path: root/arch/arm/include/asm/arch-omap4/spl.h
2015-07-27omap: SPL boot devices cleanup and completionPaul Kocialkowski
This cleans up the SPL boot devices for omap platforms and introduces support for missing boot devices. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2014-03-28spl: Fix guardian macros in spl.hMarek Vasut
Fix the macros guarding the spl.h header for various platforms. Due to a typo and a propagation of it, the macros went out-of-sync with their ifdef check, so fix this. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com>
2013-04-08OMAP3/4/5/AM33xx: Correct logic for checking FAT or RAW MMCTom Rini
In the case of booting from certain peripherals, such as UART, we must not see what the device descriptor says for RAW or FAT mode because in addition to being nonsensical, it leads to a hang. This is why we have a test currently for the boot mode being within range. The problem however is that on some platforms we get MMC2_2 as the boot mode and not the defined value for MMC2, and in others we get the value for MMC2_2. This is required to fix eMMC booting on omap5_uevm. Tested on am335x_evm (UART, NAND, SD), omap3_beagle (NAND, SD on classic, SD only on xM rev C5) and omap5_uevm (SD, eMMC). Signed-off-by: Tom Rini <trini@ti.com>
2013-03-08SPL: ONENAND: Fix some ONENAND related defines.Enric Balletbo i Serra
Some ONENAND related defines use the term ONE_NAND instead of ONENAND, as the technology name is ONENAND this patch replaces all these defines. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2012-09-27ARM: SPL: Add <asm/spl.h> and <asm/arch/spl.h>Tom Rini
Move the SPL prototypes from <asm/omap_common.h> into <asm/spl.h> and add <asm/arch/spl.h> for arch specific portions of CONFIG_SPL_FRAMEWORK. Signed-off-by: Tom Rini <trini@ti.com>
