path: root/arch/arm/include/asm/arch-omap5/clocks.h
2011-12-06arch/arm/include/asm/arch-omap5/clocks.h: Fix GCC 4.2 warningsAnatolij Gustschin
Fix: clocks.c: In function 'setup_post_dividers': clocks.c:175: warning: comparison is always true due to limited range of data type clocks.c:177: warning: comparison is always true due to limited range of data type clocks.c:179: warning: comparison is always true due to limited range of data type clocks.c:181: warning: comparison is always true due to limited range of data type clocks.c:183: warning: comparison is always true due to limited range of data type clocks.c:185: warning: comparison is always true due to limited range of data type clocks.c:187: warning: comparison is always true due to limited range of data type clocks.c:189: warning: comparison is always true due to limited range of data type Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: sricharan <r.sricharan@ti.com> Cc: Tom Rini <trini@ti.com>
2011-11-15omap4/5: Add support for booting with CH.Sricharan
Configuration header(CH) is 512 byte header attached to an OMAP boot image that will help ROM code to initialize clocks, SDRAM etc and copy U-Boot directly into SDRAM. CH can help us in by-passing SPL and directly boot U-boot, hence it's an alternative for SPL. However, we intend to support both CH and SPL for OMAP4/5. Initialization done through CH is limited and is not equivalent to that done by SPL. So U-Boot has to distinguish between the two cases and handle them accordingly. This patch takes care of doing this. Signed-off-by: sricharan <r.sricharan@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-15omap5: clocks: Add clocks support for omap5 platform.Sricharan
Adding the correct configurations required for dplls, clocks, for omap5 Soc. Also changes are done to retain some part of the code common for OMAP4/5 and move only the remaining to the Soc specific directories. Signed-off-by: sricharan <r.sricharan@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
