path: root/arch/arm/include/asm/arch-socfpga
2014-04-07socfpga: Adding Clock Manager driverChin Liang See
Clock Manager driver will be called to reconfigure all the clocks setting based on user input. The input are passed to Preloader through handoff files Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> CC: Pavel Machek <pavel@denx.de> Cc: Dinh Nguyen <dinguyen@altera.com> Acked-by: Pavel Machek <pavel@denx.de>
2014-01-09socfpga/dwmmc: Adding DesignWare MMC driver support for SOCFPGAChin Liang See
To add the DesignWare MMC driver support for Altera SOCFPGA. It required information such as clocks and bus width from platform specific files (SOCFPGA handoff files) Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Rajeshwari Shinde <rajeshwari.s@samsung.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-12-03socfpga: Adding Freeze Controller driverChin Liang See
Adding Freeze Controller driver. All HPS IOs need to be in freeze state during pin mux or IO buffer configuration. It is to avoid any glitch which might happen during the configuration from propagating to external devices. Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Wolfgang Denk <wd@denx.de> CC: Pavel Machek <pavel@denx.de> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Tom Rini <trini@ti.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2013-10-07socfpga: Adding System Manager driverChin Liang See
Adding System Manager driver which will configure the pin mux for real hardware Cyclone V development kit (not Virtual Platform) Signed-off-by: Chin Liang See <clsee@altera.com> Reviewed-by: Pavel Machek <pavel@denx.de> Acked-by: Dinh Nguyen <dinguyen@altera.com> Cc: Wolfgang Denk <wd@denx.de> CC: Pavel Machek <pavel@denx.de> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Tom Rini <trini@ti.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2013-09-06socfpga: Creating driver for Reset ManagerChin Liang See
Consolidating reset code into reset_manager.c. Also separating reset configuration for virtual target and real hardware Cyclone V development kit Signed-off-by: Chin Liang See <clsee@altera.com> Reviewed-by: Pavel Machek <pavel@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Tom Rini <trini@ti.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2012-10-04ARM: Add Altera SOCFPGA Cyclone5Dinh Nguyen
Add minimal support for Altera's SOCFPGA Cyclone 5 hardware. Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Signed-off-by: Chin Liang See <clsee@altera.com> Signed-off-by: Pavel Machek <pavel@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Tom Trini <trini@ti.com> Cc: Wolfgang Denx <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefan Roese <sr@denx.de> ---- v8: Remove no_return attribute for reset_cpu Based on v2012.10-rc2
