooper Jr., Franklin
* This is done by limiting the ARM's bandwidth and setting DSS priority in the EMIF controller to ensure underflows do not occur.
2013-12-18ARM: AM43xx: GP_EVM: Add support for DDR3Lokesh Vutla
GP EVM has 1GB DDR3 attached(Part no: MT41K512M8RH). Adding details for the same. Below is the brief description of DDR3 init sequence(SW leveling): -> Enable VTT regulator -> Configure VTP -> Configure DDR IO settings -> Disable initialization and refreshes until EMIF registers are programmed. -> Program Timing registers -> Program leveling registers -> Program PHY control and Temp alert and ZQ config registers. -> Enable initialization and refreshes and configure SDRAM CONFIG register Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-12-18ARM: AM43xx: EPOS_EVM: Add support for LPDDR2Lokesh Vutla
AM4372 EPOS EVM has 1GB LPDDR2(Part no: MT42L256M32D2LG-25 WT:A) Adding LPDDR2 init sequence and register details for the same. Below is the brief description of LPDDR2 init sequence: -> Configure VTP -> Configure DDR IO settings -> Disable initialization and refreshes until EMIF registers are programmed. -> Program Timing registers -> Program PHY control and Temp alert and ZQ config registers. -> Enable initialization and refreshes and configure SDRAM CONFIG register -> Wait till initialization is complete and the configure MR registers. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-12-04ARM: DRA7/OMAP5: EMIF: Add workaround for bug 0039SRICHARAN R
When core power domain hits oswr, then DDR3 memories does not come back while resuming. This is because when EMIF registers are lost, then the controller takes care of copying the values from the shadow registers. If the shadow registers are not updated with the right values, then this results in incorrect settings while resuming. So updating the shadow registers with the corresponding status registers here during the boot. Signed-off-by: Sricharan R <r.sricharan@ti.com>
2013-12-04ARM: DRA: EMIF: Change DDR3 settings to use hw levelingSRICHARAN R
Currently the DDR3 memory on DRA7 ES1.0 evm board is enabled using software leveling. This was done since hardware leveling was not working. Now that the right sequence to do hw leveling is identified, use it. This is required for EMIF clockdomain to idle and come back during lowpower usecases. Signed-off-by: Sricharan R <r.sricharan@ti.com>
2013-06-10ARM: DRA7xx: EMIF: Change settings required for EVM boardSricharan R
DRA7 EVM board has the below configuration. Adding the settings for the same here. 2Gb_1_35V_DDR3L part * 2 on EMIF1 2Gb_1_35V_DDR3L part * 4 on EMIF2 Signed-off-by: Sricharan R <r.sricharan@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-04-08arm: omap4: Fix SDRAM AUTO DETECTIONLokesh Vutla
Commit "8602114 omap: emif: configure emif only when required" breaks SDRAM_AUTO_DETECTION. The issue is dmm_init() depends on emif_sizes[](SDRAM Auto detection) done in do_sdram_init(). The above commit moves dmm_init() above do_sdram_init() because of which dmm_init() uses uninitialized emif_sizes[]. So instead of using global emif_sizes[], get sdram details locally and calculate emif sizes. Reported-by: Michael Cashwell <mboards@prograde.net> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-03-11arm: dra7xx: Add DDR related data for DRA752 ES1.0Lokesh Vutla
DRA752 uses DDR3. Populating the corresponding structures with DDR3 data. Writing into MA registers if only MA is present in that soc. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: R Sricharan <r.sricharan@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-11ARM: OMAP5: Add DDR changes required for OMAP543X ES2.0 SOCsLokesh Vutla
Add pre calculated timing settings of LPDDR2 and DDR3 memories present in OMAP5430 and OMAP5432 ES2.0 versions. Also adding the DDR pad io settings required for OMAP543X SOCs here. Signed-off-by: R Sricharan <r.sricharan@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Tom Rini <trini@ti.com>
2013-03-11ARM: OMAP4+: Cleanup emif specific filesLokesh Vutla
Removing the duplicated code in ddr3 initialization. Also creating structure for lpddr2 mode registers to avoid unnessecary revision checks. These change reduces code addition for future Socs. Signed-off-by: R Sricharan <r.sricharan@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-11ARM: OMAP4+: emif: Detect SDRAM from SDRAM config registerLokesh Vutla
Now SDRAM initialization is done on the basis of omap revision. Instead this should be done on basis of SDRAM type read from EMIF_SDRAM_CONFIG register. This will be helpful to avoid unnessecary cpu checks for new boards Signed-off-by: R Sricharan <r.sricharan@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2012-09-01am33xx: Pass to config_ddr the type of memory that is connectedTom Rini
We need to pass in the type of memory that is connected to the board. The only reliable way to do this is to know what type of board we are running on (which later will be knowable in s_init()). For now, pass in the value of DDR2. Signed-off-by: Tom Rini <trini@ti.com>
2012-07-07ARM: OMAP4+: Move external phy initialisations to arch specific place.SRICHARAN R
The external phy is present in the case OMAP5 soc is currently configured in emif-common.c. This results in having dummy structures for those Socs which do not have a external phy. So by having a weak function in emif-common and overriding it in OMAP5, avoids the use of dummy structures. Signed-off-by: R Sricharan <r.sricharan@ti.com>
2012-07-07OMAP5: EMIF: Add support for DDR3 deviceLokesh Vutla
In OMAP5432 EMIF controlller supports DDR3 device. This patch adds support for ddr3 device intialization and configuration. Initialization sequence is done as specified in JEDEC specs. This also adds support for ddr3 leveling. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2012-07-07OMAP5: ADD precalculated timings for ddr3Lokesh Vutla
Adding precalculated timings for ddr3 with 1cs adding required registers for ddr3 Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2012-05-15OMAP4/5: emif: Correct the emif power mgt shadow register bit fields.SRICHARAN R
PD_TIM bit field which specifies the power down timing is defined to occupy bits 8-11, where as it is actually from 12-15 bits. So correcting this. Signed-off-by: R Sricharan <r.sricharan@ti.com>
2012-05-15OMAP5: emif/ddr: Change emif settings as required for ES1.0 silicon.SRICHARAN R
The OMAP5 silicon has new DDR PHY design, which includes a external PHY as well. So configuring the ext PHY parameters here. Also the EMIF timimg registers and a couple of DDR mode registers needs to be updated based on the testing from the actual silicon. Signed-off-by: R Sricharan <r.sricharan@ti.com>
2011-11-15omap5: emif: Add emif/ddr configurations required for omap5 evmSricharan
Add the emif configurations required for omap5 soc.Add the correct ddr part configurations required for omap5 evm board. EDB8164B3PH from ELPIDA is the part used on the board. Also changes are done to retain some part of the code common for OMAP4/5 and keep only the remaining in the Soc specific directories. Signed-off-by: sricharan <r.sricharan@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
