path: root/arch/arm/include/asm/arch-tegra20/tegra20_slink.h
2014-10-22dm: tegra: spi: Convert to driver modelSimon Glass
This converts the Tegra SPI drivers to use driver model. This is tested on: - Tegra20 - trimslice - Tegra30 - beaver - Tegra124 - dalmore (not tested on Tegra124) Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-25spi: add common fdt SPI driver interfaceAllen Martin
Add a common interface to fdt based SPI drivers. Each driver is represented by a table entry in fdt_spi_drivers[]. If there are multiple SPI drivers in the table, the first driver to return success from spi_init() will be registered as the SPI driver. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-25tegra: spi: pull register structs out of headersAllen Martin
Move register structs from headers into .c files and use common name. This is in preparation of making common fdt front end for SPI drivers. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-25tegra: spi: rename tegra SPI driversAllen Martin
Rename tegra SPI drivers to tegra20_flash and tegra20_slink in preparation for commonization and addition of tegra114_spi. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
