path: root/arch/arm/include/asm/arch-omap5/omap.h
2018-01-19arm: dra762: Add support for device package identificationLokesh Vutla
DRA762 comes in two packages: - ABZ: Pin compatible package with DRA742 with DDR@1333MHz - ACD: High performance(OPP_PLUS) package with new IPs Both the above packages uses the same IDCODE hence needs to differentiate using package information in DIE_ID_2. Add support for the same. Also update clock, ddr, emif information. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-09-12ARM: DRA72x: Add support for detection of DRA71x SR 2.1Vishal Mahaveer
DRA71x processors are reduced pin and software compatible derivative of DRA72 processors. Add support for detection of SR2.1 version of DRA71x family of processors. Signed-off-by: Vishal Mahaveer <vishalm@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-09-11arm: dra76: Add support for ES1.0 detectionPraneeth Bajjuri
dra76 family is a high-performance, infotainment application device, based on OMAP architecture on a 28-nm technology. This contains most of the subsystems, peripherals that are available on dra74, dra72 family. This SoC mainly features Subsystems: - 2 x Cortex-A15 with max speed of 1.8GHz - 2 X DSP - 2 X Cortex-M4 IPU - ISS - CAL - DSS - VPE - VIP Connectivity peripherals: - 1 USB3.0 and 3 USB2.0 subsystems - 1 x SATA - 2 x PCI Express Gen2 - 3-port Gigabit ethernet switch - 2 x CAN - MCAN Adding CPU detection support for the dra76 ES1.0 soc and update prcm, control module, dplls data. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Praneeth Bajjuri <praneeth@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-08-13ARM: OMAP5: Enable support for AVS0 for OMAP5 production devicesNishanth Menon
OMAP5432 did go into production with AVS class0 registers which were mutually exclusive from AVS Class 1.5 registers. Most OMAP5-uEVM boards use the pre-production Class1.5 which has production efuse registers set to 0. However on production devices, these are set to valid data. scale_vcore logic is already smart enough to detect this and use the "Nominal voltage" on devices that do not have efuse registers populated. On a test production device populated as follows: MPU OPP_NOM: => md.l 0x04A0021C4 1 4a0021c4: 03a003e9 .... (0x3e9 = 1.01v) vs nom voltage of 1.06v MPU OPP_HIGH: => md.l 0x04A0021C8 1 4a0021c8: 03400485 ..@. MM OPP_NOM: => md.l 0x04A0021A4 1 4a0021a4: 038003d4 .... (0x3d4 = 980mV) vs nom voltage of 1.025v MM OPP_OD: => md.l 0x04A0021A8 1 4a0021a8: 03600403 ..`. CORE OPP_NOM: => md.l 0x04A0021D8 1 4a0021d8: 000003cf .... (0x3cf = 975mV) vs nom voltage of 1.040v Since the efuse values are'nt currently used, we do not regress on existing pre-production samples (they continue to use nominal voltage). But on boards that do have production samples populated, we can leverage the optimal voltages necessary for proper operation. Tested on: a) 720-2644-001 OMAP5UEVM with production sample. b) 750-2628-222(A) UEVM5432G-02 with pre-production sample. Data based on OMAP5432 Technical reference Manual SWPU282AF (May 2012-Revised Aug 2016) NOTE: All collaterals on OMAP5432 silicon itself seems to have been removed from ti.com, though EVM details are still available: http://www.ti.com/tool/OMAP5432-EVM Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-06-09arm: omap: Unify get_device_type() functionSemen Protsenko
Refactor OMAP3/4/5 code so that we have only one get_device_type() function for all platforms. Details: - Add ctrl variable for AM33xx and OMAP3 platforms (like it's done for OMAP4/5), so we can obtain status register in common way - For now ctrl structure for AM33xx/OMAP3 contains only status register address - Run hw_data_init() in order to assign ctrl to proper structure - Remove DEVICE_MASK and DEVICE_GP definitions as they are not used (DEVICE_TYPE_MASK and GP_DEVICE are used instead) - Guard structs in omap_common.h with #ifdefs, because otherwise including omap_common.h on non-omap4/5 board files breaks compilation Buildman script was run for all OMAP boards. Result output: arm: (for 38/616 boards) all +352.5 bss -1.4 data +3.5 rodata +300.0 spl/u-boot-spl:all +284.7 spl/u-boot-spl:data +2.2 spl/u-boot-spl:rodata +252.0 spl/u-boot-spl:text +30.5 text +50.4 (no errors to report) Tested on AM57x EVM and BeagleBoard xM. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> [trini: Rework the guards as to not break TI81xx] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-02-17ARM: DRA7xx: Fix memory allocation overflowAndrew F. Davis
When using early malloc the allocated memory can overflow into the SRAM scratch space, move NON_SECURE_SRAM_IMG_END down a bit to allow more dynamic allocation at the expense of a slightly smaller maximum image size. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-12-03ARM: DRA7x/AM57xx: Get rid of CONFIG_AM57XXNishanth Menon
CONFIG_AM57XX is just an unnecessary macro that is redundant given So, remove the same instead of spreading through out the u-boot source code and getting in the way to maintain common code for DRA7x family. Acked-by: Andrew F. Davis <afd@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-06TI: Rework SRAM definitions and maximumsTom Rini
On all TI platforms the ROM defines a "downloaded image" area at or near the start of SRAM which is followed by a reserved area. As it is at best bad form and at worst possibly harmful in corner cases to write in this reserved area, we stop doing that by adding in the define NON_SECURE_SRAM_IMG_END to say where the end of the downloaded image area is and make SRAM_SCRATCH_SPACE_ADDR be one kilobyte before this. At current we define the end of scratch space at 0x228 bytes past the start of scratch space this this gives us a lot of room to grow. As these scratch uses are non-optional today, all targets are modified to respect this boundary. Tested on OMAP4 Pandaboard, OMAP3 Beagle xM Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Paul Kocialkowski <contact@paulk.fr> Cc: Enric Balletbo i Serra <eballetbo@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Thomas Weber <weber@corscience.de> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Heiko Schocher <hs@denx.de> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: "B, Ravi" <ravibabu@ti.com> Cc: "Matwey V. Kornilov" <matwey.kornilov@gmail.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: "Kipisz, Steven" <s-kipisz2@ti.com> Cc: Daniel Allred <d-allred@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Ladislav Michl <ladis@linux-mips.org>
2016-04-25ARM: DRA7: Add ABB setup for all domainsNishanth Menon
ABB should be initialized for all required domains voltage domain for DRA7: IVA, GPU, EVE in addition to the existing MPU domain. If we do not do this, kernel configuring just the frequency using the default boot loader configured voltage can fail on many corner lot units and has been hard to debug. This specifically is a concern with DRA7 generation of SoCs since other than VDD_MPU, all other domains are only permitted to setup the voltages to required OPP only at boot. Reported-by: Richard Woodruff <r-woodruff2@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2016-04-25ARM: OMAP5: Enable ABB configuration for MM voltage domainNishanth Menon
Since we setup the voltage and frequency for the MM domain, we *must* setup the ABB configuration needed for the domain as well. If we do not do this, kernel configuring just the frequency using the default boot loader configured voltage can fail on many corner lot units. Reported-by: Richard Woodruff <r-woodruff2@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2016-03-27ARM: DRA72x: Add support for detection of SR2.0Ravi Babu
Add support for detection of SR2.0 version of DRA72x family of processors. Signed-off-by: Ravi Babu <ravibabu@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-28board: ti: OMAP5: added USB initializtion codeKishon Vijay Abraham I
Implemented board_usb_init(), board_usb_cleanup() and usb_gadget_handle_interrupts() in omap5 board file that can be invoked by various gadget drivers. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-28board: ti: beagle_x15: added USB initializtion codeKishon Vijay Abraham I
Implemented board_usb_init(), board_usb_cleanup() and usb_gadget_handle_interrupts() in beagle_x15 board file that can be invoked by various gadget drivers. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-28ARM: DRA74-evm: Use SMA_1 spare register to workaround DP83865 phy on SR2.0Nishanth Menon
DP83865 ethernet phy used on DRA74x-evm is quirky and the datasheet provided IODELAY values for standard RGMII phys do not work. Silicon Revision(SR) 2.0 provides an alternative bit configuration that allows us to do a "gross adjustment" to launch the data off a different internal clock edge. Manual IO Delay overrides are still necessary to fine tune the clock-to-data delays. This is a necessary workaround for the quirky ethernet Phy we have on the platform. NOTE: SMA registers are spare "kitchen sink" registers that does contain bits for other workaround as necessary as well. Hence the control for the same is introduced in a generic SoC specific, board generic location. Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-28ARM: DRA7: Add detection of ES2.0Nishanth Menon
Add support for detection of ES2.0 version of DRA7 family of processors. ES2.0 is an incremental revision with various fixes including the following: - reset logic fixes - few assymetric aging logic fixes - MMC clock rate fixes - Ethernet speed fixes - edma fixes for mcasp [ravibabu@ti.com: posted internal for an older bootloader] Signed-off-by: Ravi Babu <ravibabu@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-07-27omap-common: Common boot code OMAP3 support and cleanupPaul Kocialkowski
This introduces OMAP3 support for the common omap boot code, as well as a major cleanup of the common omap boot code. First, the omap_boot_parameters structure becomes platform-specific, since its definition differs a bit across omap platforms. The offsets are removed as well since it is U-Boot's coding style to use structures for mapping such kind of data (in the sense that it is similar to registers). It is correct to assume that romcode structure encoding is the same as U-Boot, given the description of these structures in the TRMs. The original address provided by the bootrom is passed to the U-Boot binary instead of a duplicate of the structure stored in global data. This allows to have only the relevant (boot device and mode) information stored in global data. It is also expected that the address where the bootrom stores that information is not overridden by the U-Boot SPL or U-Boot. The save_omap_boot_params is expected to handle all special cases where the data provided by the bootrom cannot be used as-is, so that spl_boot_device and spl_boot_mode only return the data from global data. All of this is only relevant when the U-Boot SPL is used. In cases it is not, save_boot_params should fallback to its weak (or board-specific) definition. save_omap_boot_params should not be called in that context either. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-06-12ARM: DRA7: CPSW: Remove IO delay hackLokesh Vutla
Now all manual mode configurations are done as part of IO delay recalibration sequence, remove the hack done for CPSW. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-04-14board: ti: DRA7: added USB initializtion codeKishon Vijay Abraham I
Implemented board_usb_init(), board_usb_cleanup() and usb_gadget_handle_interrupts() in dra7xx board file that can be invoked by various gadget drivers. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2014-12-04arm: omap: add support for am57xx devicesFelipe Balbi
just add a few ifdefs around because this device is very similar to dra7xxx. Signed-off-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-05-23armv7:TI: Add <asm/ti-common/sys_proto.h> and migrate omap_hw_init_contextTom Rini
The omap_hw_init_context function (and assorted helpers) is the same for all OMAP-derived parts as when CHSETTINGS are used, that's the same and our DDR base is also always the same. In order to make this common we simply need to update the names of the define for DDR address space which is also common. Cc: Sricharan R. <r.sricharan@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tom Rini <trini@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2014-05-23ARM: DRA72x: Add Silicon ID supportLokesh Vutla
Add silicon ID code for DRA722 silicon. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Tom Rini <trini@ti.com>
2014-05-23ARM: omap5: add platform specific info for GPMC and ELM controllerspekon gupta
This patch moves platform specific information for GPMC and ELM controller into separate header files, so that any derivative devices do not mess other header files. Platform specific information added into arch-xx/../hardware.h - CPU related platform specific details like base-address of GPMC and ELM Platform specific information added into arch-xx/../mem.h - Generic configs for GPMC and ELM initialization. - Hardware parameters or constrains specific to GPMC and ELM IP like; number of max number of chip-selects available Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-05-13ARM: OMAP5: add UART4 supportDmitry Lifshitz
Add UART4 base address. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
2014-01-24DRA7: add ABB setup for MPU voltage domainNishanth Menon
Patch adds modification to shared omap5 abb_setup() function, and proper registers definitions needed for ABB setup sequence. ABB is initialized for MPU voltage domain at OPP_NOM. Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-01-24DRA7: Add support for ES1.1 silicon ID codeNishanth Menon
ES1.1 silicon is a very minor variant of ES1.0. Add priliminary support for ES1.1 IDCODE change. Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-12-04ARM: OMAP5: Add PRCM and Control information for SATARoger Quadros
Adds the necessary PRCM and Control register information for SATA on OMAP5. Signed-off-by: Roger Quadros <rogerq@ti.com>
2013-12-04ARM: DRA: EMIF: Change DDR3 settings to use hw levelingSRICHARAN R
Currently the DDR3 memory on DRA7 ES1.0 evm board is enabled using software leveling. This was done since hardware leveling was not working. Now that the right sequence to do hw leveling is identified, use it. This is required for EMIF clockdomain to idle and come back during lowpower usecases. Signed-off-by: Sricharan R <r.sricharan@ti.com>
2013-11-01ARM: OMAP5: DDR3: Change io settingsSRICHARAN R
The change from 0x64656465 to 0x64646464 is to remove the weak pull enabled on DQS, nDQS lines. This pulls the differential signals in the same direction which is not intended. So disabling the weak pulls improves signal integrity. On the uEVM there are 4 DDR3 devices. The VREF for 2 of the devices is powered by the OMAP's VREF_CA_OUT pins. The VREF on the other 2 devices is powered by the OMAP's VREF_DQ_OUT pins. So the net effect here is that only half of the DDR3 devices were being supplied a VREF! This was clearly a mistake. The second change improves the robustness of the interface and was specifically seen to cure corruption observed at high temperatures on some boards. With the above two changes better memory stability was observed with extended temperature ranges around 100C. Signed-off-by: Sricharan R <r.sricharan@ti.com>
2013-10-07omap5: add qspi supportMatt Porter
Add QSPI definitions and clock configuration support. Signed-off-by: Matt Porter <matt.porter@linaro.org> Signed-off-by: Sourav Poddar <sourav.poddar@ti.com> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2013-08-28omap5: Expand CONFIG_SPL_MAX_SIZE and comment upon SRAM_SCRATCH_SPACE_ADDRTom Rini
After examining both TRMs and doing some experimentation, we can rely on using the start of the download area for CONFIG_SPL_TEXT_BASE and then move SRAM_SCRATCH_SPACE_ADDR up, just like am335x. This is required for peripheral boot modes such as UART. Signed-off-by: Tom Rini <trini@ti.com>
2013-07-26ARM: DRA7xx: Add CPSW support to DRA7xx EVMMugunthan V N
Adding support for CPSW Ethernet support found in DRA7xx EVM Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
2013-06-13Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Small conflict over DRA7XX updates and adding SRAM_SCRATCH_SPACE_ADDR Conflicts: arch/arm/include/asm/arch-omap5/omap.h Signed-off-by: Tom Rini <trini@ti.com>
2013-06-10ARM: DRA7xx: EMIF: Change settings required for EVM boardSricharan R
DRA7 EVM board has the below configuration. Adding the settings for the same here. 2Gb_1_35V_DDR3L part * 2 on EMIF1 2Gb_1_35V_DDR3L part * 4 on EMIF2 Signed-off-by: Sricharan R <r.sricharan@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-06-10mmc: omap_hsmmc: Update pbias programmingBalaji T K
Update pbias programming sequence for OMAP5 ES2.0/DRA7 Signed-off-by: Balaji T K <balajitk@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-06-10ARM: DRA7xx: Correct SRAM END addressSricharan R
NON SECURE SRAM is 512KB in DRA7xx devices. So fixing it here. Signed-off-by: Sricharan R <r.sricharan@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-06-10ARM: DRA7xx: Add control id code for DRA7xxLokesh Vutla
The registers that are used for device identification are changed from OMAP5 to DRA7xx. Using the correct registers for DRA7xx. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-06-10ARM: OMAP4+: Cleanup header filesLokesh Vutla
After having the u-boot clean up series, there are many definitions that are unused in header files. Removing all those unused ones. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-06-10OMAP3+: introduce generic ABB supportAndrii Tseglytskyi
Adaptive Body Biasing (ABB) modulates transistor bias voltages dynamically in order to optimize switching speed versus leakage. Adaptive Body-Bias ldos are present for some voltage domains starting with OMAP3630. There are three modes of operation: * Bypass - the default, it just follows the vdd voltage * Foward Body-Bias - applies voltage bias to increase transistor performance at the cost of power. Used to operate safely at high OPPs. * Reverse Body-Bias - applies voltage bias to decrease leakage and save power. Used to save power at lower OPPs. Signed-off-by: Andrii Tseglytskyi <andrii.tseglytskyi@ti.com> Acked-by: Nishanth Menon <nm@ti.com>
2013-06-06am33xx/omap4+: Move SRAM_SCRATCH_SPACE_ADDR to <asm/arch/omap.h>Tom Rini
The location of valid scratch space is dependent on SoC, so move that there. On OMAP4+ we continue to use SRAM_SCRATCH_SPACE_ADDR. On am33xx/ti814x we want to use what the ROM defines as "public stack" which is the area after our defined download image space. Correct the comment about and location of CONFIG_SPL_TEXT_BASE. Signed-off-by: Tom Rini <trini@ti.com>
2013-05-10ARM: OMAP4/5: Make OMAPx_SRAM_SCRATCH_ defines commonSRICHARAN R
These defines are same across OMAP4/5. So move them to omap_common.h. This is required for the patches that follow. Signed-off-by: Sricharan R <r.sricharan@ti.com>
2013-05-10ARM: OMAP: Make omap_boot_parameters common across socsSRICHARAN R
omap_boot_parameters is same and defined for each soc. So move this to a common place to reuse it across socs. Signed-off-by: Sricharan R <r.sricharan@ti.com>
2013-04-08arm: omap4: Fix SDRAM AUTO DETECTIONLokesh Vutla
Commit "8602114 omap: emif: configure emif only when required" breaks SDRAM_AUTO_DETECTION. The issue is dmm_init() depends on emif_sizes[](SDRAM Auto detection) done in do_sdram_init(). The above commit moves dmm_init() above do_sdram_init() because of which dmm_init() uses uninitialized emif_sizes[]. So instead of using global emif_sizes[], get sdram details locally and calculate emif sizes. Reported-by: Michael Cashwell <mboards@prograde.net> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-03-11arm: dra7xx: Add silicon id support for DRA752 socLokesh Vutla
Adding CPU detection support for the DRA752 ES1.0 soc. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: R Sricharan <r.sricharan@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-11ARM: OMAP5: srcomp: enable slew rate compensation cells after powerupLokesh Vutla
After power-up SRCOMP cells are by-passed by default in OMAP5. Software has to enable these SRCOMP sells. For ES2: All 5 SRCOMP cells needs to be enabled. For ES1: Only 4 SRCOMP cells in core power domain are enabled. The 1 in wkup domain is not enabled because smart i/os of wkup domain work with default compensation code. Signed-off-by: R Sricharan <r.sricharan@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Tom Rini <trini@ti.com>
2013-03-11ARM: OMAP5: Add DDR changes required for OMAP543X ES2.0 SOCsLokesh Vutla
Add pre calculated timing settings of LPDDR2 and DDR3 memories present in OMAP5430 and OMAP5432 ES2.0 versions. Also adding the DDR pad io settings required for OMAP543X SOCs here. Signed-off-by: R Sricharan <r.sricharan@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Tom Rini <trini@ti.com>
2013-03-11ARM: OMAP5: Add silicon id support for ES2.0 revision.SRICHARAN R
Adding the CPU detection suport for OMAP5430 and OMAP5432 ES2.0 SOCs. Signed-off-by: R Sricharan <r.sricharan@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Nishanth Menon <nm@ti.com>
2013-03-11ARM: OMAP5: Clean up iosettings codeLokesh Vutla
There is some code duplication in the ddr io settings code. This is avoided by moving the data to a Soc specific place and letting the code generic. This avoids unnessecary code addition for future socs. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-11ARM: OMAP4+: Make control module register structure genericLokesh Vutla
A seperate omap_sys_ctrl_regs structure is defined for omap4 & 5. If there is any change in control module for any of the ES versions, a new structure needs to be created. In order to remove this dependency, making the register structure generic for all the omap4+ boards. Signed-off-by: R Sricharan <r.sricharan@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
