path: root/arch/arm/include/asm/arch-rockchip/pmu_rk3188.h
2017-03-16rockchip: rk3188: Add header files for PMU and GRFHeiko Stübner
PMU is the power management unit and GRF is the general register file. Both are heavily used in U-Boot. Add header files with register definitions. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Kever Yang <kever.yang@rock-chips.com>
