path: root/arch/arm/include/asm/arch-orion5x
2015-02-25edminiv2: switch to SPLAlbert ARIBAUD
ED Mini V2 is based on Orion 5x which boots at fixed address 0xFFFF0000 in NOR Flash. Place SPL there, and switch U-Boot from .bin to .img format, stored in NOR Flash at 0xFFF90000. Note: this patch was tested on HW and works, i.e. it boots U-Boot properly, but SPL console output currently does not appear, due to GD being trashed by arch/arm/lib/spl.c. This trashing is soon to be removed, and then ED Mini V2 SPL console output will become visible. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2015-02-21ARM: orion5x: move SoC headers to mach-orion5x/include/machMasahiro Yamada
Move arch/arm/include/asm/arch-orion5x/* -> arch/arm/mach-orion5x/include/mach/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-03ARM: kirkwood/orion5x: Use reset_cpu definition in include/common.hDinh Nguyen
include/common.h has the reset_cpu defined already. No need to re-define here. Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Signed-off-by: Pavel Machek <pavel@denx.de> Acked-By: Prafulla Wadaskar <Prafulla@marvell.com>
2012-02-12orion5x: add USB host ehci-marvell supportAlbert ARIBAUD
2011-10-27ARM: orion5x: reduce dependence of including platform fileLei Wen
For files like the drivers/serial/serial.c, it must include the platform file, as the CONFIG_SYS_NS16550_COM1 must reference to the definition in the platform definition files. Include the platform definition file in the config file, so that it would decouple the dependence for the driver files. Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-04-27Replace obsolete e-mail addressAlbert ARIBAUD
2011-04-27Orion5x: Correct DRAM bank detectionRogan Dawes
2010-10-11orion5x: fix relocation-incompatible codeAlbert Aribaud
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-08-27orion5x: fix comment-in-comment typo in cpu.hAlbert Aribaud
2010-08-10orion5x: allow overriding default mappings windowsAlbert Aribaud
Turn all ORION5X_DEF{ADR,SZ}_xxx macros into ORION5X_{ADR,SZ}_xxx and allow defining them from board code to override defaults. This is particularly useful for defining board-specific FLASH address and size in board header file rather than having to tweak orion5x code. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-08-08cmd_ide: add support for orion5xAlbert Aribaud
Add MVSATAHC definitions to orion5x. Add support for orion5x in cmd_ide. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-07-12mvgbe: add support for orion5x GbE controllerAlbert Aribaud
Add definitions and initialization in orion5x for mvgbe. Add orion5x in mvgbe SoC includes. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-06-17Initial support for Marvell Orion5x SoCAlbert Aribaud
This patch adds support for the Marvell Orion5x SoC. It has no use alone, and must be followed by a patch to add Orion5x support for serial, then support for the ED Mini V2, an Orion5x-based product from LaCie. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
