path: root/arch/arm/include/asm/arch-s5pc1xx/gpio.h
2015-11-30arm: s5pc1xx: move SoC to mach-s5pc1xxMinkyu Kang
move arm/arm/cpu/armv7/s5pc1xx to arch/arm/mach-s5pc1xx Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-22dm: exynos: gpio: Convert to driver modelSimon Glass
Convert the exynos GPIO driver to driver model. This implements the generic GPIO interface but not the extra Exynos-specific functions. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-22dm: exynos: Tidy up GPIO headersSimon Glass
The wrong header is being included, thus requiring the code to re-declare the generic GPIO interface in each GPIO header. Fix this. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-13S5P: Exynos: Add GPIO pin numbering and rename definitionsAkshay Saraswat
This patch includes following changes : * Adds gpio pin numbering support for EXYNOS SOCs. To have consistent 0..n-1 GPIO numbering the banks are divided into different parts where ever they have holes in them. * Rename GPIO definitions from GPIO_... to S5P_GPIO_... These changes were done to enable cmd_gpio for EXYNOS and cmd_gpio has GPIO_INPUT same as s5p_gpio driver and hence getting a error during compilation. * Adds support for name to gpio conversion in s5p_gpio to enable gpio command EXYNOS SoCs. Function has been added to asm/gpio.h to decode the input gpio name to gpio number. Example: SMDK5420 # gpio set gpa00 Signed-off-by: Leela Krishna Amudala <l.krishna@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-02-03s5p: gpio: change gpio coding method for s5p gpio.Przemyslaw Marczak
Old s5p gpio coding method was not clean and was not working properly for all parts and banks. New method is clean and easy to extend. Gpio coding mask: 0x000000ff - pin number 0x00ffff00 - bank offset 0xff000000 - part number Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-11-15gpio:fix: Proper handling of GPIO subsystem parts at Samsung devicesŁukasz Majewski
Now proper GPIO parts numbering is handled at Samsung devices. This fix is necessary for code using GPIO located at other banks than first. Test HW: - Exynos4210 - Trats - S5PC110 - goni Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-09-04i2c:gpio:s5p: I2C GPIO Software implementation (via soft_i2c)Łukasz Majewski
This patch adds support for software I2C for GONI and Universal C210 reference targets. It adds support for access to GPIOs by number, not as it is present, by bank and offset. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Cc: Heiko Schocher <hs@denx.de>
2011-09-03gpio:samsung s5p_ suffix add for GPIO functionsŁukasz Majewski
This change is driven by need of general gpio_* functions, which as their parameter are accepting the GPIO pin number, NOT block and pin. This makes the code alike to omap, and allows for using more generic frameworks (e.g. software I2C). Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-05-26S5P: GPIO Macro Values Corrected.Chander Kashyap
S5PC2XX: Macro values for Pull Up and Driver Strength were wrong. S5PC1XX: Macro values for Driver Strength were wrong. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-08-30ARMV7: S5P: rename the member of gpio structureMinkyu Kang
Typically we declare the name of gpio structure to "gpio", so it was duplicated around the name. (e.g: gpio->gpio_a) This patch modified the naming that is removing "gpio_". Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-04-30SAMSUNG: make s5p common gpio functionsMinkyu Kang
Because of s5pc1xx gpio is same as s5p seires SoC, move gpio functions to drvier/gpio/ and modify structure's name from s5pc1xx_ to s5p_. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-04-13Move architecture-specific includes to arch/$ARCH/include/asmPeter Tyser
This helps to clean up the include/ directory so that it only contains non-architecture-specific headers and also matches Linux's directory layout which many U-Boot developers are already familiar with. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
