path: root/arch/arm/include/asm/arch-tegra
2016-09-27ARM: tegra: add APIs the clock uclass driver will needStephen Warren
A future patch will implement a clock uclass driver for Tegra. That driver will call into Tegra's existing clock code to simplify the transition; this avoids tieing the clock uclass patches into significant refactoring of the existing custom clock API implementation. Some of the Tegra clock APIs that manipulate peripheral clocks require both the peripheral clock ID and parent clock ID to be passed in together. However, the clock uclass API does not require any such "parent" parameter, so the clock driver must determine this information itself. This patch implements new Tegra- specific clock API clock_get_periph_parent() for this purpose. The new API is implemented in the core Tegra clock code rather than SoC- specific clock code. The implementation uses various SoC-/clock-specific data. That data is only available in SoC-specific clock code. Consequently, two new internal APIs are added that enable the core clock code to retrieve this information from the SoC-specific clock code. Due to the structure of the Tegra clock code, this leads to some unfortunate code duplication. However, this situation predates this patch. Ideally, future work will de-duplicate the Tegra clock code, and migrate it into drivers/clk/tegra. However, such refactoring is kept separate from this series. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27ARM: tegra: add peripheral clock init tableStephen Warren
Currently, Tegra peripheral drivers control two aspects of their HW module clock(s): 1) The clock enable/rate for the peripheral clock itself. 2) The system-level clock tree setup, i.e. the clock parent. Aspect 1 is reasonable, but aspect 2 is a system-level decision, not something that an individual peripheral driver should in general know about or influence. Such system-level knowledge ties the driver to a specific SoC implementation, even when they use generic APIs for clock manipulation, since they must have SoC-specific knowledge such as parent clock IDs. Limited exceptions exist, such as where peripheral HW is expected to dynamically switch between clock sources at run-time, such as CPU clock scaling or display clock conflict management in a multi-head scenario. This patch enhances the Tegra core code to perform system-level clock tree setup, in a similar fashion to the Linux kernel Tegra clock driver. This will allow future patches to simplify peripheral drivers by removing the clock parent setup logic. This change is required prior to converting peripheral drivers to use the standard clock APIs, since: 1) The clock uclass doesn't currently support a set_parent() operation. Adding one is possible, but not necessary at the moment. 2) The clock APIs retrieve all clock IDs from device tree, and the DT bindings for almost all peripherals only includes information about the relevant peripheral clocks, and not any potential parent clocks. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27mmc: tegra: Add DM_MMC support to Tegra MMC driverTom Warren
Convert the Tegra MMC driver to DM_MMC. Support for non-DM is removed to avoid ifdefs in the code. DM_MMC is now enabled for all Tegra builds. Cc: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Tom Warren <twarren@nvidia.com> (swarren, fixed some NULL pointer dereferences, removed extraneous changes, rebased on various other changes, removed non-DM support etc.) Signed-off-by: Stephen Warren <swarren@nvidia.com>
2016-09-27mmc: tegra: priv struct and naming cleanupStephen Warren
struct mmc_host is a Tegra-specific structure, but the name implies it's something defined by core MMC code, which is confusing. Rename it to struct tegra_mmc_priv to make its purpose more obvious. The new name is also more appropriate for a DM driver private data structure, which will be relevant later in this series. Nothing needs access to this type except the MMC driver itself. Move the definition into the driver C file. Make sure all Tegra MMC functions are named tegra_mmc_*. Even though they're all static, it's useful to have good naming so that symbol tables are easy to interpret. A few functions aren't renamed by this patch since they'll be deleted by a subsequent patch in this series. Cc: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27mmc: tegra: move pad_init_mmc() into MMC driverStephen Warren
pad_init_mmc() is performing an SoC-specific operation, using registers within the MMC controller. There's no reason to implement this code outside the MMC driver, so move it inside the driver. Cc: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-15mmc: tegra: port to standard clock/reset APIsStephen Warren
Tegra186 supports the new standard clock and reset APIs. Older Tegra SoCs still use custom APIs. Enhance the Tegra MMC driver so that it can operate with either set of APIs. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-15misc: add Tegra BPMP driverStephen Warren
The Tegra BPMP (Boot and Power Management Processor) is a separate auxiliary CPU embedded into Tegra to perform power management work, and controls related features such as clocks, resets, power domains, PMIC I2C bus, etc. This driver provides the core low-level communication path by which feature-specific drivers (such as clock) can make requests to the BPMP. This driver is similar to an MFD driver in the Linux kernel. It is unconditionally selected by CONFIG_TEGRA186 since virtually any Tegra186 build of U-Boot will need the feature. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-07-21ARM: tegra: add IVC protocol implementationStephen Warren
IVC (Inter-VM Communication) protocol is a Tegra-specific IPC (Inter Processor Communication) framework. Within the context of U-Boot, it is typically used for communication between the main CPU and various auxiliary processors. In particular, it will be used to communicate with the BPMP (Boot and Power Management Processor) on Tegra186 in order to manipulate clocks and reset signals. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-07-16Various, unrelated tree-wide typo fixes.Robert P. J. Day
Fix a number of typos, including: * "compatble" -> "compatible" * "eanbeld" -> "enabled" * "envrionment" -> "environment" * "FTD" -> "FDT" (for "flattened device tree") * "ommitted" -> "omitted" * "overriden" -> "overridden" * "partiton" -> "partition" * "propogate" -> "propagate" * "resourse" -> "resource" * "rest in piece" -> "rest in peace" * "suport" -> "support" * "varible" -> "variable" Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-05-31mmc: tegra: add basic Tegra186 supportStephen Warren
Tegra186's MMC controller needs to be explicitly identified. Add another compatible value for it. Tegra186 will use an entirely different clock/reset control mechanism to existing chips, and will use standard clock/reset APIs rather than the existing Tegra-specific custom APIs. The driver support for that isn't ready yet, so simply disable all clock/reset usage if compiling for Tegra186. This must happen at compile time rather than run-time since the custom APIs won't even be compiled in on Tegra186. In the long term, the plan would be to convert the existing custom APIs to standard APIs and get rid of the ifdefs completely. The system's main eMMC will work without any clock/reset support, since the firmware will have already initialized the controller in order to load U-Boot. Hence the driver is useful even in this apparently crippled state. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-05-31ARM: tegra: use DT bindings for GPIO namingStephen Warren
There are currently many places that define the list of all Tegra GPIOs; the DT binding header and custom Tegra-specific header file gpio.h. Fix the redundancy by replacing everything with the DT binding header file. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-05-04ARM: tegra: enable GPU node by compatible valueStephen Warren
In current Linux kernel Tegra DT files, 64-bit addresses are represented in unit addresses as a pair of comma-separated 32-bit values. Apparently this is no longer the correct representation for simple busses, and the unit address should be represented as a single 64-bit value. If this is changed in the DTs, arm/arm/mach-tegra/board2.c:ft_system_setup() will no longer be able to find and enable the GPU node, since it looks up the node by name. Fix that function to enable nodes based on their compatible value rather than their node name. This will work no matter what the node name is, i.e for DTs both before and after any rename operation. Cc: Thierry Reding <treding@nvidia.com> Cc: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: video: Clean up the old LCD/PWM driver codeSimon Glass
Remove the old PWM code. Remove calls to CONFIG_LCD functions now that we are using driver model for video. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: lcd: Merge tegra124-lcd.c into display.cSimon Glass
There isn't a lot of benefit of have two separate files. With driver model the code needs to be in the same driver, so it's better to have it in the same file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: pwm: Add a driver for the tegra PWMSimon Glass
This PWM supports four channels. The driver always uses the 32KHz clock, and adjusts the duty cycle accordingly. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-12ARM: tegra: rename GPU functionsAlexandre Courbot
Rename GPU functions to less generic names to avoid potential name collisions. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-11-12ARM: tegra: remove vpr_configured() functionAlexandre Courbot
There is no justification for this function, especially in exported form. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-09-16ARM: tegra: Implement clk_mThierry Reding
On currently supported SoCs, clk_m always runs at the same frequency as the oscillator input. However newer SoC generations such as Tegra210 no longer have that restriction. Prepare for that by separating clk_m from the oscillator clock and allow SoC code to override the clk_m rate. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-09-16tegra: Remove tegra_spl_gpio_direction_output declaration from header fileAxel Lin
This function is deleted by commit 2fccd2d96bad "tegra: Convert tegra GPIO driver to use driver model". Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-09-11bitops: introduce BIT() definitionHeiko Schocher
introduce BIT() definition, used in at91_udc gadget driver. Signed-off-by: Heiko Schocher <hs@denx.de> [remove all other occurrences of BIT(x) definition] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-08-13ARM: tegra: Make pinmux.h standalone includibleThierry Reding
This header file uses type definitions (u8, u32) from linux/types.h but doesn't include it. If includes aren't carefully ordered this can cause build failures. Cc: Tom Warren <twarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-13ARM: tegra: allow reading recovery mode boot typeMarcel Ziswiler
Add defines to allow reading recovery mode (RCM) boot type from the boot information table (BIT) written by the boot ROM (BR) to the IRAM. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-06ARM: tegra: enable GPU DT node when appropriateAlexandre Courbot
T124/210 requires some specific configuration (VPR setup) to be performed by the bootloader before the GPU can be used. For this reason, the GPU node in the device tree is disabled by default. This patch enables the node if U-boot has performed VPR configuration. Boards enabled by this patch are T124's Jetson TK1 and Venice2 and T210's P2571. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-06ARM: tegra: move VPR configuration to a later stageAlexandre Courbot
U-boot is responsible for enabling the GPU DT node after all necessary configuration (VPR setup for T124) is performed. In order to be able to check whether this configuration has been performed right before booting the kernel, make it happen during board_init(). Also move VPR configuration into the more generic gpu.c file, which will also host other GPU-related functions, and let boards specify individually whether they need VPR setup or not. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-05Tegra: PLL: use per-SoC pllinfo table instead of PLL_DIVM/N/P, etc.Tom Warren
Added PLL variables (dividers mask/shift, lock enable/detect, etc.) to new pllinfo struct for each Soc/PLL. PLLA/C/D/E/M/P/U/X. Used pllinfo struct in all clock functions, validated on T210. Should be equivalent to prior code on T124/114/30/20. Thanks to Marcel Ziswiler for corrections to the T20/T30 values. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-05Tegra: clocks: Add 38.4MHz OSC support for T210 useTom Warren
Added 38.4MHz/48MHz entries to pll_x_table for CPU PLL. Needs to be measured - should be close to 700MHz (1.4G/2). Note that some freqs aren't in the PLLU table in T210 TRM (13, 26MHz), so I used the 12MHz table entry for them. They shouldn't be selected since they're not viable T210 OSC freqs. Since there are now 2 new OSC defines, all tables (pll_x_table, PLLU) had to increase by two entries, but since 38.4/48MHz are not viable osc freqs on T20/30/114, etc, they're just set to 0. Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-07-28ARM: Tegra210: Add support to common Tegra source/config filesTom Warren
Derived from Tegra124, modified as appropriate during T210 board bringup. Cleaned up debug statements to conserve string space, too. This also adds misc 64-bit changes from Thierry Reding/Stephen Warren. Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-06-09tegra: Allow board-specific initSimon Glass
Add a hook to allows boards to add their own init to board_init(). Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-06-09tegra: clock: Support enabling external clocksSimon Glass
Add a simple function to enable external clocks. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13tegra: Make tegra_powergate_power_on publicJan Kiszka
Will be used for unpowergating CPUs. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Thierry Reding <treding@nvidia.com> Tested-by: Thierry Reding <treding@nvidia.com> Tested-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13tegra124: video: Add full link training for eDPSimon Glass
Add full link training as a fallback in case the fast link training fails. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13tegra: Move display controller header into commonSimon Glass
Allow this to be used by other Tegra SoCs. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13tegra124: clock: Add display clocks and functionsSimon Glass
Add functions to provide access to the display clocks on Tegra124 including setting the clock rate for an EDP display. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13tegra: clock: Split the clock source code into a separate functionSimon Glass
Create a function which sets the source clock for a peripheral, given the number of mux bits to adjust. This can then be used more generally. For now, don't export it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13tegra: clock: Add checking for invalid clock IDsSimon Glass
The get_pll() function can do the wrong thing if passed values that are out of range. Add checks for this and add a function which can return a 'simple' PLL. This can be defined by SoCs with their own clocks. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13tegra: Provide a function to allow LCD PMIC setupSimon Glass
Some LCDs require a PMIC to be set up - add a function for this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13tegra: Add a board ID functionSimon Glass
Add a way of displaying a numeric board ID on start-up. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13tegra: pwm: Allow the clock rate to be left as isSimon Glass
When enabling a PWM, allow the existing clock rate and source to stand unchanged. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13tegra: Move the pwm into tegra-commonSimon Glass
This is needed for tegra124 also, so make it common and add a header file for tegra124. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-30ARM: tegra: pinctrl: add support for MIPI PAD control groupsStephen Warren
Some pinmux controls are in a different register set. Add support for manipulating those in a similar way to existing pins/groups. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-30ARM: tegra: pinctrl: minor cleanupStephen Warren
Move struct pmux_pingrp_desc type and tegra_soc_pingroups variable declaration together with other pin/mux level definitions. Now the whole file is grouped/ordered pin/mux-related then drvgrp-related definitions. Fix typo in ifdef comment. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-04ARM: tegra: pinmux: support Tegra210's e_io_hv pin optionStephen Warren
Tegra210 has a per-pin option named e_io_hv, which indicates that the pin's input path should be configured to be 3.3v-tolerant. Add support for this. Note that this is very similar to previous chip's rcv_sel option. However, since the Tegra TRM names this option differently for the different chips, we support the new name so that the code exactly matches the naming in the TRM, to avoid confusion. This patch incorporates a few fixes from Tom Warren <twarren@nvidia.com>. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-04ARM: tegra: pinmux: support hsm/schmitt on pinsStephen Warren
T210 support HSM and Schmitt options in the pinmux register (previous chips placed these options in the drive group register). Update the code to handle this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-04ARM: tegra: pinmux: move some type definitionsStephen Warren
On some future SoCs, some per-drive-group features became per-pin features. Move all type definitions early in the header so they can be enabled irrespective of the setting of TEGRA_PMX_SOC_HAS_DRVGRPS. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-04ARM: tegra: pinmux: handle feature removal on newer SoCsStephen Warren
On some future SoCs, some of the per-drive-group features no longer exist. Add some ifdefs to support this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-04ARM: tegra: pinmux: simplify some definesStephen Warren
Future SoCs have a slightly different combination of pinmux options per pin. This will be simpler to handle if we simply have one define per option, rather than grouping various options together, in combinations that don't align with future chips. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-04ARM: tegra: add function to clear pinmux CLAMPING bitStephen Warren
This is needed to correctly apply the new Jetson TK1 pinmux config. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-04ARM: tegra: support running in non-secure modeStephen Warren
When the CPU is in non-secure (NS) mode (when running U-Boot under a secure monitor), certain actions cannot be taken, since they would need to write to secure-only registers. One example is configuring the ARM architectural timer's CNTFRQ register. We could support this in one of two ways: 1) Compile twice, once for secure mode (in which case anything goes) and once for non-secure mode (in which case certain actions are disabled). This complicates things, since everyone needs to keep track of different U-Boot binaries for different situations. 2) Detect NS mode at run-time, and optionally skip any impossible actions. This has the advantage of a single U-Boot binary working in all cases. (2) is not possible on ARM in general, since there's no architectural way to detect secure-vs-non-secure. However, there is a Tegra-specific way to detect this. This patches uses that feature to detect secure vs. NS mode on Tegra, and uses that to: * Skip the ARM arch timer initialization. * Set/clear an environment variable so that boot scripts can take different action depending on which mode the CPU is in. This might be something like: if CPU is secure: load secure monitor code into RAM. boot secure monitor. secure monitor will restart (a new copy of) U-Boot in NS mode. else: execute normal boot process Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-01-29dm: mmc: Remove use of fdtdec GPIO supportSimon Glass
These functions are going away, so use the new uclass support instead. Signed-off-by: Simon Glass <sjg@chromium.org>
