path: root/arch/arm/include/asm/arch-vf610/ddrmc-vf610.h
2015-10-02vf610: refactor DDRMC codeAlbert ARIBAUD \\(3ADEV\\)
The VF610 DDRMC driver code contains settings which are board-specific. Move these out to boards so that new boards can define their own without having to modify the driver. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-04-23ARM: vf610: Move DDR3 initialization to imx-commonSanchayan Maity
In order to avoid code duplication, move the DDR3 initialization to the common place under imx-common. Currently ROW_DIFF and COL_DIFF can be chosen from the board file. The JEDEC timings are specified using a common ddr3_jedec_timings structure. Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
