path: root/arch/arm/include/asm/cache.h
2014-01-09arm64: core supportDavid Feng
Relocation code based on a patch by Scott Wood, which is: Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: David Feng <fenghua@phytium.com.cn>
2013-03-28ARM: mmu: Introduce weak dram_bank_setup functionR Sricharan
Introduce a weak version of dram_bank_setup function to allow a platform specific function. This is used in the subsequent patch to setup dram region without 'XN' attribute in order to enable the region under client permissions. Signed-off-by: R Sricharan <r.sricharan@ti.com> Cc: Vincent Stehle <v-stehle@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-28ARM: cache: declare set_section_dcacheVincent Stehlé
We declare the set_section_dcache function globally in the cache header, for later use by e.g. machine specific code. Signed-off-by: Vincent Stehlé <v-stehle <at> ti.com> Cc: Tom Rini <trini <at> ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-10-23arm: cache: define ARCH_DMA_MINALIGN for DMA buffer alignmentAnton Staaf
Signed-off-by: Anton Staaf <robotboy@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2010-04-13Move architecture-specific includes to arch/$ARCH/include/asmPeter Tyser
This helps to clean up the include/ directory so that it only contains non-architecture-specific headers and also matches Linux's directory layout which many U-Boot developers are already familiar with. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
